Complete Newbie ? about Auto vs Manual
Discussion in '2nd Gen. Tacomas (2005-2015)' started by elk assassin, Jun 19, 2012.
  1. Jun 19, 2012 at 3:12 PM
    elk assassin
    elk assassin [OP] Active Member
    Ohio CIty, Colorado
    1993 Lifted SR5
    I've only driven manual (1989) pre-tacomas off road and I can creep down a rocky, semi-steep road very slowly without much braking using 1st low. My question is in an Automatic 2006 TRD Sport Tacoma, is there going to be a gear that will allow me to do the same without much braking? I guess I'm asking is an automatic transmission going to allow me to do the same things I can do with a manual one? I'd appreciate any help you can give me. Doug Dillingham Ohio City, Colorado.
  2. Jun 19, 2012 at 3:20 PM
    Enzo
    Enzo Well-Known Member
    Opie
    Bedford, Va
    2012 FJ Cruiser
    2012 FJ Cruiser Maggiolina Medium Grand Tour w/winter hood National Luna dual battery split charging system ABR Sidewinder Aux battery tray ARB 50qt Fridge w/Transit Bag Bajarack flat rack w/ladder Crawlarado flat black hood blackout TRD exhaust Trasharoo Outback FJ roof console
    Yes and with my TRD OR I can use hill decent control or wtf it's called.
  3. Jun 19, 2012 at 3:23 PM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    Hi Doug, Welcome to TacomaWorld!
    The 2nd Gen automatic trans is great if you ask me. It allows you to shift from Drive to 4th, 3rd, 2nd, and Low. I use the Low gear when going down hills and it usually limits me to about 5-10mph depending on the grade. It's very useful to keep your brakes cool heading down the mountain. The shifter works by not allowing the transmission to shift any higher than the gear selected, so if you were in 2, the trans would not shift any higher than 2nd gear.
    The TRD Off-Road has an optional downhill assist which utilizes the brakes but is very useful when going down steep hills with little traction.
  4. Jun 19, 2012 at 6:42 PM
    elk assassin
    Ohio CIty, Colorado
    1993 Lifted SR5
  5. Jun 19, 2012 at 6:50 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    I've got the automatic. Useing the DAC (downhill assist control) while in 4 low with the shifter in 1st gear will get you crawling down a steep desent...no need to even touch the brake pedal.
  6. Jun 19, 2012 at 8:07 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    With the Sport 4x4 in L in 4LO , you creep pretty slow down hills , even without DAC
  7. Jun 20, 2012 at 5:15 AM
    elk assassin
    Ohio CIty, Colorado
    1993 Lifted SR5
  8. Jun 20, 2012 at 7:40 PM
    elk assassin
    Ohio CIty, Colorado
    1993 Lifted SR5
    Still hopin' a couple more people will chime in and let me know if an automatic 2006 TRD Sport (without downhill assist control) will have a low enough gear to be able to CREEP down steep, rocky mountain trails without excessive braking like a manual transmission would allow me to do.
  9. Jun 20, 2012 at 7:49 PM
    Monkeyboy
    Monkeyboy Well-Known Member
    Grand Junction, CO
    2012 AC TRD Sport
    I don't know the answer directly, but I seem to recall that the granny gear in 4LO on the manual is a bit lower than the automatic.
  10. Jun 20, 2012 at 7:57 PM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    Yes is the answer, you can crawl in 4L in L gear, with minimal braking or without.
  11. Jun 20, 2012 at 11:06 PM
    Nick82
    Nick82 Well-Known Member
    Nick
    Richmond ky
    2012 DCLB MGM 4x4 sport tow nav
    ARB winch bumper
    As he said, I'd be surprised if you ever had to put your foot on the brake in low gear 4 low.
  12. Jun 21, 2012 at 6:43 PM
    OZ-T
    Peter North
    British Columbia
    Did a test for you today OP
    Decended a 15% gravel / rock grade today
    Put the truck in 4LO , and in L
    Decended the hill without touching the brakes once , the speedo needle never left the 1/8" thick line that signifies 0 on the speedometer , so I would guess I was going 1 MPH , maybe
