complete noob to alignment and some info on 5100s that were just installed
Discussion in 'Suspension' started by StreetTaco4Me, Jun 17, 2013.
  1. Jun 17, 2013 at 11:04 PM
    StreetTaco4Me
    StreetTaco4Me [OP] Taco Shot
    Bryan
    Ventura County, So. Cal.
    2001 4runner SR5
    looking to replace shocks and add spacer lift...I do not off road at all just like the height of a lift
    in addition to my other questions here...is the rear alignment looking ok?
    I am going to go to the firestone in the next city over tomorrow to hopefully put this issue to rest...what a nightmare I just want an alignment and it is a fricken circus!
  2. Jun 18, 2013 at 5:33 AM
    Sandman614
    Sandman614 LRGRNR
    Boone, NC\Garner, NC
    '06 SR5 Off Road
    I hope you get a better tech at the next place. I used to work for firestone and it's sad to see them doing this kind of work.
    The rear looks fine. There's not a whole lot you can do with the rear on these trucks. The centering pin for the leafs is centered on the axle keeping it from moving, unless it breaks.
  3. Jun 18, 2013 at 5:51 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Yes, camber and toe being out of spec will eat up tires. Caster can be way out of spec but will not affect tire wear, it can make the truck feel squirrely though. If you have toe and camber very close to 0 and a low caster number but you think it drives fine, I'd say go with it. It's not going to hurt anything or cause any damage.
  4. Jun 18, 2013 at 6:19 AM
    JRFugitt
    JRFugitt Well-Known Member
    Justin
    Texas
    '13 PreRunner V6
  5. Jun 18, 2013 at 8:50 AM
    StreetTaco4Me
    Bryan
    2001 4runner SR5
    OK cool...that does help for sure...I will be sure to keep those toe and camber #s at 0 and then monitor the drive based on the caster and see if I feel uncomfortable with it...hopefully they will just get the caster into the correct spec even if it is on the low end...that would at least give me some confidence going forward.
    thanks for everyone's help on this.
  6. Jun 18, 2013 at 2:08 PM
    StreetTaco4Me
    Bryan
    2001 4runner SR5
    3rd attempt seems more successful...I guess...sacrificed some camber for some caster...lmk what you guys think...I talke to dewsk guy for about 15 minutes they definitely gave more effort to get it into spec than the previous store...it all seems in spec for now...I will ride it for a week or two and tke it in again if I need to adjust it but for now I think I am ok...any other thoughts are appreciated...
  7. Jun 18, 2013 at 4:24 PM
    ncooper
    ncooper Well-Known Member
    Nick
    Bay Area
    2013 MGM DCSB TRD SPORT 4x4
    5100's @ 1.75, ride rite airbags, borla exhaust, headlight retrofit
    I recently installed 5100's @1.75 and took my truck in for an alignment. After reading this thread I went and found my alignment specs and was not happy with what I saw. Took my truck back to Les Schwab and asked for 0/0/2.5 and they got pretty close, the tech informed me the camber adjustment was maxed out. Thanks for all the great info, also this is my first post.
  8. Jun 18, 2013 at 7:17 PM
    BBtacosurfer
    BBtacosurfer Well-Known Member
    Dave
    All Over CA
    MGM 2012 4x4
    Good info guys! I need to get an alignment done tomorrow. Will be using this info
