COMPLETED 5th Gen 4Runner BBK upgrade for 2nd Gen Tacomas
Discussion in 'Technical Chat' started by nudavinci64, Aug 4, 2017.
  1. Oct 14, 2020 at 8:37 PM
    #361
    eljedi68
    eljedi68 Well-Known Member
    David
    Kalaheo, HI
    2010 Tacoma Ext Cab 4x4
    complete Long Travel Suspension built by DMZ: 3+ Control Arms by TC, Bed Cage, Denver Under Springs, Fox all around (Coilover & Bypass up Frt, 3.0 Bypass Rr). Full Glass front fenders and bedsides. Engine so far: TRD CAI, DT Headers, URD Y Pipe, Gibson Muffler. And a Sprint Booster. Sits on Toyo OC 35x12.5 on 17’s. Nitro Rear end and re-geared for 35’s (4.56). Goals: Flowed Heads, Cams, and Boost (SC) ! So far, so good
    Right On DanaPT !!!
    Sooo pumped for ya, you had some hurdles thrown in there at ya and ya made it across the finish line.
    cant wait to hear what ya think after a good sporty drive
    loving mine
    shoots
    DanaPtTaco likes this.
  2. Oct 14, 2020 at 8:40 PM
    #362
    DanaPtTaco
    DanaPtTaco Never-ending problems
    Thomas
    Orange County, CA
    07 ACLB Prerunner 4.0 AT
    Thank you! Gonna drive it for a bit then bleed the brakes again to fully clear the air from the lines. So far, it feels VERY different and I think once i do the pad bedding process it'll feel a lot better
    eljedi68[QUOTED] likes this.
  3. Oct 27, 2020 at 3:23 PM
    #363
    Hamishmartin47
    Hamishmartin47 Well-Known Member
    Icon Front & Rear Dakar Leafs Baja Designs S8 30'' & SAE Fogs Shittybilt 9500 Synthetic Arb Compressor Sound Deadened Sound system + Sub + Deck Custom Bed Drawer System Skid Plates
    Can anyone confirm the part number for the calliper that will fit on second gen Tacoma???? What I have is #47730-60300 & #47750-6030? Trying to go OEM as I get a discount at the dealership.
    The 2017+ Calliper has a different part number therefor I question its fit.
    Thank you all!!! Any help would be appreciated.
  4. Oct 27, 2020 at 3:28 PM
    #364
    Hamishmartin47
    Can you confirm the part number for the calliper that will fit on second gen Tacoma???? What I have found is #47730-60300 & #47750-6030? Trying to go OEM as I get a discount at the dealership but dont want to get wrong one!!
    Thank you!!! Any more help would be appreciated.
  5. Oct 27, 2020 at 3:51 PM
    #365
    DanaPtTaco
    Thomas
    Orange County, CA
    Those are the same part numbers as mine so I think ur good, as long as it has the 14WA stamped on it
    eljedi68 likes this.
  6. Oct 27, 2020 at 9:36 PM
    #366
    eljedi68
    David
    Kalaheo, HI
    Yep,, them are the #’s
    14WA is the 4’Runner upgrade (Bigger)
    13WA is a stock Tacoma
    shoots
    nudavinci64[OP] likes this.
  7. Oct 27, 2020 at 10:21 PM
    #367
    nudavinci64
    nudavinci64 [OP] Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    I will add that to the first page. i thought I had them. Yes the newer 2016+ the holes for the bolts are larger I believe. I have heard one person who sleeved it but much easier to just get the 14WA setup.
  8. Oct 27, 2020 at 10:46 PM
    #368
    nudavinci64
    Robert
    Ok may be it was 2017 then. When I first did it it was 2010-2015. Good to know 2016 works.
    eljedi68 and DanaPtTaco[QUOTED] like this.
  9. Oct 28, 2020 at 9:35 AM
    #369
    Hamishmartin47
    Thank you guys!!!
    Appreciate your help & quick responses!!
  10. Oct 28, 2020 at 7:43 PM
    #370
    eljedi68
    David
    Kalaheo, HI
    Right on !
  11. Oct 29, 2020 at 8:17 PM
    #371
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    14WB vs 14WA. Same same, 12mm vs 14mm caliper mounting holes is your part number difference. You are looking for 14WA for bolt up. 14WB is current and will require sleeving. Not a big deal but most people don’t really do mods on brakes. I sleeved mine just fine and made a thread forever lost in cyberspace that nobody will ever read. Good luck.
  12. Oct 30, 2020 at 12:25 AM
    #372
    nudavinci64
    Robert
    14WB requires sleeving not 14WA but yes I recall from your setup if you go 14WB it will work but you need to sleeve it. 14WA is plug and play. Link or send me your thread I will link it if people want to go with the later calipers. It comes way enough.
    eljedi68 and zippsub9[QUOTED] like this.
  13. Oct 30, 2020 at 2:53 AM
    #373
    zippsub9
    Halfmoon, NY
    14 DCLB
  14. Oct 30, 2020 at 10:28 AM
    #374
    eljedi68
    David
    Kalaheo, HI
    I’m loving this BBK so much on my Taco: looks, and incredible smooth stopping performance... I’m seriously thinking about upgrading the rear-end to the 4Runner disk set up (w/Stop Tech rotors of course). Mostly for the look performance wise, but I’m sure you’d feel the difference as well... maybe even add a Wammy Bar style rear break for dirt power slides
    pumped so many TW tacos are upgrading
    shoots
  15. Oct 30, 2020 at 12:14 PM
    #375
    nudavinci64
    Robert
    I have a rear kit I have yet to install. Depends on what you have. The non Off Road/Pro you can also upgrade the master. For the Off Road/Pro you cant but so far folks that have it seem solid. I will get around to it at some point.
  16. Oct 30, 2020 at 7:03 PM
    #376
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Do you have stock master cylinder? What did you notice in terms of pedal feel, amount of effort needed?
  17. Oct 30, 2020 at 8:56 PM
    #377
    eljedi68
    David
    Kalaheo, HI
    So far so good. I’m running the stock master cylinder (with pains of upgrading to the Stop Tech one). But seriously, so far I’m kind of thinking no need unless I convert to Disks in the rear.
    right from the first test drive with the BBK,, my brake pedal felt amazing. Perfect amount of firmness and control. And of course, the best part: no more Pulsing you’d feel as you come to a stop
    love it !
    EdgemanVA likes this.
  18. Nov 3, 2020 at 11:10 PM
    #378
    Hamishmartin47
    I ordered this: #47730-60300 part number, opened box and it is 14WB.
    Is it as simple as sleeving the hardware and calling it good? If i tried to return it for the 14WA I'd be paying a restocking fee.
    In sleeving this, do I run more of a risk in any way? Is it worth the restocking fee to have the whole bolt threaded?
    Thanks guys
  19. Nov 3, 2020 at 11:15 PM
    #379
    nudavinci64
    Robert
    That is what @zippsub9 did with this from what I recall.
    I am really curious how we can differentiate. Most places have a 2010-2015 and 2016+ should be different. Need to look into this from one of the Toyota parts folks I know.
  20. Nov 3, 2020 at 11:54 PM
    #380
    DanaPtTaco
    Thomas
    Orange County, CA
    That’s odd that it’s a 14WB instead of 14WA. My part numbers from rock auto are the same as what @Hamishmartin47 said but he had different calipers I guess? Here’s a pic of my order, not sure why there is a difference. For clarification, I received the 14WA and hamish received the 14WB even though they are the same part numbers on rock auto apparently.749CE24A-7C32-4F0A-A2C5-42099DFEF897.jpg
