COMPLETED 5th Gen 4Runner BBK upgrade for 2nd Gen Tacomas
Discussion in 'Technical Chat' started by nudavinci64, Aug 4, 2017.
  1. Feb 22, 2018 at 12:16 PM
    #41
    NiGelTRD
    NiGelTRD Tacoma Rocks!
    San Diego, CA
    09 TRD Sport Silver Mica Double Cab LB PreRunner
    Nothing yet!
    Hi all,
    Time to do my brake (upgrade) since the current rotors are warped, I'm gathering the necessary parts from this thread. One thing I may have either missed or couldn't find but what is the torque spec for the hub? Thanks in advance.
    Tony
    tacoma16 likes this.
  2. Feb 22, 2018 at 12:47 PM
    #42
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    https://www.tacomaworld.com/threads...lete-wheel-bearing-assemblies-bolt-in.288282/
    the 4 bolts get torqued to 55 ft/lbs and the cv nut get 173 ft/lbs
  3. Feb 22, 2018 at 1:05 PM
    #43
    NiGelTRD
    San Diego, CA
    Nothing yet!
    tacoma16[QUOTED] likes this.
  4. Mar 16, 2018 at 5:57 PM
    #44
    roary_tubbs
    roary_tubbs Active Member
    Oklahoma City, OK
    2011 White Toyota Tacoma TRD
    This is a great write up, thank you so much! I’m about to embark on a similar adventure. I’m assuming you bought 4Runner and not Tacoma rotors, right? Could you provide a link to where you got them? Also, a link for the 4Runner calipers?
    I was a little confused on your write up on the parts & their numbers.
    Thanks in advance.
  5. Mar 17, 2018 at 7:51 PM
    #45
    tazmoe
    tazmoe Member
    With the upgraded rotor size - whats the minimum size rim needed to fit? 15 inch?
  6. Mar 17, 2018 at 7:56 PM
    #46
    NiGelTRD
    San Diego, CA
    Nothing yet!
    Not sure if you're going this route but I chose Toyota parts except calipers from TRDPARTS.COM
    43512-60191 - 4Runner Rotor - LEFT
    1 $55.07 $55.07
    43512-60191 - 4Runner Rotor - RIGHT
    1 $55.07 $55.07
    47781-60140 - 4Runner Splash shield - RIGHT
    1 $47.33 $47.33
    47782-60140 - 4Runner Splash shield - LEFT
    1 $47.33 $47.33
    04465-60320 - 4Runner Brake pads
    1 $42.12 $42.12
  7. Mar 18, 2018 at 10:45 AM
    #47
    roary_tubbs
    Oklahoma City, OK
    Thanks. What calipers did you end up going with?
  8. Mar 18, 2018 at 11:06 AM
    #48
    ThreeMan
    ThreeMan Opinions Vary...
    Oswego, NY
    08 4x4 V6 TRD DCLB
    King Remote Resi Suspension - Total Chaos UCAs - Full Katzkin Leather - Leer Camper Shell - Custom Projector Halo Headlights - HID Fogs - Eagle Eye LED tail lights - Rigid Industries LED Light Bar Mounted in Bumper - Wade In-channel Vent Visors - K&N Filter - 20% on the fronts - Dakar Progressive Leafs - Fuel Beast Wheels wrapped in Hankook Dynapro ATMs - 4 Tie Down Mod - Pop N Lock - Billet Grille - Weathertech Mats - LED Map and Dome Lights - Optima Yellow Top - Redline Elite Hood Struts - Tunes: Eclipse 7100 HU - Eclipse IPC-106 Interface - Audison LRX 5.1K - Hertz Mille MLK2 Components - JL 13TW5 - JL cables and wires - Fully Deadened with SDS products - Metra dash kit - Custom Sub Box and Amp Rack - Still Under Construction.
    Nice write up.
    It's on my list.
  9. Mar 18, 2018 at 5:43 PM
    #49
    NiGelTRD
    San Diego, CA
    Nothing yet!
    You're welcome. I ended using re-manufactured from O'reilly.
  10. Mar 18, 2018 at 5:57 PM
    #50
    roary_tubbs
    Oklahoma City, OK
    Could you by chance provide a link or part number to your rotors, calipers and pads, please?
  11. Mar 18, 2018 at 11:13 PM
    #51
    4x4Taco09
    4x4Taco09 Well-Known Member
    Dane
    Louisiana
    09 TRD Sport 4x4 BSP DC LB
    Kings, Deavers, Brute Force, Prinsu, Lights, all the stuff
    The calipers I bought on eBay from a wrecked T4R. The brake pads I ordered on eBay for a 2015 T4R as well as the StopTech Slotted rotors. This was the cheapest route I found
    #51
    roary_tubbs[QUOTED] and tacoma16 like this.
  12. Mar 19, 2018 at 8:00 AM
    #52
    roary_tubbs
    Oklahoma City, OK
    Awesome, thanks! I'm pretty new to all the lingo around here. I'm assuming TR4 means TRD 4Runner? Which is helpful because I was trying to figure out which model I needed the calipers and rotors for. It looks like these would be the right calipers - http://www.trdparts.com/2016-4Runner-TRD-Pro-Brake-Components-s/26076.htm
    #52
  13. Mar 19, 2018 at 4:07 PM
    #53
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
  14. Mar 28, 2018 at 9:39 AM
    #54
    4x4Taco09
    Dane
    Louisiana
    Yes, you want 2015+ 4Runner components. That’s what I run
    I’m debating on doing that rear disc conversion, but it’s like $1000
  15. Mar 28, 2018 at 9:40 AM
    #55
    4x4Taco09
    Dane
    Louisiana
  16. Mar 28, 2018 at 10:03 AM
    #56
    nudavinci64
    nudavinci64 [OP] Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    It’s actually 2010+ 4 runner 5th gen. I heard with the 2015 they changed the bolts size so may I’ve issues. This I’m not 100% but 2010-2014 no issues.. It needs to be the 14WA stamped calipers. I’ll add some info around this in the beginning as it’s a recurring topic.
  17. Mar 28, 2018 at 10:06 AM
    #57
    nudavinci64
    Robert
    I would also as posted look for remanufactured calipers. Save you a ton. If you buy new I would look at an actual stoptech kit.
  18. Mar 28, 2018 at 1:08 PM
    #58
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    From my priceing it was $100 difference between getting new and remanufactured.
    So the 2010+ are still good to use then. Just don’t use the 2015?
  19. Mar 28, 2018 at 1:24 PM
    #59
    nudavinci64
    Robert
    Ok the site above they are $285 each. You can get a pair for less than that. The whole package should cost $400-$600 depending how you source parts. Just make sure it’s the 14WA caliper which is 2010-2014 for sure. I think 2015+ May be the same as the Lx calipers and the bolt changed.
    Calipers are $62 each side. Save you way more than $100.
    https://www.partsgeek.com/catalog/2010/toyota/4runner/brake/brake_caliper.html
    Also I believe 4Runner and Tacoma use the same pads.
    steveh_2007 likes this.
  20. Mar 28, 2018 at 4:43 PM
    #60
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Keep in mind I’m in Canada. Some don’t ship my way and shipping usually kills the price. I’ll check out the link above. Thanks!
