COMPLETED 5th Gen 4Runner BBK upgrade for 2nd Gen Tacomas
Discussion in 'Technical Chat' started by nudavinci64, Aug 4, 2017.
  1. Nov 3, 2018 at 4:59 PM
    #121
    nudavinci64
    nudavinci64 [OP] Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    I replaced with the 4runner dust shield.
  2. Nov 3, 2018 at 7:37 PM
    #122
    JaxJacket
    JaxJacket Well-Known Member
    2013 DCLB
    Larger piston in 14wa is going to take more pedal travel. Steel brakelines might give some of the slack back.
  3. Nov 5, 2018 at 5:36 PM
    #123
    gikser1278
    gikser1278 Member
    2007 indigo blue dclb
    3” rough country lift method wheels
    I did this upgrade as well and pressure bled the entire system multiple times with our brake flush machine to no avail. Wondering if theres a better matched master cylinder for this upgrade
  4. Nov 17, 2018 at 6:39 PM
    #124
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    @FadedComa here ya go even better than the Lexus set up!
    nudavinci64[OP] likes this.
  5. Nov 17, 2018 at 7:49 PM
    #125
    Bwthomas77
    Bwthomas77 Well-Known Member
    North Carolina
    12 dbl cab trd sport 6spd
    Supercharger, flowmaster exhaust, 4runner disc brakes, Volant CAI, ECGS bushing
    Also have a trd sport, 2012 though. Had spongy pedal after a good bleed also. Ended up being the shoes on the back (which I also replaced same time) were not dialed in enough, about 10-15 clicks later on each side it was fixed. The offroad I understand is a little trickier but the sport was pretty straightforward. Used a self bleeding canister which helped alot - especially since the wife was really over it after the hours this project took.
  6. Dec 5, 2018 at 9:52 PM
    #126
    nudavinci64
    Robert
    Curious if there is something else. I had no issues. Do you have a sport or off road? Curious if the folks with the electric booster have less issues. I had also planned to do the SOS conversion for kicks but I am unable to replace with the sequoia master due to the off road electric booster.
    I just rebuilt a caliper and bled all 4 brakes again and it helps a bit. Did you bleed the master by the way?
  7. Dec 5, 2018 at 9:53 PM
    #127
    nudavinci64
    Robert
    ah that would make sense on the rear. The off road once you figure out how to bleed is super easy. It pretty much does the work for you. have not really played with the rear but from a bleeding standpoint super easy.
  8. Dec 31, 2018 at 9:28 AM
    #128
    roary_tubbs
    roary_tubbs Active Member
    Oklahoma City, OK
    2011 White Toyota Tacoma TRD
    Just did this upgrade and ran into a few snags along the way.
    1. Removing the hard brake lines was a bit cumbersome, the connections closest to the truck bed are a pain to get to.
    2. Removing the hubs was pretty time consuming.
    3. I also had to run and get a 35mm socket for the nut.
    I am noticing some brake drag though. Did anyone else run into similar issues afterwards? Curious what I need to do to get rid of it.
  9. Dec 31, 2018 at 11:57 AM
    #129
    nudavinci64
    Robert
    What do you mean by brake drag? Also the hub is 35 not 36 although it seems to work still. And yah those rear lines are a PIA.
  10. Dec 31, 2018 at 4:04 PM
    #130
    roary_tubbs
    Oklahoma City, OK
    You are right, 35mm. I updated my post. What I mean by brake drag... when I come to a stop or take off the brakes feel like they do not fully release instantly. Like there is a big of a "lag". I've read somewhere it could be from too much brake fluid in the reservoir or brake pads being to tight with shims. Although I did not use any shims.
  11. Dec 31, 2018 at 11:12 PM
    #131
    nudavinci64
    Robert
    Ah gotcha. What pads did you use? I have stock pads right now. I did hear using say EBC the shims make it too tight.
  12. Jan 2, 2019 at 1:29 PM
    #132
    roary_tubbs
    Oklahoma City, OK
    I used the EBC greenstuff pads. I did not use any shims, I only used the "baffles" that they provide. Maybe I just need to grease the pins that go into the pads and calipers more.
  13. Jan 2, 2019 at 1:36 PM
    #133
    nudavinci64
    Robert
    That may help. I recently just popped mine out and did that. Check to make sure you do not have a seized pistons. If ones sticking that could cause some pulling or possible dragging.
  14. Jan 21, 2019 at 12:24 PM
    #134
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    Just to clear it up for everyone. The tacoma wheels will not fit with the 4Runner calipers. For the same reason you can not put tacoma wheels onto a 4Runner. The factory tacoma offset is 30mm and the T4R offset is 15mm. And that is also why the aftermarket wheels have no issues, they are mainly a 0mm offset. So it is not the too big around it is the too thick that is the issue. So yes, spacers will fix the issue.
  15. Jan 22, 2019 at 7:31 AM
    #135
    DNahas
    DNahas Well-Known Member
    Dallas
    09 DC 4x4 OR
  16. Feb 10, 2019 at 2:22 PM
    #136
    jstanley
    jstanley Well-Known Member
    Central TX
    2013 TRD Sport 4x4 Pyrite Mica.
    OTT, OME, Dakar, Eaton rear locker, camper shell, Konig Six Shooters and 33" Wildpeak tires, Pelfreybilt front bumper and skids
    Anyone found a master cylinder that gives a firmer pedal feel/less pedal travel with a TRD Sport? Ready to do this upgrade but must have a better pedal feel than I have now so want to upgrade the master cylinder too. Already have SS lines installed, can't say it made any difference.
    That Power Stop kit price looks tempting but I think I'd prefer factory parts.
  17. Feb 20, 2019 at 11:05 AM
    #137
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    Here ya go
  18. Feb 23, 2019 at 1:19 AM
    #138
    nudavinci64
    Robert
    check out SOS performance. the sequoia master swaps with the sport models.
    YamaDirtrider likes this.
  19. Feb 23, 2019 at 5:48 AM
    #139
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    Anything swap with the sr5?
  20. Feb 23, 2019 at 8:13 AM
    #140
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    The tundra brake booster then TrailToys makes an adapter plate to put a bigger GM master cycl on it.
