COMPLETED 5th Gen 4Runner BBK upgrade for 2nd Gen Tacomas
Discussion in 'Technical Chat' started by nudavinci64, Aug 4, 2017.
  1. Feb 23, 2019 at 1:46 PM
    #141
    nudavinci64
    nudavinci64 [OP] Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    The sequoia master should swap direct with all models but off road/pro
    As long as you run 17” wheels you can do this swap.
  2. Feb 23, 2019 at 2:53 PM
    #142
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    O, the brake swap was done quite a while back. I was just curious about the master cylinder.
  3. Feb 23, 2019 at 4:43 PM
    #143
    nudavinci64
    Robert
    Ah ok, the sequoia is plug and play for the most part. Not sure if it will make a difference but they reccomend this when folks add Theie rear disc setup.
    https://sosperformance.com/products/2005-2008-master-cylinder-kit
    TacoFMS[QUOTED] likes this.
  4. Feb 23, 2019 at 8:13 PM
    #144
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    Have you come across anyone that just sells the adapter plate? 170 is steep for that little plate
  5. Feb 27, 2019 at 4:03 PM
    #145
    jstanley
    jstanley Well-Known Member
    Central TX
    2013 TRD Sport 4x4 Pyrite Mica.
    OTT, OME, Dakar, Eaton rear locker, camper shell, Konig Six Shooters and 33" Wildpeak tires, Pelfreybilt front bumper and skids
    Not doing a rear disk swap, just want a firmer feel/less travel than with the stock master cylinder when I do the 4-runner front brake swap onto my '13 Sport.
  6. Feb 27, 2019 at 4:12 PM
    #146
    nudavinci64
    Robert
    Add stainless lines. Going to a bigger madter won’t always give you a firmer feel. If I find it. another lost that went work a bigger setup and reverted back.
  7. Feb 28, 2019 at 9:21 AM
    #147
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    after doing a little bit of online research, stock Tacoma (2005+, Non Off-Road) Master cylinder is 13/16" bore, single reservoir, uses 2 holes for mounting to booster, and has M12 x 1.0 brake line fittings. Toyota Tundra (2006+) has a 1" bore, single reservoir, 2 holes for mounting, and M12 x 1.0 brake line fittings. It would appear at first glance this would be a simple improvement to move more fluid with the same stroke length to the larger brake caliper volume needed.
    EDIT: no beuno for direct replacement. mounting holes are 90 degrees opposite, ports on opposite side.
  8. Mar 18, 2019 at 10:11 AM
    #148
    09TRDSport4x4
    09TRDSport4x4 OCD Approved!
    Nick
    Southwest Ohio
    I’m putting together a list of parts needed to do this to my 2009 Tacoma TRD sport. I’m using the OEM 17” Sport wheels but I have 1.25” spacers installed and based on what I’ve read, this should fit. Can anyone confirm that before I pull the trigger?
    Also, other than a set of stainless front lines, does the below list include everything I’ll need to do the 5th Gen upgrade on my truck?
    NAPA Eclipse Calipers (14 WA cast)
    $96.49 EA + $16.67 core
    L caliper (SE6830)
    R caliper (SE6829)
    OEM Part Numbers:
    #04465-60320 - Front Brake Pad Set
    #00475-1BF03 - OEM Brake Fluid
    #43512-60191 - Brake Rotor x2
    #47781-60140 - Backing Plate
    #47782-60140 - Backing Plate
  9. Mar 18, 2019 at 10:39 AM
    #149
    jstanley
    Central TX
    09TRDSport, add Napa part# UP 83106A, brake hardware kit when you get the calipers. The T4R calipers are wider so the pad holding pins are longer. Most parts stores don't stock them, found out the hard way, but got lucky at O'Reillys.
    steveh_2007 likes this.
  10. Mar 18, 2019 at 11:18 AM
    #150
    09TRDSport4x4
    Nick
    Southwest Ohio
    Added it to the list and to my cart. Thanks for the heads up!
  11. Mar 19, 2019 at 12:03 AM
    #151
    nudavinci64
    Robert
    not 100% on the spacers but based on aftermarket offsets should be fine. 1.25 puts you right around some common aftermarket setups.
  12. Mar 19, 2019 at 6:49 AM
    #152
    09TRDSport4x4
    Nick
    Southwest Ohio
    Yeah, I’m effectively running a 17x7.5 inch wheel with a -2 offset with the spacers installed.
    And this is what makes it hard for me to decide between 4th and 5th Gen T4R parts... I know the 4th Gen setup will fit but it sounds like I’d be hoping the 5th Gen setup fits with spacers. And if the 4th Gen calipers didn’t have issues with seizing I’d probably have already bought them. I just have no desire or need to change my wheels and want to make sure I get something that will work with the stock 17” setup.
  13. Mar 19, 2019 at 10:13 AM
    #153
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    The factory Tacoma wheels will fit the 5th gen calipers with the spacers. The difference in factory wheel offset is for the brake calipers. Tacoma has a 30mm offset and 4Runner has a 15mm offset. So all you need is 15mm but they are much harder to come by. Probably have to have them built by BORA and then you would have to make sure the wheels you are running have the recessions in the mounting surface to allow for the factory stud to have room to protrude into the mounting surface of the wheel.
  14. Mar 19, 2019 at 10:21 AM
    #154
    09TRDSport4x4
    Nick
    Southwest Ohio
    Ok, that makes me feel better. I already have the spacers installed and I’d rather use the 5th Gen parts for roughly the same cost as the 4th Gen setup. I’ll order the parts and post results when I’m done!
  15. Mar 19, 2019 at 10:21 AM
    #155
    mr.trd
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Did you get the Napa Eclipse SE6830 & SE6829? The pictures and description say that they come with the hardware.
  16. Mar 19, 2019 at 10:23 AM
    #156
    09TRDSport4x4
    Nick
    Southwest Ohio
    Those are the two part numbers I have in my cart. I don’t mind spending the extra $10 on hardware, just in case. I’d rather order everything and have too many parts than not enough.
    steveh_2007 and mr.trd like this.
  17. Mar 19, 2019 at 10:26 AM
    #157
    mr.trd
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    MY50cal likes this.
  18. Mar 19, 2019 at 12:43 PM
    #158
    09TRDSport4x4
    Nick
    Southwest Ohio
    I added the hard brake lines and swapped the TRD pads in my cart from my local Toyota dealer. Ordering those online then picking the parts up just down the street from work saves me money versus having things shipped to the house. Now I just need to buy all the parts. Still haven’t found stainless lines though. Don’t really need extended and can’t seem to find stock length anywhere. The closest I’ve found are 2” longer than stock...
  19. Mar 19, 2019 at 12:48 PM
    #159
    09TRDSport4x4
    Nick
    Southwest Ohio
    Looks like my total cost with the more expensive TRD pads is going to be around $580 minus the core charges to NAPA. I was budgeting $550 so that’s in the ballpark. I’ll just need to find some stainless lines and pickup some brake fluid.
  20. Mar 20, 2019 at 2:10 PM
    #160
    KCTaco77
    KCTaco77 Well-Known Member
    Kansas City
    2011 Tacoma 4X4
    3" Lift, AMP Running Boards and tailgate step, ANZO head and tail lights.
    Do you know if the stock Tacoma hard brake lines will work with the upgraded calipers, or did you just replace them for safe measure?
