Complex vibration question???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 10trdtaco, Aug 6, 2016.
  1. Aug 7, 2016 at 8:24 AM
    AKdude007
    AKdude007 The mountains are calling and I must go
    EAFB
    2007 Tacoma TRD Off-road
    Vision X Light Bars KB Voodoo Bed Rack Tuff Stuff 4x4 RTT
    I had this last year. It was my wheel bearing. If you are mechanically minded, do it yourself. A local shop wanted $800 to do both right and left. I just did it myself and had a local place press the new hub assembly together for $15. There are plenty of how to' for this. I think it is a fairly common issue.
    10trdtaco[OP] likes this.
  2. Aug 7, 2016 at 8:43 AM
    10trdtaco
    10trdtaco [OP] American Infidel *DON'T TREAD ON ME*
    Shayne
    Lynchburg, VA
    2010 Tacoma TRD Sport DCSB
    4" lift 33-12.50-17 Atturo Trail Blade M/T 17" HELO TRD Satoshi Blackout Grill Tinted headlights with caliraised led headlights ... More to come
    I think I can get them pre-pressed? Is that correct?
  3. Aug 7, 2016 at 8:48 AM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
  4. Aug 7, 2016 at 8:59 AM
    AKdude007
    EAFB
    DaveInDenver[QUOTED] likes this.
  5. Aug 7, 2016 at 9:02 AM
    AKdude007
    EAFB
    This is the how to article I used
    DaveInDenver likes this.
  6. Aug 7, 2016 at 11:15 AM
    10trdtaco
    Shayne
    Lynchburg, VA
    Don't those ones that you linked come pre-pressed?
  7. Aug 7, 2016 at 11:46 AM
    ManBeast
    ManBeast Well Feared Member
    Zach
    Orange Park FL
    2015 DCLB:TOTALED-> 2014 4R TRAIL
    Zipties so you dont waste an expensive adhesive mount
  8. Aug 7, 2016 at 1:42 PM
    nickj604
    nickj604 Well-Known Member
    Nick
    Vancouver BC
    2019 RAM 1500
    To be announced
    Just out of curiosity have you checked your tires to make sure they are balanced. Could you have thrown your wheel weights off ?
  9. Aug 7, 2016 at 4:27 PM
    10trdtaco
    Shayne
    Lynchburg, VA
    It was just balanced and aligned ... New tires ... I'm taking it to a shop tomorrow to have it investigated further! Will inform on what they say ... Zip ties are a good idea! If they don't find anything tomorrow, on goes the GoPro lol
  10. Aug 8, 2016 at 12:36 PM
    10trdtaco
    Shayne
    Lynchburg, VA
    Took it in to have it looked at, all bearings, tie rods, ... Everything is solid ... Tires are being rebalanced as I post ... If that doesn't fix it, I'm kinda out of ideas lol ...
  11. Aug 8, 2016 at 2:55 PM
    10trdtaco
    Shayne
    Lynchburg, VA
    Well vibration still there balanced and aligned, everything is right in all the suspension and steering components ... I'm out of ideas lol, the guy said mud tires always ride bad ... I've had plenty of 33" mud tires and they don't vibrate like this ... So there is something else going on
    Components checked:
    Hub bearing
    Wheel bearing
    Up and lower control arms
    Tie rods
    Front track bar
    Steering rack
    Tires (balanced twice to be sure, and put the best balanced one on the front)
    Alignment was good ...
  12. Aug 8, 2016 at 5:15 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Are your wheels hub centric or lug centric? Lug centric wheels require a hub centric ring to make sure they aren't traveling in an ellipse.
  13. Aug 8, 2016 at 5:19 PM
    10trdtaco
    Shayne
    Lynchburg, VA
    I have no idea ... How would I tell? Lol
  14. Aug 8, 2016 at 5:24 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Being lifted could be a axle shaft. I would move one of the back wheels to the front and see if goes away. Also, road force balancing maybe necessary.
  15. Aug 8, 2016 at 5:26 PM
    #35
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Hub centric wheels fit like a glove on the hub - oem wheels will all be like this. Aftermarket wheels are often sold to fit multiple styles of hubs eg Chevy and Toyota have the same lug pattern, but their hubs are different diameters. To save on cost aftermarket wheel manufacturers will produce the wheels with an opening big enough to accommodate any conceivable hub size. To make sure that the wheel is traveling in a circle they make rings that fill the gap between the opening for the hub to pass through in the wheel and the hub.
  16. Aug 8, 2016 at 5:30 PM
    #36
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Here's an example: https://www.ecstuning.com/b-ecs-par...-YhOeO9gT1oPhF7E82hbplAXqIa82qHZDTxoCU4Xw_wcB
    But the vibes could be from the lift too. It seems like it could be wheel related if it vibrates differently than it did before once your wheels are mounted again (i.e. If your not getting vibes when turning in different directions each time you mount the wheels or if the turning thing stops working) - a lot of people do get drive shaft vibes from lifting though.
  17. Aug 8, 2016 at 5:47 PM
    #37
    10trdtaco
    Shayne
    Lynchburg, VA
    Did move one of the rears forward and nothing either ... What is road force balancing?
  18. Aug 8, 2016 at 5:53 PM
    #38
    10trdtaco
    Shayne
    Lynchburg, VA
    If the wheels were the issue, wouldn't all the wheels be doing the same thing? And even when I switch tires and wheels to the front right from other areas of the car, it still is the vibration in the front right ... So I think it's isolated no matter what tire or wheels is up there ??? How do I check the axle to see if it's bad? I'm sure the tech would have checked that today to rule all of it out, but I can look if there are any ideas or questions about the axels!
  19. Aug 8, 2016 at 6:01 PM
    #39
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    Could still be wheel bearing. I had same symptoms on my 2005 Tacoma. Had 2 shops tell me wheel bearings were fine. No play at all. Changed them anyway and vibration was gone.
  20. Aug 8, 2016 at 6:15 PM
    #40
    10trdtaco
    Shayne
    Lynchburg, VA
    I just don't want to start throwing parts at it ... But I am really out of other ideas, so I may just need to replace the wheel bearing and get it over with ... Sound like a logical place to start???
