componant speakers crossover location?
Discussion in 'Audio & Video' started by polox40, Feb 4, 2010.
  1. Feb 4, 2010 at 4:01 PM
    polox40
    polox40 [OP] Well-Known Member
    ONTARIO
    TRD SPORT 4X4
    TOYOTA ALUMINUM STEP BAR, 3M HOOD FILM, WEATHERTECH FLOOR MATS, 7" DD WITH BACKUP CAMERA, TRD SEAT COVERS
    For all you guys who have replaced front speakers , where did you put the crossover?
    mine are in the mail , was told to not install them in the doors.
    no biggie to wire run new wire as i might want to install a amp in the future so i could loop the wires to one of the cubby's behind the seat for future.
    just curious on your opinions.
  2. Feb 4, 2010 at 5:58 PM
    RTaylor
    RTaylor Active Member
    Arkansas
    08 Tacoma TRD Sport
    Run new wire. You can put them in the doors but it is not a good idea, plus toyota makes it easy to run wire to the door.
  3. Feb 4, 2010 at 6:24 PM
    zanodave
    zanodave Well-Known Member
    so il
    07speedwayblue
    back wall with amp rack
  4. Feb 4, 2010 at 6:48 PM
    uglygun
    uglygun Well-Known Member
    With the exception of the plastic runner along the door sill, I'd like to know where you ran your wires through the cab to the doors.
    Looked up under there and it is a tight fit trying to get to the rubber grommet/tubing that runs to the door. Did you remove a bunch of the dash to gain access to it or just cuss and bitch while trying to do it blind?
    In a weekend or two I've gotta run some wire off my front stage amp to the door speakers and I'm not looking forward to it.
  5. Feb 4, 2010 at 6:57 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i put my cross overs in a plastic ziplock bag, and used 3m tape and put them on the inside of the door.(cut some of the back out of the bag.)
  6. Feb 4, 2010 at 7:02 PM
    sooner07
    sooner07 1/2 man 1/2 amazing
    A A Ron
    DFW, Texas
    Debadged 2008 Rugged Trail
    Toytec ultimate lift kit, light racing UCAs, ARB bumper and full skid plates underneath. Looking into redoing the suspension and maybe repainting the ol' Taco.
    I put mine underneath the driver's seat.
  7. Feb 4, 2010 at 7:05 PM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Toytec TRD PRO LIFT with 1.5 SAW in rear, 255 Coopers, Baja Rack, Southern Style Front Bumper, Warn Wireless Winch, DeMello Sliders.
    i put mine in the doors as well, almost a year no problems.
  8. Feb 4, 2010 at 9:52 PM
    ilovetacos
    ilovetacos Well-Known Member
    Gavin
    Sacramento/Woodland
    2006 TRD Sport 4x4 DC
    Sold!
    Put mine on my amp rack...I can easily adjust them if needed.
    Key-Rei likes this.
  9. Feb 5, 2010 at 7:53 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    I managed to squeeze my JL Audio XR crossovers in the front kick panels and rear panels.
    techbill likes this.
  10. Feb 5, 2010 at 3:55 PM
    polox40
    ONTARIO
    TRD SPORT 4X4
    I really like that look , did you add that piece of mdf to the left side there?, on ********* they dont show that, you also had to remouve the plastic cover on the back of the seat? i use that quit a lot
  11. Feb 6, 2010 at 11:56 AM
    dreamnz
    dreamnz Well-Known Member
    SoCal
    PreRunner
    Suspension: Camburg Spindles, Bilstein 5100s, Deaver Leafs, BFGs Audio: IDQ 10 in "Marv" box - Hybrid Audio L6 mid bass/ L4 mids / L1 ProSE tweets - RF Power / Arc Amps...BitOne.1 to control it all.
    Ya, if you're going to add an amp later anyways then take the time to run new wires to the back wall. Further, I'd run the amp wires back there at the same time while you've got all the plastic runners and such removed. Obviously, just don't wire to the battery yet. You'll be prepped and ready to go for expansion later.
    I removed all the plastic from the rear of mine and built a simple amp rack myself. I've done everything carefully so that I can put it all back to stock if I ever want to.
    And today, there are no passive crossovers anyways... :D
    azsean likes this.
  12. Feb 6, 2010 at 1:14 PM
    ilovetacos
    Gavin
    Sacramento/Woodland
    Sold!
    Yeah, I built that piece myself using MDF and attached it to the ********* box.
    I had the plastic removed at first but I also need to use the back of the seat at times so I cut a hole in the shape of the sub because it was rubbing when the seat was all the way folded down.
    In this pic the sub was rubbing the seat but I have since moved the box back a good 1" and have no more rubbing.
  13. Feb 6, 2010 at 2:04 PM
    polox40
    ONTARIO
    TRD SPORT 4X4
    Nice thanks!!
  14. Jul 20, 2016 at 9:03 AM
    azsean
    azsean Well-Known Member
    sean
    HELL ... aka mesa,arizona
    2013 black prerunner trd sport
    gosh.. where do I start, 18x9’s on 275-65 ridge grapplers. Bilsteins, clazzio leather, audio consists of stereo integrity,fosgate power amps,sundown audio, hybrid audio. Plus more...
    looks awesome !!! i have a similar set up with fosgate amps and HAT. was it a huge difference once u went with the audison?
  15. Jul 21, 2016 at 6:10 PM
    jkcashin
    jkcashin Well-Known Member
    Jamie
    Ottawa, Ontario, Canada
    2017 TRD OR AC MT
    OP, you were told not to install them in the doors... I wonder why? That's where I had planned to put mine...but now I am re-thinking.
  16. Jul 22, 2016 at 5:10 AM
    rob feature
    rob feature Tacos!
    Colorado
    2003 4x4 V6 X-Cab SR5
    Shocks. Pegs. Lucky.
    More moisture in the doors than inside the cabin. Plus repeated opening and closing the doors subjects them to excessive forces.
    jkcashin[QUOTED] likes this.
  17. Jul 22, 2016 at 5:33 AM
    timothom
    timothom Well-Known Member
    2014 Tacoma Access cab sr5
    Kenwood DMX7705S PrecisionPower Phantom 900.4 Alpine type-r 8" Image Dyanmics CXS64.2
    I squeezed them under the drivers seat right by my amp. Also ran all wiring from amp to xOver to speakers. No problems, no regrets
  18. Jul 22, 2016 at 5:39 PM
    TreeFortRichard
    TreeFortRichard Barcelona Red is the best red...
    Brian
    42.3115167,-71.6638516
    '23 SR5 DCSB 4x4 Barcelona Red
    Well since this is a 6 year old thread...Probably anyone who put them in the doors 6 years ago can let us know if they've had any moisture issues :)
    jkcashin likes this.
  19. Jul 22, 2016 at 8:13 PM
    jkcashin
    Jamie
    2017 TRD OR AC MT
    You're brilliant.
  20. Jul 22, 2016 at 8:18 PM
    rob feature
    rob feature Tacos!
    Colorado
    There was a thread in here a week or 2 ago where someone had a Kicker crossover in a door go tits up.
