Component Speaker Question
Discussion in 'Audio & Video' started by A_Ninja_Racer, Dec 16, 2008.
  1. Dec 16, 2008 at 6:47 PM
    A_Ninja_Racer
    A_Ninja_Racer [OP] Well-Known Member
    Tampa, FL
    08 PreRunner TRD Debadged
    Real quick question guys. Where are you installing the crossovers for your component speakers. I have an access cab and I'm looking to do component 6.5's for both front and back. I'm not planning on a sub just yet because I want to keep things clean and I like my center console.
  2. Dec 16, 2008 at 7:03 PM
    atsaubrey
    atsaubrey Dealer/Sales Rep for Sundown Audio.
    california
    blue 2007 double cab
    Sundown Audio 100.4 and 1500D, Pioneer 880PRS, Zapco Refernece 6.5" comps, 2 10" Image Dynamics IDQ, 200ft of Second Skin deadener, Kicker wire
    Personally I would go into the kick panels for passive xovers.
  3. Dec 16, 2008 at 7:06 PM
    A_Ninja_Racer
    Tampa, FL
    Have you done this? Is there enough space?
  4. Dec 16, 2008 at 7:09 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    there is plenty of space. from a pic I saw a guy had speakers recessed into the kick pannels, it looked badass
  5. Dec 16, 2008 at 7:17 PM
    EquinsuOcha
    EquinsuOcha Bourbon
    Casey
    Ft Worth, TX
    07 PreRunner
    AFE Drop-in filter, Wet Okole seat covers, Hifonics 6.5" components in front, MA Audio midbasses in rear, Kicker 8", RE Audio 2 channel for components, Elemental Designs bridged 2-channel for sub, CB, Devil Horns, Rancho QuickLift, Rancho RS9000XL rear shocks, Toytec AAL, stickers, things and stuff.
    Zip-tied right above the kick panels.
  6. Dec 16, 2008 at 7:19 PM
    A_Ninja_Racer
    Tampa, FL
    What about the rears?
  7. Dec 16, 2008 at 7:48 PM
    Pre08
    Pre08 Well-Known Member
    Alpharetta, GA
    SR5, 4X4, V6, 6Sp, DC
    best place to mountthem IMO would be next to the amp! It's just a little extra speaker wire and if you need to trouble shoot they are right their!
  8. Dec 17, 2008 at 2:37 PM
    EquinsuOcha
    EquinsuOcha Bourbon
    Casey
    Ft Worth, TX
    07 PreRunner
    Good question. I never thought of putting components back there.
    I will tell you that there is plenty of room to mount anything under that rear door panel if you don't feel like running a lot of wire.
    Just shooting out ideas here, but maybe you could get some sheet metal screws and just attach them to the inner door itself. The window doesn't open, so you don't need to worry much about water, but the vibration may knock some shit loose after awhile.
    I'm no professional, just trying to get some ideas out there.
  9. Dec 17, 2008 at 3:08 PM
    81shark
    81shark Well-Known Member
    2006 Base Access CP1
    i zip tied my front crossovers into the doors. the only downside is you can't adjust em once you put the door back together.
  10. Dec 17, 2008 at 7:01 PM
    atsaubrey
    california
    There is room in the kickpanels. As far as the doors go, they can go in there no problem but 99% of the xovers I have seen after say 2 years are rusted up and damaged do to moisture. I mention kick panel because they can be accesed very quickly in the Taco and out of danger of water and well protected and hidden.
  11. Dec 17, 2008 at 7:04 PM
    A_Ninja_Racer
    Tampa, FL
    See now that makes since. I will have to take a closer look at those kick pannels.
