Component Speaker Replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 14SportTRD81, Apr 27, 2019.
  1. Apr 27, 2019 at 3:18 AM
    14SportTRD81
    14SportTRD81 [OP] New Member
    Paul David
    14 TRD
    None
    What's up guys, first posting on Tacoma World so thanks for letting me be a part of this...I'm looking to replace my factory component speakers in my 14 Tacoma access cab. I wanna save myself a headache and have everything I need for when I do the install. Should I get the speaker wire harness? speaker adapters? go with a crossover mounting pair or one with a crossover built in? recommendations on speakers? I am gonna keep my factory head unit and I will add an amp, not sure about a sub just yet but if I do it will be a low profile one that I can save space with and has an amp built in. Please, any feed back will be greatly appreciated!
  2. Apr 27, 2019 at 3:50 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    2013 Super White Tacoma DCLB TRD SPORT
    Changing the headunit will yield better results than replacing the speakers with factory headunit. In my experience it did. :)
    BillDaCat8 likes this.
  3. Apr 27, 2019 at 4:19 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 300+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    ^^^ what he said. I was shocked to hear what a new head unit did for these crappy speakers in my truck.
  4. Apr 27, 2019 at 4:42 AM
    TegoTaco
    Ontario, Canada
    I was actually really impressed with the OEM speakers with an aftermarket headunit. :)
  5. Apr 27, 2019 at 4:49 AM
    Larzzzz
    Larry
    MA
    Ikr... Channel separation. Something that was not existent with the stock hu.
  6. Apr 27, 2019 at 6:41 AM
    fb40dash5
    fb40dash5 Well-Known Member
    People's Republic of MD
    11 V6 AC 4x4
    Just about the 1st thing I did when I bought this one was to pull my Alpine HU and mini-amp out of my old one and install it.
    I haven't felt the need to buy speakers yet, in fact I kinda want to pull the door panels just to make sure it still has factory speakers and the PO hadn't upgraded. For only having 2 speakers it's damn decent, and if they are in fact OE (I suspect they are) they've got to be the least crappy base factory speakers I've heard.
    Skyway likes this.
  7. Apr 27, 2019 at 6:48 AM
    Minimag95
    Minimag95 Well-Known Member
    Niles
    Annapolis, MD
    2009 Pyrite Mica V6 SR5 4x4
    OME Nitros, 887 Coils, AAl, SPC LR UCA's, 285 St Maxx
    I agree HU or amp will make give you the most bang for the buck improvement, BUT if it were me I would also look into some of the inexpensive speaker upgrades. The stock speakers suck ass but once you pull them out you'll realize the sound is rather remarkable for how crappy they are. Cones are paper thin and magnets are tiny. A lot of folks on here are doing the Subaru tweeter upgrade for cheap.
  8. Apr 27, 2019 at 6:57 AM
    Bikinaz
    Bikinaz The Thread Killer
    Hey You
    Phoenix, AZ
    2014 Regular Cab 4x4 5MT
    Toytec Lift. FN Five Stars. Sliders. Cruise Control. Intermittent Wipers. Fog Lights.
    I thought I read that the Subaru tweeter upgrade only works on 3rd gens? If this is a go on the 2nd gens I may just have to get busy based on all the positive reviews. I've been mulling over speaker upgrades for months and just can't make a decision. I do know that I'd really like to keep the factory HU, just because I like the factory look.
  9. Apr 27, 2019 at 7:04 AM
    Minimag95
    Niles
    Annapolis, MD
    I'm not extremely familiar with that upgrade, but I'm sure you can make it work on a 2nd gen. Some others may know more about it than me. When I did mine I went with JL audio speakers which required adapters. Here is my thread with my setup. I will say that if you want to keep your head unit, an external amp will serve you well.
    https://www.tacomaworld.com/threads/complete-sound-system-in-my-2nd-gen.597101/
    Bikinaz likes this.
  10. Apr 27, 2019 at 7:13 AM
    Bikinaz
    Hey You
    Phoenix, AZ
    I agree about the amp. Of course the only thing I've made a firm decision on is a small compact amp and low cost sound deadening. Which amp is still up in the air, but I'm going with a couple rolls of the Peel and Seal for sound deadening.
    https://www.lowes.com/pd/Peel-Seal-...s-6-in-x-25-ft-Aluminum-Roll-Flashing/1018733
  11. Apr 27, 2019 at 7:25 AM
    TegoTaco
    Ontario, Canada
    I think I went 6 months without replacing the speakers, I only did it because I was installing a sub/amp. :)
  12. Apr 27, 2019 at 11:31 AM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    I replaced the speakers first and had sound deadening added to the doors. I had an amp added at the same time.
    I think replacing the crappy speakers is the best improvement. Later I will consider replacing the head unit.
    Norton and dthomps like this.
  13. Apr 28, 2019 at 4:19 AM
    14SportTRD81
    Paul David
    14 TRD
    None
    your sound system looks incredible, excellent job! thanks for the feed back
  14. Apr 28, 2019 at 4:54 AM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    I just replaced my speakers yesterday. And i have to agree the stock speakers aren’t bad. But there not clear. I bought all the adapters and harness extention . Went with kicker dc series. Sounds much cleaner now. But i also recommend getting some sound deadening for the doors it was a huge improvement on the doors. You don’t have to spend alot of money. I bought the 36 square feet 80mil off Amazon for $64 dollars. It damn nearly covered the whole truck. Doing the back wall and doors . A few peices under the floor matts and a few spots under the storage area under the rear seats. I also have the sony xav-100 great radio with Apple CarPlay and it has DSO which makes the speakers sound like there higher up on the doors
  15. Apr 28, 2019 at 8:24 AM
    glazer1972
    glazer1972 Well-Known Member
    05 Tacoma PreRunner Double Cab 4.0L
    The speakers in my 05 sound quite good after a new head unit.
    14SportTRD81 [OP] likes this.
  16. Apr 28, 2019 at 1:13 PM
    dthomps
    dthomps New Member
    Doug
    2013 Tacoma Prerunner
    2017 TRD Wheels
    Speaker upgrade a must. Take a look at factory speakers and you will see. I replaced my speakers and what a difference. Crutchfield is a great source for what speakers will fit and have the part number's for all the accessories needed. I later added an amplifier and under seat powdered sub woofer.
    Norton likes this.
  17. Apr 29, 2019 at 8:42 AM
    TegoTaco
    Ontario, Canada
    Is 50 sq/ft enough for a double cab? Mainly doors and the rear storage behind the seats.
  18. Apr 29, 2019 at 10:43 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; Cooper Discoverer A/T3s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; mattgecko's Underhood Lighting; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I found a number of threads on this and similar topics when looking to upgrade the sound in my AC. The Audio & Video forum is a good place to start. Crutchfield is a good place to get an idea of what's available/suitable. Armed with that info, visit a (couple of) local shop(s) to listen to various combos. (In the end, it's about what sounds good to you, rather than what anyone else used.) Narrow your choices and buy from where you get the best "bang for your buck." FWIW, I went with the following, which I think sounds great...
    - AudioControl LC2i Line Out Converter
    - JL Audio XD200/2v2 Amp
    - Focal PS165V1 Speakers
    - Sound Ordnance B-8PTD Sub
    - Hushmat & Noico Liner Sound Insulation
    I pulled most interior panels and the carpet, in addition to door panels, when I did mine...
    Unless money is burning a hole in your pocket, comparison shop! I got all my stuff for an average of 40% off MSRP.
  19. Apr 29, 2019 at 1:06 PM
    TACOMA2NDGEN
    ROLAND
    new jersey
    baja squadron pros
    More than enough
  20. Apr 29, 2019 at 2:30 PM
    Capt. Obvious
    Capt. Obvious Fearless Keyboard Warrior
    Darrick
    Seattle
    '12 DCLB TRD
    6" body lift, LEDs errwhere, Jesus mural on the hood
    I highly recommend NOT using that stuff for sound deadening. The adhesive isn't the same as an automotive sound deadener and that stuff will stink when it gets hot. Look up Noico sound deadener on Amazon if you're looking for a budget alternative. It's what I used in my truck and it's a great product.
    Here's my budget stereo build for another point of reference for options:
    https://www.tacomaworld.com/threads/my-budget-friendly-stereo-upgrade.496080/
    ZRXDean and Norton like this.
