Composit bed, is there steel under the floor? How do I attach a tool box?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ERdept, Aug 31, 2008.
  1. Aug 31, 2008 at 10:46 PM
    ERdept
    ERdept [OP] Well-Known Member
    I now will get a tool box that will fit into the bed, inside the shell.
    It has to be anchored to the bed by drilling holes in the bed to attach the box..
    On the Taco, is the bottom steel?
    How does one attach a tool box to the bed?
  2. Aug 31, 2008 at 10:56 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    There should be steel under the bed if not were F$#cked, lol what kind of tool box you getting?
  3. Aug 31, 2008 at 10:59 PM
    ERdept
    I'm getting one of those aluminum diamond plated ones that will fit inside the bed with the shell on.
    I notice many people just throw stuff into their shell and think some thin plastic window will secure it.
    So I want stuff to be locked inside the shell for extra security or when I'm kidnapping someone. :eek: That's was a joke.
  4. Aug 31, 2008 at 11:04 PM
    SocalMan22
    Steve-0
    So*Cal
    What Mods!
    lol i hear ya on the kidnapping i mean security. what site you looking at? or do you have one in mind
  5. Aug 31, 2008 at 11:47 PM
    ERdept
  6. Aug 31, 2008 at 11:58 PM
    SocalMan22
    Steve-0
    So*Cal
    What Mods!
  7. Sep 1, 2008 at 12:21 AM
    ERdept
    I see you got Revos. How are you liking them?
  8. Sep 1, 2008 at 12:28 AM
    EquinsuOcha
    EquinsuOcha Bourbon
    Casey
    Ft Worth, TX
    07 PreRunner
    AFE Drop-in filter, Wet Okole seat covers, Hifonics 6.5" components in front, MA Audio midbasses in rear, Kicker 8", RE Audio 2 channel for components, Elemental Designs bridged 2-channel for sub, CB, Devil Horns, Rancho QuickLift, Rancho RS9000XL rear shocks, Toytec AAL, stickers, things and stuff.
    To my knowledge, there is no steel underfloor. The points at which I mounted my light bar, were all composite.
  9. Sep 1, 2008 at 1:51 AM
    ERdept
    OK, so how do you attach and secure a tool box to the bed?
  10. Sep 1, 2008 at 1:58 AM
    EquinsuOcha
    EquinsuOcha Bourbon
    Casey
    Ft Worth, TX
    07 PreRunner
    Maybe bolt 'er on down with some big washers underneath? I'm not sure. I'm sure someone who has a toolbox like the one you want will chime in soon enough. :thumbsup:
  11. Sep 1, 2008 at 6:40 AM
    ERdept
  12. Sep 1, 2008 at 6:41 AM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    I drilled two holes in the box, dead center lined up, then placed the box squared everything and drilled two holes in the bed. I used two stainless steel bolts with nuts.
    A word of advice.....if do-able put a thin layer of plastic/rubber, like that found in Craftsman roll tool boxes on the floor, and the back side (if you put it all the way back). If not the slight movement will mark the bed.
    The two bolts for me held great, with no movement, but then I had a few items in it that made it heavy.
    Sorry no pic's of install, or set up, this was before I found this GREAT place.
  13. Sep 1, 2008 at 6:41 AM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Which box are you getting?
  14. Sep 1, 2008 at 6:46 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    What the others have said. Bolts and some large washers and you will be set. :)
  15. Sep 1, 2008 at 8:58 AM
    ERdept
    Alright. Thats it.
    Plan is to put down the rubber mat, Drill through the box, mat and bed, 1/2 inch. Use very large washers (2inches?) in diameter, then seal with either spray on undercoat or silicone.
    You guys are phucking brilliant.
  16. Sep 1, 2008 at 11:53 AM
    Rich8419
    Rich8419 Well-Known Member
    Louisiana
    2009 Dbl Cab Short Bed Offroad Pkg
    weathertech floor liners, scan guage, gatekeeper
    That's what I did. However I didn't use silicon. No issue with water here. Might try to find some felt washers later if it becomes a problem.
    Rich
