Computer help
Discussion in 'Technology' started by drifter379, Aug 22, 2009.
  1. Aug 22, 2009 at 1:50 AM
    drifter379
    drifter379 [OP] CenTex Honky
    Texas
    06 Tacoma SR5 Prerunner
    Secondary Air filter mod,Removed running boards,AFE Pro dry filter,sirius satelite radio,relocated horns,sockmonkey decal,EZ change drain plug,color matched grille,grille craft mx, BHLM, Fog light mod, Hellas behind the grille
    My computer is starting to bog pretty bad. I think I might have caught a little something. I have already run disk defrag. Any good free anitvirus and anti spy ware you can suggest?
  2. Aug 22, 2009 at 5:06 AM
    Gatoral65
    Gatoral65 Member
    Alan
    Maine
    09 DC SB SR5
    None yet...
    AVG for anti-virus and Ad-aware and or Spybot for spyware. All can be found on download.com or via google search. I use them all the time. Good luck!
  3. Aug 22, 2009 at 5:39 AM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    What he said. I use CNET.com for free software. Biggest problem with googling software. Sometimes it looks like you are getting the software you googled, when in fact you are getting something else. Or it is a version you have to buy. Plus CNET has reviews from users like you.
    Another good one is malwarebytes.
    http://download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html?tag=mncol
    Another thing you may want to consider. Upgrade your ram(memory). In todays time, webpages are more of a memory hog than even 2 years ago. Plus with added highspeed internet you may not be getting the full performance, if your PC can't keep up. The common misconception is that people think you need a bigger processor or new PC. When in fact if you bump your memory up it will do more good than a bigger processor or new PC.
  4. Aug 22, 2009 at 5:59 AM
    Gatoral65
    Gatoral65 Member
    Alan
    Maine
    09 DC SB SR5
    None yet...
    Yeah that is a good point, knowing the source you are downloading from is generally a good idea. Same with memory upgrades.. it can make a pretty significant difference, and is shouldn't be too expensive either.
  5. Aug 22, 2009 at 5:59 PM
    HwyRogue
    HwyRogue Resident Canuck
    Halifax, Canada
    2007 TRD Sport 4x4
    Arctic bull bar, hitch step, side bars (All by Avid Off Road!), BHLM, eye lids....
    Get yourself the comodo internet suite (free firewall, antivirus and monitors your background). AVG is also a free one (mentioned earlier), so is s-squared...
    Download spybot S&D, install it - let it scan your system during the next boot up;
    Download the Eusing registry cleaner and run it;
    Every time you install software, your registry is written to, even if you un-install the s/w, it doesn't remove everything from the pc, including cleanup of the registry. If you install/uninstall a lot of programs, the boot up will take longer as windows still searches the paths from the registry.
    If you install a lot of programs, your pc will also be sluggish because of the preload of programs during startup (check the bottom right had side of the screen, the more icons, the more crap pre-loads). You can clean a lot of that junk up and increase your speed.
    How much ram do you have?
  6. Aug 22, 2009 at 6:00 PM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    +1 for AVG running it for over a year now and no problems... use limewire too
  7. Aug 22, 2009 at 7:51 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    I have a Mac, so I don't have to deal with AV software. :D
    But when I had a PC, I used CCleaner all the time. :)
  8. Aug 22, 2009 at 7:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Ummm.....I know a guy that did this....without useing a pen to stop the fan from spinning. I...cough....He......Was impressed by how fast the fan would spool up with 130 psi air......Think anything bad came from it? You know....So I can ...cough....let him know??? :anonymous:
  9. Aug 23, 2009 at 4:02 PM
    genxer36
    Sean
    Bethlehem,GA
    I hear frostwire is safer & better. I downloaded it recently, much faster than Limewire.
  10. Aug 23, 2009 at 4:06 PM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    2014 Sierra All Terrain
    AVG Free af http://filehippo.com - way better than download.com as there speeds are slow.
    Also try going to trendmicro and doing a houscall online scan
    malware bytes is a very good one
    and so is ad-aware.
    plus I would suggest go to start-run-msconfig
    and removing anything from the start up that you do not need, this will increase your performance a lot
  11. Aug 23, 2009 at 4:06 PM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    none of these programs are safe they are all equally as bad you should be torrenting not peer to peering
  12. Aug 23, 2009 at 5:47 PM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven, WV
    2021 Cement Grey Off Road
    Stock
    avg ftw!
  13. Aug 23, 2009 at 5:54 PM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    Yeah I work at an ISP, now this is in canada and I dont know how it works in the us, but when they send you that message saying they know what you donwloaded they are basically saying we know you did it and we cant do shit about it. The ISP I work for gets these messages all the time and we are supposed to let out subscribers know about it. We dont tho we just ignore them cause there is no law sayig we have to and there is no law broken.
    If you just use private trackers, aka private torrent sites such as torrentleech and bitsoup.org you cannot get caught cause it is not a public tracker.
  14. Aug 23, 2009 at 6:07 PM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    sucks to have that isp then, thats why i only use private trackers
