Computer Virus! HELP!!!
Discussion in 'Technology' started by BigBawlzTaco, Dec 17, 2009.
  1. Dec 17, 2009 at 6:40 PM
    BigBawlzTaco
    BigBawlzTaco [OP] Well-Known Member
    2019 Toyota Tacoma SR
    My computer will turn on. and it will go to the windows xp loading screen. and after it's done loading, the cursor appears but everything else is black. What should I do?
    I cannot lose the files I have on there! :eek:
    EDIT: Im on my moms computer right now.
  2. Dec 17, 2009 at 6:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Dont surf porn without an firewall, and good anti virus.
  3. Dec 17, 2009 at 6:44 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  4. Dec 17, 2009 at 6:45 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    get a mac?
  5. Dec 17, 2009 at 6:46 PM
    BigBawlzTaco
    Anything else?
  6. Dec 17, 2009 at 6:47 PM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    20 Gladiator Rubicon
    Steersmarts Draglink, Tie rod, Track Bar
    Will it load in safe mode?
  7. Dec 17, 2009 at 6:53 PM
    oofy15354
    oofy15354 Proud Tundra *****
    Dave
    Massachusetts
    Herculiner, Access Tonneau, Uniden cb, firestik antennae, Bosch Wipers, JVC Ipod headunit, Boston Acoustic Speakers
    I had this exact problem not 2 months ago. You have a bad sector on your hard drive and your only option is to reformat which may or may not fix the bad sector. This was likely caused by a crash or something else that caused the computer to not shut down properly and some invalid piece of data was saved.
    reformatting will erase all your data and you will have to start fresh. if you really want to save some stuff, download ubuntu and make a boot CD (plenty of guides on this). start ubuntu but dont install it then open up your main hard drive and transfer whatever you want to a USB drive or external Hard drive.
    if you want, you can use the disk checker (or whatever its called) to see that you have a bad sector.
    WARNING: ubuntu will most likely save some random file type that only it can read, causing the device to not work under windows. once you have windows reinstalled, check to see if the USB or External HDD will function or if theres an error. if so, you will have to go back into ubuntu and drag your files into a place you can find in windows. You will then have to format that drive in order for it to work again.
    and obviously, ubuntu will need to be made on another computer
  8. Dec 17, 2009 at 6:53 PM
    CATCHIT
    CATCHIT Well-Known Member
    TRD Sport
    I'll take it to Best Buy, they might be able to hep you, they can get some files off your computer even if if does not start up.
  9. Dec 17, 2009 at 6:56 PM
    oofy15354
    Dave
    Massachusetts
    also, try safe mode first. if not, wait for the black startup screen that comes up after an unsuccessful boot and choose to launch startup repair. i doubt either of these will work but its worth a shot. also, if you made any restore points, try going back to those. i was dumb and assumed id never need them
  10. Dec 17, 2009 at 6:57 PM
    MTgirl
    Weesa
    Bob's secret mod lair
  11. Dec 17, 2009 at 6:58 PM
    FullDub
    FullDub Member
    09-TRD Sport 4x4
    Get a MACCCC!!!
