Condensation
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ecotecin, Sep 6, 2014.
  1. Sep 6, 2014 at 5:51 PM
    ecotecin
    ecotecin [OP] Wait, whut........
    WV
    2014 DCSB sold (2020 Chevy Silverado Crew Cab)
    I have a 2014 DCSB and it seems that im getting alot of condensation on the inside of my windows in my truck. I know its been kinda humid, but its like when you leave one window cracked and it rains, it makes moisture gather on the windows. Well mine is doing that, but im not leaving any windows down or anything, its just collecting moisture inside the windows.
    Is there anyone elase having this issue, if so, how have you stopped it?
  2. Sep 6, 2014 at 6:01 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    I use the defrost setting to clear the windshield when it happens.
    You may want to check for a damp floor/carpet on the passenger side for leaks from the windshield or air conditioning drain.
  3. Sep 6, 2014 at 6:14 PM
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    ...wet lungs
  4. Sep 6, 2014 at 6:28 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Do you have the a/c set to "MAX" all the time? If so, turn the temp knob up 1 spot to shut off "MAX". This will allow fresh air into the cabin, where as the "MAX" setting recirculates the same air causing the humidity to climb. It's really not meant to be used all the time.
  5. Sep 6, 2014 at 6:46 PM
    Flowin
    Flowin Well-Known Member
    Acworth, Georgia
    2014 DCSB TRD OFF ROAD
    OME 3" lift, 265/75/16 KO2s, 35% tint
    Had the same problem at the beginning, after cleaning the windshield 100x it is gone. There was some kind of film on there from the factory
  6. Sep 7, 2014 at 4:13 AM
    ecotecin
    WV
    I use the max setting, but not all the time. I roll the windows down alot as well. It only seems to happen after its been parked a while. Its kind of aggrevating ya know. I dont want moisture building up inside my vehicle all the time. This is the first vehicle i have ever owned that done this, all the other ones never have done it. Thought it might have been window not sealing good or something. I just dont want it to eventually tear something up.
  7. Sep 7, 2014 at 4:50 AM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
  8. Sep 7, 2014 at 4:53 AM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    I have found on all my vehicles that starting out the defroster on a warm setting and slowing going down to the cool eliminates this problem.
  9. Sep 7, 2014 at 7:10 AM
    ecotecin
    WV
    These are all good replies, but my problem is happening when the truck hasnt been running. Like when i go to work, shut it off, work my shift, come back out and there condensation on the inside of the windows. And i cant seem to figure out exactly whats causing it. The windows arent cracked, the doors are shut, i dont have a rear sliding glass, shouldnt be having any condensation inside the truck. I park out in the sunshine all day, so i know its not a shade/sun issue.
  10. Sep 7, 2014 at 9:42 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Sounds like you might have some water in your truck to start with.....
    Start poking around your carpets & such...to check for water.
    This thread might interest you...
    http://www.tacomaworld.com/forum/2n...er-leak-expected-wtf-recall-oh-sorry-tsb.html
    Oh...but wait... 2014... TAKE it back to the dealer!! Have them look at it!!! You're still under warranty!
