confused about 5100s
Discussion in 'Suspension' started by 2k4Taco, Dec 18, 2011.
  1. Dec 18, 2011 at 3:00 PM
    2k4Taco
    2k4Taco [OP] IG: Swannybruh
    Swanny
    Fleming Island, Fl
    16 DC TRD Offroad 4x4
    Icon 2.5s / 2.0's / //Dakar HD Pack//CBI T3 Front/ ATH HC Rear//SPC UCAs/ Camburg LCAs// MR312s w/ 34in Yoko GeoLndrs
    Im probably gonna get some shit for this but whatever... ive heard so many different things about the billy 5100s.. some say you need aftermarket coils to get lift in the front and which setting to put it at to level the truck out....so what is it? can i level my truck out with stock coils and the 5100s?I just want to know before I commit to the buy. Thanks guys- Swanny.
  2. Dec 18, 2011 at 3:03 PM
    DrewH
    DrewH Well-Known Member
    Yes.
  3. Dec 18, 2011 at 3:06 PM
    dayNnite4
    dayNnite4 We can't stop here, this is bat country.
    Nick
    Southern NH
    '11 4x4 5-speed AC
    if u leave the 5100's at stock height of .85, u can use stock spring but if ur gonna set them at 1.75 or 2.5, then u need new springs. and i beleive 1.75 will level it out. not sure about that tho
  4. Dec 18, 2011 at 3:07 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    That's not true. 5100s are designed for use with the stock springs, at any height you set the shock to.
  5. Dec 18, 2011 at 3:07 PM
    sethr21785
    sethr21785 Well-Known Member
    Seth
    Lake Jackson TX
    00 Tundra
    that doesnt sound right. I have stock springs and mine are set at 1.75...
  6. Dec 18, 2011 at 3:09 PM
    2k4Taco
    Swanny
    Fleming Island, Fl
    See...lol... So what do I need to set them at to level the truck out? 1.75?
  7. Dec 18, 2011 at 3:09 PM
    mainewoodsballer
    mainewoodsballer YESSAHBUD...heyut
    Ol' Waltah
    Maine
    2015 DCLB TRD Sport (Pyrite Mica)
    Check out my Build to See!
    You can use the stock springs any setting you want
  8. Dec 18, 2011 at 3:10 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    That's how it is if you run them with OME 885 springs
  9. Dec 18, 2011 at 3:10 PM
    Maverick904
    Maverick904 Resident Fishing Expert
    Kameron
    Northeast Florida
    08 TRD Rugged Trail 4x4
    3" Procomp Lift, BDF Light Bar, Borla Stainless Cat-Back System, 2 10" Polk MM Subs, LED Interior Lighting, Pioneer Touch Screen, Kicker Speakers up front, Sonys in the back, Grillcraft grill, 20% tint, Weathertechs, Projector Retrofit Headlights. BHLM
    The 5100 springs are designed for use with stock coils. However the lift is achieved through spring preload thus making the ride rougher.
    However their are aftermarket coils that can be bought that do some lifting themselves and allow for either very little or no preload be used in order to achieve desired lift.
  10. Dec 18, 2011 at 3:10 PM
    TexasTacoma37
    When I set mine at 1.75" pre-tsb I was slightly nose-high.
  11. Dec 18, 2011 at 3:10 PM
    OZ-T
    Peter North
    British Columbia
    This ^
  12. Dec 18, 2011 at 3:13 PM
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
    This is not true....
    You can run the 5100's at any set up with the stock coils. The more lift you get, the more stiff the ride is going to be. Here is an example for you. This is my truck with just the TSB and my billies at 2.5.....I had a bit of a bro lean....
  13. Dec 18, 2011 at 3:13 PM
    2k4Taco
    Swanny
    Fleming Island, Fl
    What's tsb?
  14. Dec 18, 2011 at 3:15 PM
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
    TSB, Technical Service Bulletin...This
  15. Dec 18, 2011 at 3:17 PM
    bgsmith
    bgsmith Well-Known Member
    Brian
    Hingham, MA
    06 Speedway Blue TRD Sport 4x4 DCSB
    ATX Mojaves with 265/75 16 Hankook Dynapro ATMs, Spidertrax 1.25" spacers (front and rear), Bilstein 5100 all around up front set at 1.75", Blacked out badges, Pioneer AVIC D3 DVD/NAV Head Unit, K&N Air Filter, Tyger Tri Fold Tonneau Cover, Rockford Fosgate Punch Speakers.
    Pretty much a recall where Toyota would replace the stock 3 leaf pack with a 4 leaf back due to bottoming out when heavy loads are in the bed.
    I have my 5100s set at 1.75 with stock springs, no TSB or issues, truck is level.
  16. Dec 18, 2011 at 3:25 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    If you use aftermarket coils that provide lift you should set the shocks at .85 max based on recommendations by vendors. Anymore is not safe for the shock.
    If you are using stock coils or after market coils that do not provide any lift then you can set the shock at .85, 1.75 or 2.5 but as you increase height it compresses the springs and the ride becomes stiffer. Most choose .85 or 1.75 but some do run 2.5 and are ok with the ride.
    If you are looking for more than 1.75 in lift you are better off going with aftermarket coils that provide lift by a longer coil since it will ride better.
    Max lift is about 3-3.5 inches if you use a aftermarket lift coil and set the shock to .85.
    There is also another variable called a top plate spacer. This goes on top of the setup and adds more lift. 1/2" plate is typically the max.
    As stated to level out a stock truck with or without updated TSB springs they choose 1.75 some like a raked vehicle which is lower in the front and choose .85 mainly without the TSB springs.
    Purchase from downsouth motorsports for the best price. They are in the vendors section of the forum. There is a discount code in the sticky section of their vendor page.
  17. Dec 18, 2011 at 3:30 PM
    lj973gm
    Ohio
    06 DCSB 4wd
    Take most of this back since you have a 2004 tacoma.
    I am a second gen guy so disregard what I posted. The heights and TSB springs do not apply the same to a first gen.
    Someone else with a 1st gen will chime in soon
  18. Dec 18, 2011 at 3:32 PM
    2k4Taco
    Swanny
    Fleming Island, Fl
    So pretty much there's a recall for leaf packs with 3 leafs to the 4 leaf? Bare with my guys I used to own a dodge...lol
  19. Dec 18, 2011 at 3:37 PM
    OZ-T
    Peter North
    British Columbia
    No
    A TSB is not a recall
    A TSB informs the techs about a reoccurring issue , and how they can fix it .
    You need to go to the dealer and complain / prove that you have the issue to get it fixed under warranty .
    I also just noticed you have a 2004 , the leaf spring TSB is for 2005-2012 Tacomas only .
  20. Dec 18, 2011 at 3:38 PM
    2k4Taco
    Swanny
    Fleming Island, Fl
    I have a three leaf pack with what looks like a helper leaf... So do i qualify for the recall? That would help bc my rear leafs look like a slightly sad face....
