Confused about the locking rear diff and crawl
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TheSharksDen, Apr 28, 2019.
  1. Apr 28, 2019 at 4:09 PM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    Kudos for getting your truck into that. Kinda jealous
    Skydvrr and uploadadventure like this.
  2. Apr 28, 2019 at 4:55 PM
    WiscoPat
    WiscoPat One does not simply purchase a Ridgeline
    Pat
    Wisconsin
    2019 TRDOR Tacoma 1995 JDM 80 Series
    Mall Rated
    Crawl control is best for crawling up hilly and/or rocky terrain, possibly in deep sand too (from my understanding).
    Mud is one of those obstacles that needs momentum and lots of wheelspin to keep your lugs clean, imo; also making sure your traction control is completely off, which 4 low should do for you automatically. 4 low, second gear, and higher rpm will be your friend!
    But yea, that looks a bit deep regardless. Good learning experience.
    JNG likes this.
  3. Apr 28, 2019 at 4:57 PM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    Just a few points.
    In crawl, all wheels will turn roughly together, however they go rather slow in all crawl control speeds, so I would bet you might not see it or realize it is turning. (also keep in mind that the system requires enough brake friction to hold the opposite wheel. I don't know if brakes filled with mud will generate enough friction)
    For OR automatic models, in 4Lo the truck defaults to NO traction control so in effect just open diffs are the default. Rear locker will correct that in the rear, but you will need to use MTS to give simulated locker in the front (or crawl control).
    Note, this is different behavior than the other trims.
    (more detail here https://www.tacomaworld.com/threads/3rd-gen-traction-control-modes-explained.530695/)
  4. Apr 28, 2019 at 8:41 PM
    ferntr33
    ferntr33 Well-Known Member
    Did the dudes trying to winch you out let enough line out? I don’t remember the math but too much spooled line decreases your pulling power. Glad you didn’t break anything when getting pulled out.
  5. Apr 28, 2019 at 8:49 PM
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    Whew. Congrats on getting your truck buried! That’s impressive.
    TheSharksDen[OP] likes this.
  6. Apr 28, 2019 at 8:55 PM
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Detriot locker rear ARB air locker front 4.56 gears OME 3" lift, SPC uca's , moto metal 951 wheels 315/75/r16 Treadwright guard dogs, homemade front plate bumper with smittybilt 9.5k winch, homemade skids, homemade Bed bars, Mobtown offroad high clearance rear bumper with tire carrier, Homemade rock sliders , U-bolt flip, Wheeler's super bumps, BORA 1" wheel spacers , Black headlight mod , black tail lights, Satoshi Grill , autoPage C3 RS-665 alarm with remote start, flowmaster 40 series exhaust, cruise control,bed/ground effect lights, wet okole seat covers, tinted,windows, weather tech floor mats, AVS vent shades, debadged, hidden cobra 19 cb, 7" offroad lights behind grill, rear diff breather relocate, abs kill switch
    :rofl::rofl::rofl:
    Crawl control
    OP you want wheel speed and make it rain mud
    4hi traction control off has always worked for me
    TheSharksDen[OP] and JNG like this.
  7. Apr 28, 2019 at 9:03 PM
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    And all the people that are saying nothing could make it through that or you found the limits of the truck are wrong. That's a baby puddle. If a Ram made it through you should have too. You just did it wrong
  8. Apr 28, 2019 at 9:09 PM
    tcjacado
    tcjacado Well-Known Member
    Math is roughly..... if you have half the line spooled, the winch is half the rated power/weight. At least that's what I remember reading.
  9. Apr 28, 2019 at 9:11 PM
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    this is for an 8,000 lbs winch
    Layer 1 – 8000lbs.
    Layer 2 – 6777lbs.
    Layer 3 – L5878lbs.
    Layer 4 – 5189lbs.
  10. Apr 28, 2019 at 9:12 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    The design of mud tires is to clear mud at high speeds. The mud is flung out of the tread by centrifugal force. If you get mired and there is no traction, crawl or MTS or locker is not going to help.
    If I had to go through that bog hole, I would have hit it with more speed and aired down to give you a longer tread contact patch and more flotation. The Ram likely benefited from larger tires.
  11. Apr 28, 2019 at 9:15 PM
    tcjacado
    Stock wrangler with kevlar suck in the mud.
    3000 rpm in 3rd gear doing 25 to 30 mph on flats and little down hills, Aired down to 18 psi going up hill was more like 10mph sometimes to less than 5mph. Like the truck was on ice. Knew if I stopped, it wasn't going to move forward again.
    2wd problems.
  12. Apr 28, 2019 at 9:20 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    First wrap is 100% of the winches pulling power, each wrap after decreases the power but increases the speed.
    Think 2nd wrap is 84% and 3rd wrap is 73% winch capacity.
  13. Apr 28, 2019 at 9:23 PM
    Kodachrome
    Kodachrome Well-Known Member
    Western Colorado
    2005 Taco, 2024 Audi SQ8 ETron
    TRD S/C, URD...Stuff
    Do your truck a favor and check your airbox and filter. I have seen people hydrolock their motors in goo only a bit deeper than that. It's rare with mud but it does happen.
    shakerhood likes this.
  14. Apr 28, 2019 at 9:23 PM
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    correct roughly 15% for each wrap
    OnHartung'sRoad and tcjacado like this.
  15. Apr 28, 2019 at 9:27 PM
    #35
    chrispchicken9
    chrispchicken9 Well-Known Member
    '04 3.4 tacoma, '16 4.0 4runner
    Haha this is awesome
    Only thing I can think of gettin thru that is big tires and lots of horse power
    TheSharksDen[OP], JNG and Stocklocker like this.
  16. Apr 28, 2019 at 9:27 PM
    #36
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    tcjacado likes this.
  17. Apr 28, 2019 at 9:28 PM
    #37
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    All the line out means the winch is pulling at 100% capacity and as has been mentioned , each wind of rope around the drum decreased the pulling power of the winch by 15% or so...each wrap. Spool our all the line, throw several snatch blocks in the loop and increase the capability but decrease the speed.
    Clearly he did find the limits of his capability and truck cause he called a tow.
    Not saying nothing could have made it through but he surely didn’t.
  18. Apr 28, 2019 at 9:28 PM
    #38
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    I wish we had that option
  19. Apr 28, 2019 at 9:30 PM
    #39
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    I agree he found his limits mainly because of experience but the truck can do so much more than that little baby puddle
  20. Apr 28, 2019 at 9:33 PM
    #40
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
