confused avh-p4400bh install with jbl tato
Discussion in 'Audio & Video' started by IslandBoy86, Apr 24, 2013.
  1. Apr 24, 2013 at 8:35 PM
    IslandBoy86
    IslandBoy86 [OP] Well-Known Member
    Las Vegas, NV
    As the title says...help me please....anyone have the actual wiring diagram? Am I suppose to splice into the original harness? Or are all the splicing done between the tato and aftermarket head unit harness?
  2. Apr 24, 2013 at 11:12 PM
    AZM9
    AZM9 Well-Known Member
    Jay
    Chandler, AZ
    2009 Prerunner TRD Sport
    ARE tonneau cover, Redline hood struts, Leaf TSB, and Trans TSB, Satoshi grille.
    Did you order the jbl harness from tacotunes. And don't forget the steering wheel interface. All these plug into the factory plugs and are color coded to splice in at the new head unit.
  3. Apr 25, 2013 at 5:53 AM
    IslandBoy86
    Las Vegas, NV
    I have the pac tato from crutchfield.
  4. Apr 25, 2013 at 3:54 PM
    Aw9d
    Aw9d That one guy
    Az
    You need to get the JBL stereo harness, its about 100$ if I remember.
    OR
    Cut your old harness and tap into it.
    If you don't know what you are doing I wouldn't suggest cutting the harness.
  5. Apr 25, 2013 at 3:55 PM
    Aw9d
    Aw9d That one guy
    Az
    OR
  6. Apr 25, 2013 at 4:08 PM
    IslandBoy86
    Las Vegas, NV
    ^^^ I thought that's what the pac tato harness is for?
  7. Apr 25, 2013 at 4:34 PM
    Aw9d
    Aw9d That one guy
    Az
    Sorry you are right.. I thought that was the steering wheel controls only as I didn't look it up.
    I don't use harnesses, I wire everything from a fuse block under the hood and use relays. I had the JBL and I refuse to pay that much for something I can build myself.
    So to answer your question the open ended wires on the Tato are the ones that will match up to the HU's wiring harness. Then all that plugs into the stock harness for the truck. The colors are typically universal but double check the manual just to be on the safe side.
    This should help so you know the color codes for each wire.
  8. Apr 25, 2013 at 4:45 PM
    PVT Pablo
    PVT Pablo Ultra Junior Member
    Paul
    Chesapeake, VA
    2016 4Runner TRD Pro
    ^^^ Am I crazy or does that say honda element??
    I just did that exact same install. You shouldn't have to splice anything if you have all the correct parts. You need the ASWC-1 if you have steering wheel controls. Then you need the PAC-TATO JBL wiring harness. Its a big black box with a shit load of wires coming out of it. Its all plug and play.
  9. Apr 26, 2013 at 7:31 AM
    Shaowei
    Shaowei Well-Known Member
    New Mexico
    05 Tacoma 4x4 LB
    It largely depends on how you're going to install the new HU. If you plan to reuse the JBL speakers/Amp/Sub you WILL need the JBL friendly harness. This is it:
    http://www.crutchfield.com/p_127TATO/PAC-Toyota-Factory-Integration-Adapter.html
    The free harness that comes from Crutchfield does not work with the JBL harness in the truck.
    If you're going to be running speakers off of an amp I would recommend just splicing into your factory harness. The wiring diagram can be found at Post #13 at:
    http://www.tacomaworld.com/forum/audio-video/28954-antenna-help-needed.html
  10. Apr 26, 2013 at 12:48 PM
    Aw9d
    Aw9d That one guy
    Az
    Yes its for an element, however the color of wires for the metra harness are universal and that's what I was referring too.
    He won't have to splice, but he does have to hook up the Pac to the new HU.
  11. Sep 3, 2013 at 6:54 PM
    RockyMtnTRD
    RockyMtnTRD Wanderlust.
    Noah
    Colorado
    '11 TRD OR
    hack job
    I realize this is probably an old thread.. :D
    So if you have the PAC TATO wiring harness from crutchfield you do not need the harness that comes standard? You just plug the PAC TATO into the stock plugs and the radio?
