Confused by ARB
Discussion in '2nd Gen. Tacomas (2005-2015)' started by EasTxTacoma, Jul 22, 2018.
  1. Jul 22, 2018 at 8:50 PM
    EasTxTacoma
    EasTxTacoma [OP] Member
    2014 Tacoma double cab 4x4
    Roadmaster active suspension system, adjustable Billstein shocks (2"+front), ARB front bumper, KC Hi-Lites, Warn M8000, 285 Toyo Open Country R/T's
    Wow, ARB's application guide is confusing. I know there are several threads on the topic but I am super paranoid about getting the correct part. The application guide says:
    RD111 for 3.91 and up ( I assume up as in higher gear and not numerically???)
    RD121 for 3.73 and down ( I assume down as in lower gear and again, not numerically?)
    Anyhow the dealer I bought my 2nd gen from tells me it is equipped with 4.11's and I want to get 4.88's and lockers. Has anybody gone through this before?
  2. Jul 22, 2018 at 8:56 PM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    Do you have a manual trans or a 4 cylinder? Pretty sure the autos in second gens are 3.73 in V6.
  3. Jul 22, 2018 at 9:02 PM
    EasTxTacoma
    I have an automatic with V6 (2014). Yokem Toyota in Shreveport told me I had 4.11's based on VIN.
  4. Jul 22, 2018 at 9:22 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    The higher the number the lower the gearset, and vice versa.
    ARB offers two part numbers because there is what is called a "brake" between gearsets which means that the mounting flange on the center section is in different places for the part # due to the thickness of the gearset.
    Like tacovrd said if you have a 4cyl, you have 4.11's if it's a v6 you have 3.73's.
    4.88's are a very low gearset, like for 35in and up tires.
    If your serious about regearing call ECGS and they will talk you thru your needs and what you should use.
  5. Jul 22, 2018 at 9:22 PM
    Bogg
    Bogg Well-Known Member
    Surrey, Canada
    07 TRD Sport 4x4
    Like TACOVRD stated, 2nd gen V6 trucks came with 3.73. The 4cyl came with 4.10s. I don't think they have a 4.11 for our trucks.
  6. Jul 22, 2018 at 9:25 PM
    EasTxTacoma
    Ok, who is ECGS?
  7. Jul 22, 2018 at 9:28 PM
    medic2230
    Murph
    Bama! Roll Tide
  8. Jul 22, 2018 at 9:40 PM
    EasTxTacoma
    Thanks
    medic2230 likes this.
