Connect shell window to cab?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoTuesday1, Apr 27, 2023.
  1. Apr 27, 2023 at 12:02 AM
    TacoTuesday1
    TacoTuesday1 [OP] Well-Known Member
    FL
    Is this a thing? Anyone done this?
    Looking at keeping propane to camp, but possibly in the cab, with a CO/Gas Alarm also in the cab. Fear is if the tank leaks in the cab I might not hear it camping in the bed with the window closed.
    Got me thinking; there has to be a way to connect the center opening window of the shell, to the sliding window of the cab. To leave it open as an air pass-through, but still cut off/insulated from outside cold air getting in
    looks like this guy has some kind on an ARE
  2. Apr 27, 2023 at 12:13 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
  3. Apr 27, 2023 at 12:35 AM
    TacoTuesday1
    FL
    I've heard there's one type that rubs the paint off with grit; I'd have to guess inflatable style is the one to do that
    vs other types like accordion rubber boots that I imagine could stick on with 3M VHB possibly installed from inside the shell, or also folding down the window to adhere it to the cab, if the shell has a fold down window
    I'll ask shell shops I know; surprised I never heard about it during install quotes that just went over lift it, slap some foam, wire the light
    could draw cold in; I guess that's the point for the windows to still be closeable. As shells are less insulated than cabs.
  4. Apr 27, 2023 at 5:20 AM
    Madd Matt
    Madd Matt Well-Known Member
    Between the Brandywines S.E. Penna.
    2015 Blue Tacoma TRD Sport 4.0 6 speed manual
    You could try a motorcycle or bicycle inner tube inflating it between the cab and topper shell.
    If paint rubbing is a concern just pull the valve stem deflate and remove when not in use.
  5. Apr 27, 2023 at 11:27 AM
    Shwaa
    Shwaa Well-Known Member
    Bay Area, CA
    '13 DC Prerunner TRD Off-Road
    The camper shell I had in the mid 90's, I think it was a Leer 100 R, had that boot there by default. I am not sure what year they stopped doing that.
  6. Apr 27, 2023 at 1:48 PM
    mojojojo78
    mojojojo78 Well-Known Member
    2007 Prerunner Access Cab SR5 V6 6 Speed Manual
    None... yet
  7. Apr 27, 2023 at 1:57 PM
    MAG GRY TACO15
    MAG GRY TACO15 Well-Known Member
    Alan
    GA
    '15 TRD Off-Road
    Same crap everyone else got
    I would try this. It just needs to go around the center window so a bike tire should do it.
  8. Apr 27, 2023 at 3:13 PM
    TacoTuesday1
    FL
    not sure if it has to be a fat bike tire or regular one
    If regular sounds quick cheap and simple to get that and a hand pump
    Maybe remove it off roading when dust kicks up
    or maybe if there’s room, gentle masking tape on the paint, followed by electrical tape (seals better than masking tape); then the inner tube
    to protect the paint mating surface
  9. Apr 27, 2023 at 11:21 PM
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    Even if it's a fat tire tube, still a cheaper option. They are easy to get also.
  10. Apr 28, 2023 at 8:12 AM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    Remembering from... the '80s?.. One could buy an inflatable gasket to fit between the cab and cap. They were very popular. In a couple of years you could see where the gasket rubbed the paint down to the bare metal. They dropped in popularity. Can't remember the last time I saw one.
    The cab and bed move independently from each other. You'll need to address that problem if you want to fill that gap.
    BigCountry762x39 likes this.
  11. Apr 28, 2023 at 9:01 AM
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    likely because they destroyed the paint my 1990 had a topper like that and all the paint around my rear window was buffed off. from the topper gasket/seal rubbing on the cab
  12. Apr 28, 2023 at 1:23 PM
    TacoTuesday1
    FL
    honestly I could even accept that at this point given the roof and hood fade spreading that a paint guy quoted me like $3k+ to fix and would need shell removed
    obviously I said no thanks lol
    how cool it would be one day to respray the whole thing
    Better yet to a matte green or tan so these off road vehicles actually blend in off road. Which the factory green and tan of newer Toyotas is at least closer to than 2nd gen color choices
  13. Apr 28, 2023 at 1:26 PM
    BigCountry762x39
    TL
    PNW, Oregon!
    yeah, I've a white Tacoma and thought i was doing okay (only paint I've found gone is around the door glass and the paint under the hood) until I noticed a huge bubble on my hood sort of behind my bug guard and I was super excited to see that bubble, i may honestly grab a roll of wrap and start over the hood.
