Connections to thermal expansion valve
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jnywadd, Dec 24, 2019.
  1. Dec 24, 2019 at 7:04 AM
    jnywadd
    jnywadd [OP] Member
    Hi folks! I have a 2005 Tacoma prerunner that has bent tubes going into the thermal expansion valve (it's the part with the stubby tubes that screws into it), does anybody know what this piece is called and where to get a new one?
  2. Dec 24, 2019 at 7:11 AM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
  3. Dec 24, 2019 at 8:38 AM
    jnywadd
    jnywadd [OP] Member
    It does help but I'm looking for the connection tube part as mine is bent, I've looked everywhere and no one seems to have a new one
  4. Dec 24, 2019 at 9:16 AM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Junkyard !
  5. Dec 24, 2019 at 9:32 AM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    You need the manifold (two tubes built into a flange) that bolts to the TEV? I believe that is considered part of the TEV and is included with it under the OE part number. 88515-04060
  6. Dec 24, 2019 at 9:43 AM
    jnywadd
    jnywadd [OP] Member
    oh, ok, I didn't know
  7. Dec 24, 2019 at 9:47 AM
    windsor
    windsor Just a guy
    Homeless in Oregon
    No worries. That what questions are for. To ask something you dont know.
    I will make one note though. If you buy non-OEM TEV, I doubt it will come with the tubes. Probably just a pair of o-rings.
  8. Dec 24, 2019 at 9:50 AM
    windsor
    windsor Just a guy
    Homeless in Oregon
