Consensus on front diff oil
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Hank Heel, Sep 11, 2018.
  1. Sep 11, 2018 at 12:40 PM
    Hank Heel
    Hank Heel [OP] Well-Known Member
    WA
  2. Sep 11, 2018 at 12:46 PM
    nh_yota
    nh_yota Well-Known Member
    Jeff
    Portsmouth, NH
    2010 DC V6 TRD-OR 6-SPD
    2" Lift with HS coils/AAL and 5100s, TRD Exhaust, TRD Skid Plate, URD Short Shift, AT3s
    Your front diff does much less work than your rear diff so I don't think anything special is necessary. I use Valvoline Synthetic 75W90 in both diffs because I can get it cheap on sale.
    tonered likes this.
  3. Sep 11, 2018 at 12:47 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Lucas 85w-140 Dino (this is what east coast gear supply recommends)
  4. Sep 11, 2018 at 12:50 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Less work, yes, but due to the ADD, the spiders are always whirring around. I'd always change it when changing the rear. Using just 1.6qt, it doesn't hurt much.
    There was another diff lube thread around here that had a 'study' in it sponsored by AmSoil. Reading it with a critical eye shows that just about any full-synth diff lube is plenty fine.
  5. Sep 11, 2018 at 12:52 PM
    Hank Heel
    WA
    Good to know, though subjective, whats better RP or mobile 1?
  6. Sep 11, 2018 at 12:54 PM
    nh_yota
    Jeff
    Portsmouth, NH
    Agreed and that's why I always change them both at the same time.
    tonered[QUOTED] likes this.
  7. Sep 11, 2018 at 12:55 PM
    nh_yota
    Jeff
    Portsmouth, NH
    Just like engine oil, it's more important that you change it regularly than which brand you use.
  8. Sep 11, 2018 at 12:57 PM
    Hank Heel
    WA
    The reason im not touching rear diff, is because i just had toyota completely reseal and refill it last month. It was their third attempt at stopping rear diff leak, seems ok now. So with that said rear diff fluid is brand new, along with all the hardware
    tonered likes this.
  9. Sep 11, 2018 at 12:58 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    75W90 Redline or Amsoil (only Group V) synthetics. Change every 60k miles or do whatever you want.
  10. Sep 11, 2018 at 1:00 PM
    Hank Heel
    WA
    As a previous E46 M3 owner of 12 years, RedLine oils have great initial specs, but loses its properties quick, so the consensus for redline was to change it often.
    And i agree, motor oil is under much more strain that a front diff that is hardly used
  11. Sep 11, 2018 at 1:08 PM
    nh_yota
    Jeff
    Portsmouth, NH
    I've heard the same - I use RedLine MT90 in my manual transmission/transfer case and change it every 30k.
    tonered likes this.
  12. Sep 11, 2018 at 1:12 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I went with M1 just because it was more available and priced well.
    Jh8473 and Clearwater Bill like this.
  13. Sep 11, 2018 at 1:14 PM
    Grossomotto
    2017 4WDV6LB6MT
    Which properties? As in TBN? Did you do an oil analysis? All oils Dino and Synthetic will shear down to lower weights especially at the 15K BMW OCI.
    The good thing with Redline is their weights are higher on the visco scale, ie their 0W20 is almost a 30wt.
    FWIW, Redline is one of the only Group V polyol Ester based pure synthetics on the market.
    shakerhood likes this.
  14. Sep 11, 2018 at 1:25 PM
    BarcelonaTom67
    BarcelonaTom67 Lost in Translation....
    Tom
    Laurel County, Kentucky
    2017 Barcelona Red Off-Road DCSB M/T
    I've been using Amsoil oil and gear lubes in my vehicles since the late 90's. Since I don't have any experience with other synthetics, I can offer no comparisons, but have never had a single issue with any Amsoil product.
    Hank Heel[OP] likes this.
  15. Sep 11, 2018 at 1:26 PM
    Hank Heel
    WA
    Yes I know most of this only because BMW’s OG 10w-60 oil for s54’s was ester based, which they later did away with causing uproar among the community. I’m not arguing that redline is bad, it’s great for high duty cycles with frequent intervals.
    I digress though, my diff doesn’t see abuse, I’ll go with rp.
    Thanks for your knowledgeable input
  16. Sep 11, 2018 at 1:28 PM
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    CAN CONFIRM
    BassAckwards[QUOTED] likes this.
  17. Sep 11, 2018 at 1:30 PM
    Grossomotto
    2017 4WDV6LB6MT
    Right on, any gear oil will last 60k miles. Some owners never change it for 250k
  18. Sep 11, 2018 at 1:56 PM
    Hank Heel
    WA
    If only it were readily available
  19. Sep 11, 2018 at 3:16 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Hank Heel[QUOTED][OP] likes this.
  20. Sep 11, 2018 at 3:21 PM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Toyota specs 75w85 GL-5
    Hank Heel[OP] and shakerhood like this.
