Constant 12v near tailgate?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tanzak88, Mar 10, 2011.
  1. Mar 10, 2011 at 11:47 AM
    tanzak88
    tanzak88 [OP] Well-Known Member
    Alright guys, I'm wiring in some "driving lights" as dome lights in my canopy... Making up the wiring harness right now, and wondering if there's a constant + somewhere near the tailgate. If not, then I'll just run up to my battery.
    Any ideas?
    Thanks
  2. Mar 10, 2011 at 12:10 PM
    tanzak88
    Yup that is mine. TRD Sport with the tow package.
  3. Mar 10, 2011 at 12:27 PM
    rhavin42
    rhavin42 Well-Known Member
    Vladimir
    Phoenix, AZ
    09 DC LB SPORT 4x4
    how bout tapping off the trailer wiring, I'm pretty sure there is +12V in that harness.
    Or even more fun, tap off the 110VAC from the inverter plug and wire up some AC lights :)
  4. Mar 10, 2011 at 12:49 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    In you application, depending on how powerful the lights
    i would just run directly to the battery
    with the appropiate fuse in line with the switch.
  5. Mar 10, 2011 at 12:59 PM
    tanzak88
    Yeah I'm thinking that may be the safest. I'll probably end up doing that. I'm out on a call right now though so can't work on it... My truck is sitting in the bay at the station haha. Booo!
  6. Mar 10, 2011 at 3:42 PM
    Tacofanatic05'
    Tacofanatic05' #1 Member
    Hunter
    Waynesville/Charlotte,NC
    05' Tacoma 4x4 sr5, 3 Inch lift
    16'' American Racing wheels, 285/75/16 Cooper Discoverer St tires, Bilstein 5100 w/eibach coils, K&N Cold Air Intake, Flowmaster Super 44, 1 in 2 out exhaust. Tractor Supply Tool Box, No Mud Flaps, Mossy Oak Seat Covers, Oakley Decals, Hoyt Decal, Window tint 20% on sides 5% on top front windshield, Uniden Cb, and Window Deflectors.
    Running it to the battery sounds like the easiest to me!
  7. Mar 10, 2011 at 5:18 PM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    x2..I wouldn't tap into the bed outlet since its only rated at 400W, that would limit that outlet for other plug-in devices. Tapping into taillights may overload it and blow the fuse.
  8. Mar 10, 2011 at 5:57 PM
    tanzak88
    Roger that guys. I'll run it to the battery.
  9. Mar 10, 2011 at 6:02 PM
    BarefootBandit
    BarefootBandit Well-Known Member
    TC UCA OME 884 5100 TSB+AAL 4.10 V6 6spd 285/75/16
    I almost ran my reverse lights to the battery but I couldn't figure out a good path. I just wired it into the trailer harness.
    I was afraid that a bare 14 gauge wire running along the frame could wear away and cause a short.
    Care to show us how you did it?
  10. Mar 10, 2011 at 6:39 PM
    tanzak88
    I'll run it to the battery with some wire loom, tuck it up above the frame and zip tie it. I'll take a couple pics in a sec here. It's nothing special really, just two little cheap "driving lights" from Princess Auto, mounted at the top-rear of my canopy.
  11. Mar 10, 2011 at 8:05 PM
    tanzak88
    Okay, so... I got fed up trying to figure out the best way to run the power back from the battery annnnd I'm giving up... for now...
    Can anyone who wired up switched backup lights, chime in?
    EDIT
    Is this correct? Has anyone used the constant hot on the trailer wiring? They're 55w lights, according to the box, and since I wont be towing a trailer...yet... I'm sure drawing from the trailer harness would be fine...?
  12. Mar 10, 2011 at 9:25 PM
    tanzak88
    Update:
    The black wire on our trailer harnesses is 12v+ switched. Only comes on with the key turned to "ON".
    Damn... so much for that idea... I guess it's time to run power from the battery... ughhh this is going to suck.
  13. Mar 10, 2011 at 10:39 PM
    squamish VFR
    squamish VFR Well-Known Member
    Squamish B.C. Canada
    '06 tacoma 4door shortbox
    Bilsteins set at 2.5" OME Dakar rear leaf packs, FJ manual TC conversion, basket winch front and rear, hidden hitch in the front behind licence plate. Spyder headlights, tailgate seals.
    Isn't the red hot all the time? I think you have everything you need right there.
  14. Mar 10, 2011 at 11:16 PM
    tanzak88
    Not from what I read on trailer wiring diagrams. They said that black was 12v, which is it, but switched 12v.
    I decided to man up and run it to the battery.
    Fucking disgusting.
    When Toyota undercoated it... they did it with a rubberized undercoat. It hasn't fully set up, 6 weeks later. I have rubberized tar shit all over me. In my hair, on my clothes... thankfully I had nitrile gloves on... Gross.
    Shower time, then bed, then finish wiring tomorrow.
  15. Mar 10, 2011 at 11:23 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I don't doubt it is switched. But I bet it's switched with a relay. Relays can be removed and jumpered if you can find the relay. Then, constant power and game on.
  16. Mar 10, 2011 at 11:30 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Don't be such a Thornton and run it to the battery . ;)
  17. Mar 11, 2011 at 2:49 AM
    06rubi
    06rubi Well-Known Member
    Kenney
    Pueblo West, CO
    10 MGM (wife's truck)
    Debadged, tinted windows, 7 pin relocated, bed lights, 12 volt socket in bed of truck, on board air, auxiliary fuse box, grill craft, hella 500's, t-rex eyelids, pink budbuilt skids, icon remote resi coil over, camburg uca, alcan rear springs, ubolt flip, icon 2.5 remote rear resi shocks
    Might want to put in a 12v outlet or 2 while you are pulling wire.
  18. Mar 11, 2011 at 3:18 AM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    Yea even if the trailer harness had a constant hot IDK if i'd mess with it just to be safe. Smart move running a new wire, dont forget about wire loom to protect it. I did the same for bed lights and decided to throw in a 12 outlet in one of the cubbys
  19. Mar 11, 2011 at 9:54 AM
    tanzak88
    The whole time running the wire, I was thinking to myself... "I should be running a heavier gauge, and making 12v plug back there...."
    I didn't. Blah.
  20. Mar 11, 2011 at 9:04 PM
    Jerry Bear
    Jerry Bear Well-Known Member
    Jerry
    Mesquite, Texas
    2010 Access Cab
    tint, topper, receiver hitch, trailer wiring, topper lighting, cruise control, intermittent wipers, backup camera, auto-dim mirror
    It's the BATT CHG relay in the fuse box under the hood.
    I could not find unswitched 12 Volts anywhere behind the cab of a 2nd Gen Tacoma. I checked the 2006 and 2010 EWDs when I was wiring the light in my topper.
