Constant Hot Wire Under Dash?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MolonLabeTaco, Mar 13, 2018.
  1. Mar 13, 2018 at 11:50 AM
    MolonLabeTaco
    MolonLabeTaco [OP] Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    I searched but all I found was info. pertaining to turd gens. Is there a fuse spot in the panel under the dash that's not being used & is a constant hot? If not, is there a convenient constant on wire under the dash so I can do the inverter constant on mod? Thanks.
  2. Mar 13, 2018 at 2:37 PM
    twhalm
    twhalm Well-Known Member
    Denver, CO
    2015 TRD/OR Manual, OME , Dual battery
    MolonLabeTaco[OP] likes this.
  3. Mar 13, 2018 at 5:17 PM
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    That mod does the 400W all the time.
    I'm wanting to make the inverter work without the key in the ignition.
    I'd like to use a fuse tap and tap into one of the fuses (that's the sole purpose of my post!), but which one do I tap into?
    Thanks.
  4. Mar 13, 2018 at 6:07 PM
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    There's 2 fuse slots, both already being used, in the fuse panel behind the change holder that are constant hot. In the photo, it's the one that says PWR OUTLET 15A and the one that says DR LOCK 20A. I'll use one of these to do the always on mod for the inverter.
    This is the thread I'll be using it for:
    https://www.tacomaworld.com/threads/inverter-anytime-stock.251597/
    Thanks.
  5. Mar 13, 2018 at 6:26 PM
    badger
    badger Well-Known Member
    07 SR5
  6. Mar 13, 2018 at 7:27 PM
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    That's the exact device I plan on using. Keeps things nice & clean, no splicing of factory wires (which I can't stand) plus it's cheap!
    badger[QUOTED] likes this.
  7. Mar 13, 2018 at 11:10 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    The tail light and door lock fuses should have juice to them 24/7. You can use a voltmeter to locate other possible sources. Remember to connect your fuse tap in the side of the power source, not the side to the accessory.
  8. Mar 14, 2018 at 3:36 PM
    Chuy
    Lakeside, CA
    Silver Taco
  9. Mar 14, 2018 at 5:08 PM
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    I'm not actually powering the factory inverter with it. It's just the trigger wire for the switch and to make the inverter think the key is turned on. All the factory wires I'll be messing with are 18 or 20 gauge. Thanks for looking out, though!
  10. Mar 14, 2018 at 5:28 PM
    Chuy
    Lakeside, CA
    Silver Taco
    Gotcha. May I suggest a pop-in volt meter for one of the power ports to monitor voltage, assuming you have constant-on power. This, to monitor voltage drop because inverters quickly drain batteries.
  11. Mar 14, 2018 at 7:48 PM
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    On my 80 I went all out with double batteries, plugs everywhere, crazy wiring, 3 volt meters (1 under hood, 1 front console, 1 rear compartment), etc. I'm not going that crazy on this. I'll definitely get a bolt meter where I can keep an eye on it! I've read the inverter will cut off when battery gets down to 12V's. Any idea if that's true?
  12. Mar 14, 2018 at 9:05 PM
    badger
    07 SR5
    I think the suggestion of volt meter is a good one. 12.7V is fully charged. I think 11.8V is stone dead. If the cut off is 12V, that is cutting it close.
  13. Mar 15, 2018 at 6:12 AM
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    I just started my FZJ80 at 11.4V and it's a lot harder to crank than these Taco's. I'll be getting a VM on it and keeping my eye on it. Thanks! :thumbsup:
