Contemplating trading 03 tacoma in due to axlewrap
Discussion in '1st Gen. Tacomas (1995-2004)' started by Matthewlost, Apr 14, 2011.
  1. Apr 14, 2011 at 2:56 PM
    Matthewlost
    Matthewlost [OP] Active Member
    Louisiana
    2003 Prerunner SR5 X-Cab, V6
    Interesting. Well my truck sits very level, so I guess that's a bad sign.
    So, basically you all are recommending I purchase an aftermarket set of leafs (4 pack I assume). This won't raise the back end too much?
  2. Apr 14, 2011 at 2:58 PM
    TacomaJack09
    TacomaJack09 Well-Known Member
    Jackson
    Montana!
    06 Access Cab 4x4
    Billie 5100's, Ride Rite Airbags, Tech Deck
    Had the same problem, replaced my leafs, and no more problems. Here's a link to a vendor here. If you want stock height you would want to buy the 4 pack. I bought the 5-pack for my truck, which gives about 1.5" of lift. They just had a group buy on these too, you may be able to get in on the deal still, don't quote me on that tho! These leafs get great reviews. Many Taco's on this forum run them.
  3. Apr 14, 2011 at 4:03 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Yep, a decent Wheeler's 4 pack will do it.
    Noticed your spare tire looks about shot...
  4. Apr 14, 2011 at 4:43 PM
    Matthewlost
    Louisiana
    Yeah. On the list.
  5. Apr 14, 2011 at 5:13 PM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    I got an AAl and it fixed it completely. But you will need to lift the front if u get an AAL since that will lift the rear.
    did cleaning the throttle bodies improve power or throttle response? If so, it makes sense that it made the wrap worse. since more power will equal more axle wrap
  6. Apr 14, 2011 at 8:36 PM
    Matthewlost
    Louisiana
    Honestly cleaning the throttle body (did not remove but cleaned plate, front and part of back) didnt do much except cause an increased idle. I removed battery cable to reset sensors and it went back to normal. Probably wouldnt do that or seafoam again - just didnt seem to help anything.
  7. Apr 15, 2011 at 3:45 AM
    nighthawkNdragon
    nighthawkNdragon Member
    4wd
    The wheelers 4 leaf did NOT fix my axle wrap. Adding their 2" AAL completely removed it.
  8. Apr 15, 2011 at 5:55 AM
    747
    747 function > form
    1st Gen.
    the bb trac bar worked for me, but it was relatively expensive, and did nothing to cure the underlying problem: weak oem leafs. x2 on replacing leafs. also, imo, aal is a temp fix...just sayin'. good luck, op.
  9. Apr 15, 2011 at 6:21 AM
    JeffsJeep04
    JeffsJeep04 Well-Known Member
    WI
    2021 TRD OR Premium 6MT
    Are you positive it's axle wrap and not a u-joint starting to go?
  10. Apr 15, 2011 at 6:21 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    eh, throw a couple Ford springs under your stockers, & go about your business & call it good, because it will be....:cool:
  11. Apr 15, 2011 at 6:25 AM
    MTgirl
    Weesa
    Bob's secret mod lair
    Axle wrap about drove me crazy as well...I upgraded the entire suspension last year and couldn't be happier! The ride is better and axle wrap is gone. I went with the Wheeler's 5 pack amongst other parts....
  12. Apr 15, 2011 at 6:42 AM
    Matthewlost
    Louisiana
    I don't know for sure that it is axle wrap, but it seems very likely based on what I've read. Can a U-Joint failing cause similar symptoms?
    An interesting note: I live in Louisiana and we recently had a cold day. During that day the axle wrap was much improved - only doing it a few times that day. In my mind, the cold made the steel more rigid, which improved the axlewrap, but I can't be sure.
  13. Apr 15, 2011 at 6:54 AM
    JeffsJeep04
    WI
    If you are getting a clunk/thump when taking off/changing directions, I'd look at a u-joint before springs honestly. Best thing is to jack back tires off the ground (wheels chocked), set the parking break, and see if you can get any play in the drive shaft.
  14. Apr 15, 2011 at 7:02 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    On just about any other vehicle I'd lean towards this, but for the Tacomas, with those symptoms, smart money says its time for some springs, either adding some or new leaf pack altogether...;)
  15. Apr 15, 2011 at 7:16 AM
    #35
    woodygg
    woodygg Well-Known Member
    So Cal
    04 DC Tacoma 4x4
    Don't give up, that should be one of the easier problems to fix...
  16. Apr 15, 2011 at 7:18 AM
    #36
    Matthewlost
    Louisiana
    Definitely not getting a thump when changing directions. Only when I come to a stop or let off the break. It feels like built up tension and then recoil to release the build up of pressure. Weakening leafs seems more likely to me, but I'm not very familiar with the inner working of u-joints.
  17. Apr 15, 2011 at 7:23 AM
    #37
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Bro' you can stop driving yourself nuts over this, what you describe is classic, text book Tacoma axle wrap, I'll do you one better.... If a rebuild or change in your springs doesn't take care of that "wrap" . Send me the bill...:cool:
  18. Apr 15, 2011 at 8:07 AM
    #38
    Matthewlost
    Louisiana
    Well good. I'm definitely going to buy new springs and I will install them myself. I'll do a search for a good write up on "how to," but if anyone has an easy forward, please post.
    Thanks everyone.
  19. Apr 15, 2011 at 10:22 AM
    #39
    MTgirl
    Weesa
    About a week before you attempt the install get a can of PB Blaster and start dousing the front bolts and rear shackles to help break up any rust, etc. Do this at least a couple of times. That was the hardest part of the install...freeing up the bolts. Some guys have had to saw them off. Otherwise it was pretty easy.
    Along with the new spring packs, I would recommend also getting new front eye bolts and new u-bolts. You can reuse the rear shackles but if you have the money it wouldn't be a bad idea to replace them as well.
  20. Apr 15, 2011 at 4:00 PM
    #40
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    ^ what she said i would make sure you buy the bolt for the front hangers. You can always return them if they actually come out. All 4 times iv changed leaf's it has had to get chopped out.
