Contemplating trading 03 tacoma in due to axlewrap
Discussion in '1st Gen. Tacomas (1995-2004)' started by Matthewlost, Apr 14, 2011.
  1. Apr 15, 2011 at 9:43 PM
    #41
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Also... heat works wonders on shitty rusted bolts. Especially after 6 days of PB blasting 3 times a day.. a few minutes of heat works wonders... :cool: Even on your back muscles :D
  2. Apr 17, 2011 at 7:14 AM
    #42
    Matthewlost
    Matthewlost [OP] Active Member
    Louisiana
    2003 Prerunner SR5 X-Cab, V6
    Does anyone have any experience with greasable shackle set vs. oem set?
  3. Apr 17, 2011 at 8:45 PM
    #43
    Supra TT
    Eric
    Indiana
    Greasable are nice!
  4. Apr 18, 2011 at 7:24 AM
    #44
    Matthewlost
    Louisiana
    Is this everything? Anyway to save money on this order?
    Wheeler's Off-Road Secure Ordering
    ProductQuantityPriceAmount
    Wheeler's 4 Leaf Tacoma Leaf Spring Set 1998-2004 498L-R 449.00
    Tacoma Factory Shackle Set 04483-04040 157.00
    WHE-U6754X U-bolt Set 29.95
    Tacoma Factory Main Eye Bolt Set 17.50
    All prices are in US DollarsTOTAL653.45
  5. Apr 18, 2011 at 7:30 AM
    #45
    JeffsJeep04
    JeffsJeep04 Well-Known Member
    WI
    2021 TRD OR Premium 6MT
    I know they say it's leafs, but did you at least check the ujoint before you are going to drop $650 on a hunch?
  6. Apr 18, 2011 at 9:44 AM
    #46
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    I didn't recommend buying any aftermarket springs...
    I'm POSITIVE its axle wrap...
    AXLE WRAP....
    Axle wrap
    :facepalm: That ship has already sailed, I coulda fixed your problem for less than $75, but whatever follow the sheep...BAAA, BAAAA !!:D
    :facepalm::facepalm::facepalm:
    Just can't get past that U-joint thing can you mr. Jeep , I don't base my opinions or suggestions on hunches, maybe you should read up on the quirks &/or TSB's on these trucks
  7. Apr 18, 2011 at 9:52 AM
    #47
    JeffsJeep04
    WI
    I've been a mechanic before, I've read TSB's. I also know that things that can be checked for free and very simply should be. Get off your high horse man.
  8. Apr 18, 2011 at 10:14 AM
    #48
    Matthewlost
    Louisiana
    A bit more than a hunch, but I think its a good policy to rule out cheaper possibilities, prior to spending that kind of money. I will check the u-joints, but if you do a search on this forum for axle wrap, you'll see its a very common problem and the symptoms are very distinct.
  9. Apr 18, 2011 at 10:27 AM
    #49
    JeffsJeep04
    WI
    No doubt, and that'd be my first assumption as well, based on the history with these trucks. Seems silly to not check u-joints when there is driveline thumps though, I've seen them do it on deceleration/stops as well (driveline unloading).
    No skin off my back though, if I'm too knew/don't have enough posts for some, I guess they just don't have to take my advice into consideration.
  10. Apr 18, 2011 at 10:56 AM
    #50
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Dude, I don't give a shit how many post someone has, I don't look for numbers, I look at the content, & I'm not in disagreement with checking drive line (U joints, sliding yokes,etc;) something that should be done on a regular basis, but with the OP's issue & symptoms it cannot be anything else BUT axle wrap, I put up with the same shit for at least a year , with exactly same symptoms, rebuilt my stock springs & it is a done deal, no more axle wrap, Now if the OP wants to spend $600 + to remedy this thats up to him, not everyone wants to get that "hands-on" with their trucks (rebuild, like i did)
    P.S. I wasn't trying to come off like a know-it-all
    (because I sure as hell don't know all)
    Its only because i just went thru this
  11. Apr 18, 2011 at 11:04 AM
    #51
    JeffsJeep04
    WI
    I'm with ya, I sure the heck would learn to get "hands on" fast if I wasn't before spending almost a grand for a pair of leaf springs.
  12. Apr 18, 2011 at 11:09 AM
    #52
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    EXACTLY !! ;)
  13. Apr 18, 2011 at 11:10 AM
    #53
    Matthewlost
    Louisiana
    I've done almost all the work on my truck myself, and I plan on installing the leaf springs myself, if I decide to go ahead with that. I don't know how to be much more "hands on."
    So rebuilding your stock springs cured your axle wrap (4wd) ?
    I've heard from one taco owner who purchased the 4 pack leaf set and it didn't fix the problem. Anybody else have trouble fixing the axle wrap?
  14. Apr 18, 2011 at 11:19 AM
    #54
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    If money is an issue right now.. a $25 pair of helpers spring from Auto zone will help big time!
  15. Apr 18, 2011 at 11:20 AM
    #55
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    http://www.tacomaworld.com/forum/suspension/149950-stock-trd.html
  16. Apr 19, 2011 at 6:36 AM
    #56
    nighthawkNdragon
    nighthawkNdragon Member
    4wd
    That was me, wheelers' 4 leaf pack didn't fix axlewrap on my 2001 double cab 4wd. I ordered the 2" add a leaf and it fixed it. I don't think it's the lift, I think it's the extra leaf spring that helped.
  17. Apr 19, 2011 at 8:19 AM
    #57
    DblCabMN
    DblCabMN Well-Known Member
    Mpls, Minnesota
    03 DC TRD/LTD
    Bilstein 5100's all around - Toytec/Eibach 112-620 Coils, Wheelers 5-Pack+Wheelers 2"AAL. 33x10.5x15 KM2s - Siped on Summit Racing 84-5883 rims with 3.750 BS. 4.88s. Demello HD round sliders. Home built full skids. Home built front bumper. Plasti'd badges. Energy Susp. steering rack bushings. Sway bar delete. Deck plate mod. aFe Pro-Dry. Gibson exhaust.
    Why do people go with the 4 over the 5?
    Also if you wouldn't of hmmm'd and hawwwww'd over the leaf-pack purchase for the past week or so you could've gotten in on the Wheelers 5-Leaf Group Buy and gotten the 5-pack for $390 (15% off).
    Good luck to you!
  18. Apr 19, 2011 at 8:31 AM
    #58
    Littlebro 5
    Littlebro 5 Well-Known Member
    Tyler
    Wilsonville or
    01 4x4 3.4L sr5 manual all-pro lift
    6" deck plate mod, sweet bed bar.
    http://www.tacomaworld.com/gallery/showphoto.php/photo/152291/size/big/cat/500/ppuser/49292
    That's what I did and it works good
  19. Apr 19, 2011 at 9:28 AM
    #59
    sxgt
    sxgt Member
    03 DC SR5 4WD TACO
    I will echo that new leaf springs don't guarantee a fix.
    I have an 03 Dbl Cab 4wd Auto - just replaced the entire suspension with the Wheelers complete OME setup listed here for $1,139: Axle wrap still exists for me - no change to the axle wrap issue whatsoever after the new suspension - it is just as bad. I measured my heights before and after - I needed the suspension but it did not fix the issues for me. I have the distinct clunk when braking or taking off from a quick stop. If I ease the brakes to come to a stop it does it significantly less.
    Just some discussion info - I plan to have my ujoints looked at - by the shop that did my install. Also I need to post pics in OME thread - I really like the way it sits now with my new wheels.
  20. Apr 19, 2011 at 8:36 PM
    #60
    nighthawkNdragon
    4wd
    I originally wanted to keep the stock height, then decided to lift it a few months later.
