control arm bushing sleeves
Discussion in '1st Gen. Tacomas (1995-2004)' started by jrmram, Apr 27, 2011.
  1. Apr 27, 2011 at 9:20 AM
    jrmram
    jrmram [OP] New Member
    i am working, paint and body, on a 96 4x4 for a customer and we are putting all new bushings in. because i am backed up a little, i was having a mech shop close to me do the control arm bushings, upper and lower. the just called and said that they pressed out the sleeve with the bushing and that the new, energy suspension set did not have the sleeve. that the bushing was to small for the hole without the sleeve. this was my first set also, another reason i sent it to them. well, i cant find just the sleeve. i wanted to know if anyoneelse has ever had to deal with this problem and what the cure was or how they fixed it
  2. Jan 29, 2014 at 9:29 PM
    elkhunter358
    elkhunter358 Member
    Steven
    AZ
    01 4x4 trd 2.5'' lift step side
    danahoe coil over 2.5-3'' 2'' leave springs in back diff breather air aid intake vinyl flooring bed liner in bed and side panels turn signal mod
    What did you end up doing? Im in the exact same position right now except Im doing it on my own! what did you do?
  3. Jan 29, 2014 at 9:57 PM
    presto
    presto Well-Known Member
    Topher
    san francisco
    97 4wd 2.7L xtra cab auto
    Look at build thread
    Damn that sucks. I got the master set and have been waiting to do the control arm bushings till I need an alignment.
