Controller Area Network (CAN) truck?
Discussion in '1st Gen. Tacomas (1995-2004)' started by derekp, May 13, 2010.
  1. May 13, 2010 at 6:38 AM
    derekp
    derekp [OP] giddy up!
    Derek
    Grand Forks, ND
    2001 X-Cab 4x4 TRD V6 5Spd
    Deck plate, Flowmaster Delta-Flow 40 series, 265/75-16 Wrangler TDs, more to come...
  2. May 13, 2010 at 8:20 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    On a 2001, you need an OBDII scanner. CAN compliance didn't arrive until the 2005+ generation.
  3. May 13, 2010 at 11:49 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Get a Scangauge II ..... it'll read engine codes, allow you to clear them, and a lot of other stuff. Do some research, lots of info about them!
  4. May 13, 2010 at 11:55 AM
    derekp
    Derek
    Grand Forks, ND
    The code reader is already in the mail. The scangauge looked pretty cool though, it was on the gadget list until Garmin teased us with the ecoroute HD (which they have pushed the release date back a few times). Plus, the scangauge won't give me sensor readouts (I don't think it will).
    Also, has anyone relocated the ODBII port on the 1G? I have pretty much made up my mind that if I am running the truck with something plugged in the port, I will kick the plug and damage the plug and/or the device. I'm not sure if relocation is even possible.
