Converting 2006 Toyota Tacoma from 2wd to 4wd
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2006 yoda boy, Dec 21, 2017.
  1. Dec 21, 2017 at 8:46 PM
    2006 yoda boy
    2006 yoda boy [OP] Member
    2006 Toyota Tacoma prerunner
    Hey guys glad I could join the group. Imma hit y’all with a serious question that I’ve been researching. How much and what all do I need to convert my 2006 Toyota Tacoma prerunner to 4wd? Trading or selling My truck is a negative.. I love my truck.
  2. Dec 21, 2017 at 8:50 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I’d estimate 2-3k if you do the labor
    Front diff
    T case
    Cv axles
    Wheel bearings
    Front/rear drive shafts
    New transmission
    Fabricate a new 4x4 crossmember
    Hardware to mount the diff
    Wiring to activate ADD System
    Interior 4wd switch
  3. Dec 21, 2017 at 8:55 PM
    2006 yoda boy
    Would that be searching around to find the parts cheap as possible or new? An doing it myself or paying someone more mechanically inclined? Cause I haven’t did a swap like this yet
  4. Dec 21, 2017 at 8:55 PM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    2006 Tacoma pre-runner converted 4x4 supercharged
    I did manual trans at the same time. It was about 5.5k. There is custom work that needs to be done. If your up for that. A modified driveline as well. If you decide to do it I have a few left over parts that may help you.
  5. Dec 21, 2017 at 8:57 PM
    anthony250f
    Anthony
    San Diego, CA
    Not new...new would be like 10k
    Buy new hub bearings though from here
  6. Dec 21, 2017 at 8:57 PM
    anthony250f
    Anthony
    San Diego, CA
    You went from auto to manual?
    rheath08 likes this.
  7. Dec 21, 2017 at 8:59 PM
    rheath08
    Russell
    Bakersfield, CA
    Yes I did. I don't recommend that for the faint of heart.
  8. Dec 21, 2017 at 9:01 PM
    rheath08
    Russell
    Bakersfield, CA
    I found some of the big parts off eBay. I found a new trans not rebuilt from Toyota for about $1800 plus shipping. That was after I finished. Lol
  9. Dec 21, 2017 at 9:06 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Why not sell the 2wd and buy a 4x4?
  10. Dec 21, 2017 at 9:06 PM
    2006 yoda boy
    So if I kept it auto it would run about 2-3k? Swapping to manual would probably be 5-6k?? How long would it take to do either one once I got everything I need?
  11. Dec 21, 2017 at 9:10 PM
    rheath08
    Russell
    Bakersfield, CA
    Mine took a while I even had problems with bad parts so more down time. Be patient it will take time. Especially when is the fabrication of the crossmember. Then once everything's in you can take a measurement for your drive line to have the drive line modified. Which the carrier bearing will be modified to a new location as well as a front section shortened and have a new flange put on.
    2006 yoda boy [OP] likes this.
  12. Dec 21, 2017 at 9:11 PM
    rheath08
    Russell
    Bakersfield, CA
    I set aside about a week if all goes good. So have other transportation.
  13. Dec 21, 2017 at 9:11 PM
    2006 yoda boy
    Honestly I just paid it off and I’ve put some work into it. Most importantly I’m down for the project.
  14. Dec 21, 2017 at 9:12 PM
    anthony250f
    Anthony
    San Diego, CA
    2-3k is just a guess...all depends on how much the parts are that you find.
    In my opinion it’s not worth the trouble...sell it
  15. Dec 21, 2017 at 9:14 PM
    rheath08
    Russell
    Bakersfield, CA
    Are you down for custom fabrication and welding?
    Just be prepared.
    Do a search for rock solid toys. Wyatt has done a few conversions and will help awnser some questions.
  16. Dec 21, 2017 at 9:16 PM
    rheath08
    Russell
    Bakersfield, CA
    It is a big a$$ job. Money, money, money. I only did my conversion because I could not find I used 4x4 under $33k. But that is how California goes. Overcharge for everything. Lol
  17. Dec 21, 2017 at 9:17 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    It's madness. Sell it. Buy the identical truck with a 4x4 switch.
  18. Dec 21, 2017 at 9:20 PM
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    Depending on parts, you can do the conversion for under 3k. Look into 4th gen 4Runner Parts, that’s what I used, the hardest part will be swapping the tranny and building a new/custom tranny cross member.
    Do you want an auto tranny? Electronic or manual tcase?
    2006 yoda boy [OP] and rheath08 like this.
  19. Dec 21, 2017 at 9:22 PM
    JaCado
    JaCado Bad luck charm
    @acal here is a thread up your alley. Newer model with a little more cutting required than yours.
    acal likes this.
  20. Dec 21, 2017 at 9:23 PM
    YamaDirtrider
    Josh
    Elizabeth CO
    I’ve herd 1st gen is all bolt on. Super easy. 2nd you have to fab the mount
    2006 yoda boy [OP] and JaCado like this.
