Converting a 2.7l L4 2x4 PreRunner to a 3.4l V6 4x4 (Seriously)
Discussion in '1st Gen. Tacomas (1995-2004)' started by BartMaster1234, Feb 23, 2017.
  1. Feb 23, 2017 at 3:14 PM
    jacobrippey
    jacobrippey It’s always Taco Tuesday Instagram #rippstik
    Jacob
    Surprise, Arizona. USA
    2004 Tacoma DC 4wd
    Find me on Instagram: @rippstik
    Many people like the non-add manual set up. The add is vaccum actuated, which can lead to headaches on the trail. The manual setup gets rid of all the vacuum bologna and replaces it with the manual hubs (which are more reliable). When the hubs are unlocked, it's also less wear on the front end complements. I'd try to find a j shifter instead of the push button.
    boostedka likes this.
  2. Feb 23, 2017 at 3:16 PM
    Mobtown Offroad
    Mobtown Offroad Boss
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Go for it. It won't be an impossible thing. Report back with pics and funny stories.
  3. Feb 23, 2017 at 7:08 PM
    BartMaster1234
    BartMaster1234 [OP] Well-Known Member
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    So going the manual hub route is easier and more reliable, basically?
  4. Feb 23, 2017 at 7:31 PM
    jacobrippey
    Jacob
    2004 Tacoma DC 4wd
    Yes. Especially when converting from 2wd to 4wd. Also, you can modify the add front diff to be a manual setup pretty easily. Let me know if you want the link to how to do it.
  5. Feb 23, 2017 at 8:17 PM
    Animus313
    Animus313 Well-Known Member
    Post Falls/CDA, ID
    2000 Tacom xtra cab
  6. Feb 23, 2017 at 10:23 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I was planning on just buying a whole truck since I'm doing the engine swap too it'll be cheaper.
  7. Feb 23, 2017 at 10:36 PM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    BartMaster1234[OP] likes this.
  8. Feb 23, 2017 at 11:35 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    You should just go the extra mile and put a 4.7 V8 in there, that way there's a noticeable power gain! The HP difference between the 3.4 and 2.7 isn't that impressive.
  9. Feb 23, 2017 at 11:38 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    My real dream is putting in a 1JZ diesel in there like someone on this forum did, but after looking through that write-up it involves a crazy amount of fabrication and troubleshooting wiring harnesses. I chose the 3.4l because it already comes with a wiring harness and computer made for Tacomas and for the most part you don't have to fabricate or majorly change anything. I'll probably put a supercharger on it. Maybe.
    ClevSix likes this.
  10. Feb 23, 2017 at 11:40 PM
    2004TacomaSR5
    Jon
    Montana
    I always thought a twin turbo 2JZ swap into a Taco would be cool as well. People's jaws would drop when you smoked their Corvette with a 1000rwhp first gen Tacoma! Haha
  11. Feb 24, 2017 at 12:24 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Oh man you'd wreck the drivetrain from all that power and torque haha.
    That reminds me of a friend who took a Prius, removed the entire electrical and mechanical systems, fabricated a custom drivetrain, and dropped in a Chevy small block engine. It looked completely stock on the outside. You should've seen the face of the guy driving a Mustang stopped at the stoplight when he started revving the engine of the Prius.
  12. Apr 3, 2017 at 9:27 AM
    YotaGurlIAm
    YotaGurlIAm Well-Known Member
    Madison
    Arizona
    2008 4.7L - wait..I’m on the wrong forum.
    Stuff n' Thangs
    Hey Jacob, not sure if you'd know the answer to this but i've been researching the manual hub conversion for my 2003 pre runner. I've heard you can take the output shaft from a 4x4 transmission and attach to my current transmission. Is that possible? I'm also having trouble finding a concise parts list. I have the front driveshaft and interior bezel so far (not much i know) but all I need is the spindle/bearing hub assembly, manual CVs, manual transfer case (J-shift??) and front diff correct? Can the front diff come from any first gen or only another 2003? Sorry for the novel. Any input would be much appreciated! Thanks
  13. Apr 3, 2017 at 9:54 AM
    jacobrippey
    Jacob
    2004 Tacoma DC 4wd
    Oh boy. I don't know all the answers, but, you'll definitely need manual hubs, and front diff from any year Tacoma, drive shafts, etc. not sure about the transmission thing. Your part list looks good. Any front diff from any first gen Tacoma will work (add or manual). I can walk you through how to Convert the add to a manual if needed. Just be sure you match the gearing front and rear.
    YotaGurlIAm[QUOTED] likes this.
  14. Apr 3, 2017 at 9:55 AM
    jacobrippey
    Jacob
    2004 Tacoma DC 4wd
    I'm also in the middle of 3.4 swapping my 2.7 truck. Updates are on my build thread. Motor mounts will need to be moved. All wiring harness/ecu needs to be changed. Good luck bud!
  15. Apr 3, 2017 at 9:56 AM
    #35
    jacobrippey
    Jacob
    2004 Tacoma DC 4wd
  16. Apr 3, 2017 at 10:17 AM
    #36
    YotaGurlIAm
    Madison
    Arizona
    Stuff n' Thangs
    Thanks for the reply. Since I have a 2wd I don't believe I need to switch ADD to manual since theres no 4wd components anyway :confused:
    I do have a rear locker, but I don't think that needs to me messed with at all since its rear. I have been thinking about regearing to 4.10s, so yeah i'll have to find a matching front
    I'll take a look at your build thread too, thanks for the info!
  17. Apr 3, 2017 at 11:26 AM
    #37
    jacobrippey
    Jacob
    2004 Tacoma DC 4wd
    What I meant by the add swap is that you can get an ADD front diff (which are more plentiful on 4runners and tacomas) and convert it to a manual locking setup.
  18. Apr 3, 2017 at 11:29 AM
    #38
    YotaGurlIAm
    Madison
    Arizona
    Stuff n' Thangs
    Ohhh okay gotcha, yeah that could be a possibility. I'll be starting to really shop around for parts this next coming month.
  19. Apr 8, 2017 at 10:50 AM
    #39
    tacotime1
    tacotime1 Well-Known Member
    I just converted my truck from V6 prerunner to 4x4 with the push button transfer case.
    ClevSix likes this.
  20. Apr 8, 2017 at 10:59 AM
    #40
    BartMaster1234
    Tyler
    Flux Capacitor
    How hard is the push button vs. manual hubs? I'd rather have ADD push button simply for convenience.
