Converting J Shift to Electronic Shift 4wd?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ThunderOne, Jul 12, 2019.
  1. Jul 12, 2019 at 8:30 AM
    ThunderOne
    ThunderOne [OP] Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Has anyone done this or would know what would be involved in doing this?
    I know most people do this the other way around - however I plan to install a crawlbox and the Electronic shifter is much easier to relocate as it doesn't require four sticks in your shifter area, only 3 (I have a 5 speed manual so 4 sticks would get a little crowded)
    Thanks
  2. Jul 12, 2019 at 8:32 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Never heard of anyone doing that. But man 4 sticks would be cool as hell!!! I gotta see a pic of that! Wait wouldn't it be 3 sticks? Tranny, transfer case, and crawl box?
    970btu likes this.
  3. Jul 12, 2019 at 8:36 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    If you don't want your J shifter in the cupholder from the tcase being moved back, you'll need to break up the two shift patterns (2wd/4wd, hi/low) into two sticks.. so there would be a 2/4, hi/low, nocrawl/crawl, and 5 speed shifter. It looks like a mess, but you retain your cupholders. There's a lot of shifter bending to get them in the right place without hitting each other.
    Here is a super duper CLEAN install pic stolen from @Jonyd182
    essjay likes this.
  4. Jul 12, 2019 at 8:40 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Here's a vague sense of what it would look like with an electronic shifter, I think this is a 4runner though, and I have no idea why he used two E shifters either.
  5. Jul 12, 2019 at 8:43 AM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    It' d be a bitch. But it's doable You'd first have to swap in a 2-4 button transfer case to use the associated push button shifter.
    cruiserguy likes this.
  6. Jul 12, 2019 at 8:43 AM
    cruiserguy
    Elijah
    SEKS
    Oooooohh I gotcha.... I've never seen that and I love it though. But I get what you're saying. I'd imagine that if the year and model you have had the option of the push button then it would be possible to do. But I've never heard of it.
  7. Jul 12, 2019 at 8:43 AM
    cruiserguy
    Elijah
    SEKS
    Ultimate theft deterrent
  8. Jul 12, 2019 at 8:45 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Welp I was gonna type a response but @Snowy is in here now so I'll let him respond to this lol
    Bottom line is I would swap the tcase also.
  9. Jul 12, 2019 at 8:58 AM
    License2Ill
    Ian
    Well then the 4wd ecu has 12 wires. Half are shared with the j-shift transmission relay. The rest of the wires go to TC actuator.
    I converted from a push button to a j shift. If you get the TC & transmission harness it'll make your life easier.
  10. Jul 12, 2019 at 9:00 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    ah, I figured there would be some ECU crap in there somewhere. Thanks!
  11. Jul 12, 2019 at 9:04 AM
    License2Ill
    Ian
    Nah it's more like a fancy relay. It does things like scream out at you if you push the 4x4 button if you're going over 55 mph.:thumbsup:
    ThunderOne[OP] and cruiserguy like this.
  12. Jul 12, 2019 at 9:06 AM
    License2Ill
    Ian
    @tacotime1 Installed it and his truck never came with 4wd.
  13. Jul 12, 2019 at 9:33 AM
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    Honestly, keep your j shift. I dont see it worth it to swap in that push button tcase. Tcase shifters are easier to manipulate than swapping tcases. Dont have to twin stick the jshift case.
    ThunderOne[OP] likes this.
  14. Jul 12, 2019 at 9:43 AM
    License2Ill
    Ian
    I'm with Greg. 9 out of 10 posts of "My 4x4 no work" are from folks with the 2-4 TC.
    When I found out the FSM is completely wrong in it's diagnosing process. And there's no proper way to troubleshoot it I ripped mine out.
    Dirty Pool and ThunderOne[OP] like this.
  15. Jul 12, 2019 at 9:54 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Thanks fellas, you guys are right, can't beat the J shift reliability.
  16. Jul 12, 2019 at 10:47 AM
    tacotime1
    tacotime1 Well-Known Member
    Mine didn’t have any issues in Moab.
  17. Jul 13, 2019 at 4:29 PM
    License2Ill
    Ian
    Glad it's working perfect for you! I'm sure there are thousands of those TC's with no issues. But there are plenty with issues. With no ability to diagnose it. You pretty much have to throw parts at it. And those actuators ain't cheap.
  18. Jul 13, 2019 at 4:31 PM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Interesting. Cool to see someone going against the grain. I’m sure it’s possible. But I don’t have any 1st gen knowledge. Good luck though.
  19. Jul 13, 2019 at 5:15 PM
    tacotime1
    Appreciate it! Yeah that’s true. When it goes out, I’ll either convert to J-shift or do a gear driven swap.
