Cooks 2000 4x4 build with some BS
Discussion in '1st Gen. Builds (1995-2004)' started by BYJOSHCOOK, Jun 19, 2014.
  1. Nov 25, 2016 at 6:29 PM
    #1621
    LogCabins
    LogCabins Well-Known Member
    Robert
    Oahu
    99 SR5 3.4L 4WD
    You should be good, just need to trim....either that or your back spacing on your wheels is no bueno
    ChadsPride likes this.
  2. Nov 25, 2016 at 6:29 PM
    #1622
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    After all your functional needs are met.
    Patches won't help on the trail.
  3. Nov 25, 2016 at 6:30 PM
    #1623
    HSmith_11
    HSmith_11 Tacoma Enthusiast
    Hunter
    Madison, Va
    2001 Ext Cab SR5 4x4 MT
    5100/OME 881s 1.5" Progressive AAL 33x12.50X15 KO2s
    I have 3.75" backspacing
  4. Nov 25, 2016 at 6:32 PM
    #1624
    LogCabins
    Robert
    Oahu
    99 SR5 3.4L 4WD
    Ok so your good.....now get outside and BFH & Trim :amen:
  5. Nov 25, 2016 at 6:33 PM
    #1625
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    What did ya buy?
  6. Nov 25, 2016 at 6:34 PM
    #1626
    HSmith_11
    Hunter
    Madison, Va
    Does anyone else have any pics of their trimming cause i wanna make sure i dont screw up too bad.
  7. Nov 25, 2016 at 6:35 PM
    #1627
    HSmith_11
    Hunter
    Madison, Va
    Will flexing make the rubbing worse or less??
  8. Nov 25, 2016 at 6:36 PM
    #1628
    ChadsPride
    Sponsored by TacomaWorld.com
    Worse
  9. Nov 25, 2016 at 6:37 PM
    #1629
    ChadsPride
  10. Nov 25, 2016 at 6:37 PM
    #1630
    HSmith_11
    Hunter
    Madison, Va
    Thats what i thought but someone was trying to tell me that it will give it more room to turn and that it wont hit as much
    ChadsPride[QUOTED] likes this.
  11. Nov 25, 2016 at 6:38 PM
    #1631
    LogCabins
    Robert
    Oahu
    99 SR5 3.4L 4WD
    Worse for obvious reasons....but your front suspension doesn't "flex" nearly like the rear....and pics aren't going to help you need to turn wheel trim where tire touches, check trim more if you have to. You can also put a jack under the LBJ to "flex" your tire and check trim.....you get the picture
  12. Nov 25, 2016 at 6:38 PM
    #1632
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    BYJOSHCOOK[OP] and ChadsPride like this.
  13. Nov 25, 2016 at 6:44 PM
    #1633
    HSmith_11
    Hunter
    Madison, Va
    What size tires are u running
  14. Nov 25, 2016 at 6:45 PM
    #1634
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Also, I'm still rubbing frame behind the wheel (barely) and the top of the fender wells. Need to shed a little more plastic up there.
  15. Nov 25, 2016 at 6:46 PM
    #1635
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    255/85/16
    Essentially 33x10.5
  16. Nov 25, 2016 at 6:47 PM
    #1636
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    Yep mine looks similar, also running 255/85/16
  17. Nov 25, 2016 at 6:48 PM
    #1637
    BYJOSHCOOK
    BYJOSHCOOK [OP] Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Kinda what I'm thinking, each patch roughly $6 so that could equate to something I'd need
    Dakars and some maintenance stuff
  18. Nov 25, 2016 at 6:49 PM
    #1638
    HSmith_11
    Hunter
    Madison, Va
    That picture is trippin me out for some reason :annoyed:
  19. Nov 25, 2016 at 6:50 PM
    #1639
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Dude, you're going to love the dakars. Had I known what I know now, I would have ran them on my other truck.
  20. Nov 25, 2016 at 6:52 PM
    #1640
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Buddy, it's literally a 10 minute job per side. Don't let it get you down. I bet you none of us have any regrets.
