Cooks 2000 4x4 build with some BS
Discussion in '1st Gen. Builds (1995-2004)' started by BYJOSHCOOK, Jun 19, 2014.
  1. Nov 26, 2016 at 1:19 PM
    #1681
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    D6XL
    ChadsPride likes this.
  2. Nov 26, 2016 at 1:27 PM
    #1682
    BYJOSHCOOK
    BYJOSHCOOK [OP] Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Well if you're going over rocks, I'd say no. That inch will help a ton. Scraped my cross member a couple times while others in 285s never did
  3. Nov 26, 2016 at 1:32 PM
    #1683
    HSmith_11
    HSmith_11 Tacoma Enthusiast
    Hunter
    Madison, Va
    2001 Ext Cab SR5 4x4 MT
    5100/OME 881s 1.5" Progressive AAL 33x12.50X15 KO2s
    I dont really plan on going over too many big rocks. Im also thinking the 265s might give me some mpg back if i swap back to my old rims
  4. Nov 26, 2016 at 2:05 PM
    #1684
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Then go that route. You'll get a little bit back and won't have a need to regear after you add bumpers. Not something I'd do but it's your truck your wallet
  5. Nov 26, 2016 at 2:07 PM
    #1685
    HSmith_11
    Hunter
    Madison, Va
    The 33x12.50s just seem to wide to clear stuff on the inside with only a 2.5" lift
  6. Nov 26, 2016 at 2:17 PM
    #1686
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Are you rubbing anything now?
  7. Nov 26, 2016 at 2:18 PM
    #1687
    HSmith_11
    Hunter
    Madison, Va
    Just a bunch of plastic stuff on the inside and that's with no flex. I'm gonna flex it out sometime soon tho.
  8. Nov 26, 2016 at 3:03 PM
    #1688
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Well cut that plastic! It's nothing
  9. Nov 26, 2016 at 3:04 PM
    #1689
    HSmith_11
    Hunter
    Madison, Va
    Its a little bit of other stuff too lol
  10. Nov 26, 2016 at 3:06 PM
    #1690
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Hammer down!
  11. Nov 26, 2016 at 3:07 PM
    #1691
    HSmith_11
    Hunter
    Madison, Va
    Idk its pretty bad when i back up and i wanna be able to wheel on trails
  12. Nov 26, 2016 at 3:39 PM
    #1692
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Cut/trim and hammer down and you're good
  13. Nov 26, 2016 at 3:44 PM
    #1693
    HSmith_11
    Hunter
    Madison, Va
    Idk im really torn cause idk if i have enough lift and i think the tires are too wide for when i stuff them
  14. Nov 26, 2016 at 3:48 PM
    #1694
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    Lift does not matter for clearing tires. It clears tires at ride height but the suspension still cycles the same way up and down. No matter what your going to have to cut and hammer things to fit your tires.
  15. Nov 26, 2016 at 3:49 PM
    #1695
    HSmith_11
    Hunter
    Madison, Va
    Its mainly the tire width that im worried about
  16. Nov 26, 2016 at 3:56 PM
    #1696
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    Okay, so if it's the width your what rubbing on your frame? Get some wheel spacers. What tire size
  17. Nov 26, 2016 at 4:05 PM
    #1697
    cbechtold
    cbechtold IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    The new one, D43XL would be a better option for you then. The D6XL is only good for 60lbs while the new D43XL supports 220lbs.
  18. Nov 26, 2016 at 4:15 PM
    #1698
    ChadsPride
    Sponsored by TacomaWorld.com
    Wheel spacers will make the rubbing worse
  19. Nov 26, 2016 at 4:19 PM
    #1699
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    How else would you stop rubbing the frame?
    ChadsPride[QUOTED] likes this.
  20. Nov 26, 2016 at 4:19 PM
    #1700
    ChadsPride
    :sawzall:
    Delta00[QUOTED] likes this.
