Cooks 2000 4x4 build with some BS
Discussion in '1st Gen. Builds (1995-2004)' started by BYJOSHCOOK, Jun 19, 2014.
  1. Nov 26, 2016 at 4:55 PM
    #1721
    HSmith_11
    HSmith_11 Tacoma Enthusiast
    Hunter
    Madison, Va
    2001 Ext Cab SR5 4x4 MT
    5100/OME 881s 1.5" Progressive AAL 33x12.50X15 KO2s
    Im not worried about going over big obstacles. Just some trails here and there
    ChadsPride likes this.
  2. Nov 26, 2016 at 4:55 PM
    #1722
    HSmith_11
    Hunter
    Madison, Va
    Huh :eek:
    ChadsPride[QUOTED] likes this.
  3. Nov 26, 2016 at 4:56 PM
    #1723
    cbechtold
    cbechtold IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
  4. Nov 26, 2016 at 4:57 PM
    #1724
    cbechtold
    Cory
    Pleasanton, CA
    Wheeler's says it's for 98-2004 Tacoma 4x4 and Pre Runner.
  5. Nov 26, 2016 at 4:58 PM
    #1725
    cbechtold
    Cory
    Pleasanton, CA
    I'd rather have an easier time with an obstacle then have smaller tires, but that's just me.
  6. Nov 26, 2016 at 5:00 PM
    #1726
    HSmith_11
    Hunter
    Madison, Va
    But i also dont think i will bring myself to trim enough to fit the 12.50 wide tires when they get pushed into the wheel well. And I'll mainly just be daily driving with a few mediocre trails with some buddies.
  7. Nov 26, 2016 at 5:02 PM
    #1727
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    I have 265s on my 2.7, Im not sure what gears you have but with my 4.30s and heavy e load 265/70r17s it does really good. I've had em only in mud, following ford rangers around on 33x12.50 cooper stt pros a while ago before I got the mts
  8. Nov 26, 2016 at 5:05 PM
    #1728
    cbechtold
    Cory
    Pleasanton, CA
    I don't know the trails over in Virginia but if you feel as if you don't need them, then 285 might be a better option for you. They'll be smaller and rub a bit less. Over in California we have some of the hardest trails in the country, so totally understandable. 285 would keep some off road capability, while making it more friendly do drive daily and rubbing with still be better. You'll still rub at full lock when flexing though. There's no way to really eliminate the rubbing there easily.
  9. Nov 26, 2016 at 5:05 PM
    #1729
    HSmith_11
    Hunter
    Madison, Va
    I have the 4.30s as well. What brand tire do u have
  10. Nov 26, 2016 at 5:06 PM
    #1730
    HSmith_11
    Hunter
    Madison, Va
    285s are just barely smaller than 33x12.50s right?
  11. Nov 26, 2016 at 5:09 PM
    #1731
    cbechtold
    Cory
    Pleasanton, CA
  12. Nov 26, 2016 at 5:10 PM
    #1732
    HSmith_11
    Hunter
    Madison, Va
  13. Nov 26, 2016 at 5:11 PM
    #1733
    cbechtold
    Cory
    Pleasanton, CA
    Are you looking to totally eliminate rubbing everywhere? Even at full lock flexed?
  14. Nov 26, 2016 at 5:12 PM
    #1734
    HSmith_11
    Hunter
    Madison, Va
    Im fine with full lock flexed but its really annoying for me over bumps and backing up at full lock and turning at full lock
  15. Nov 26, 2016 at 5:17 PM
    #1735
    cbechtold
    Cory
    Pleasanton, CA
    There's something you can bend back that helps with that. It's right in front of the cab mount on both sides. I bent mine off-roading and bending it back helped with with the rubbing that you're looking for. I still need to bend them back a bit more.
  16. Nov 26, 2016 at 5:19 PM
    #1736
    HSmith_11
    Hunter
    Madison, Va
    But the main problem with my 12.50s is that I'm usually in tight spaces so I'm constantly turning sharp and riding over bumpy areas. And when i go trailriding around here, its mainly little stuff but tight corners and turns
  17. Nov 26, 2016 at 5:25 PM
    #1737
    cbechtold
    Cory
    Pleasanton, CA
    Yea, being the wide tires definitely cause that. You're mainly hitting the body then. Narrower tires might help, maybe some 255/85s, but tubing would eliminate everything for good. I normally don't like to recommend body lifts, but you might be able to get away using a 1" 4crawler body lift. I'd be opposed to using one myself, but other's have different opinions.
  18. Nov 26, 2016 at 5:26 PM
    #1738
    HSmith_11
    Hunter
    Madison, Va
    I dont have the money for much more modification lol
  19. Nov 26, 2016 at 5:29 PM
    #1739
    cbechtold
    Cory
    Pleasanton, CA
    At that point it's hard to help. I don't blame you if you don't have the funds for the truck right now, but fixing the rubbing will either cost some plastic or money.
  20. Nov 26, 2016 at 5:31 PM
    #1740
    HSmith_11
    Hunter
    Madison, Va
    Thats why im looking at the 265/75s cause i already have the rims and i could sell me newer tires and rims to get some money back.
