coolant blowing out!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SEAN B, Apr 16, 2014.
  1. Apr 18, 2014 at 11:11 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    first thing i EVER do is change the radiator cap. it is actually cheaper to try that than to take the car in to a mechanic for a pressure test...a good mech will pressure test the cap as well. if the system cannot hold pressure it will simply boil over.
  2. Apr 18, 2014 at 11:13 PM
    MARSHBUSTER
    MARSHBUSTER Well-Known Member
    Jim
    Alamogordo NM
    2005 SR5 4X4 Tacoma TRD
    Grill Gaurd/ Winch Bumper, Mile Marker 9000 LBS Winch, Custom Head Ache Rack, Custom Rear Bumper, Marathon Camo Max 4 Seat Covers
    Is that why I can hear it boiling in the over flow after I run the truck hard???
  3. Apr 18, 2014 at 11:15 PM
    aficianado
    back to bone stock.
    probably..any time the system cannot hold pressure the water is allow to boil..
    my MIL's car did this..white stuff everywhere. i got it hot and noted a tiny water leak between the plastic radiator tanks and the fins section. new radiator time. i got that white residue because since it was the top seal that leaked, the wind from driving and the fan blew it everywhere.
  4. Apr 19, 2014 at 8:47 PM
    SEAN B
    SEAN B [OP] Well-Known Member
    SEAN B.
    SAN DIEGO
    05 PRERUNNER DCSB
    MODS/UPGRADES DONE- *ICON COIL-OVERS (LEVELING KIT) *TRD INTAKE SYSTEM *TRD CAT-BACK *RIMS & TIRES *WINDOW TINT *OEM TRAILER HITCH *GRILLCRAFT MX GRILL *TRD FRONT SEATS *'09+ OEM LED TAIL LIGHTS *TAILGATE ANTI-THEFT MOD
    It was the radiator cap. All is good for now.
  5. Apr 19, 2014 at 11:00 PM
    MARSHBUSTER
    Jim
    Alamogordo NM
    Guess I am buying a new radiator cap tomorrow!!!!!
  6. Apr 20, 2014 at 6:40 AM
    aficianado
    back to bone stock.
    It usually is :)
  7. Apr 21, 2014 at 8:38 PM
    MARSHBUSTER
    Jim
    Alamogordo NM
    Radiator Cap didn't fix it. Going to try Thermostat next I guess.
  8. Apr 21, 2014 at 8:52 PM
    discoy2k
    discoy2k Well-Known Member
    DISCO
    NOLA
    05 TRDSport 3" Iron Man Coil, Stealth
    2005 to 2012 Front End Replace,2010 TRD Interior,6x Escort Shifters, Escort 9500ix, Escort LIVE w/ 4G Data, 100% Stealth on Interstate,De-Badged Completely,5% Tint Blacked out,Iron Man lift,InfraRed military Humvee Spots, Drive in 0lite,Lexus/Fujisu NAV, dual 8in lcd sun visors, 2 10" kicker solobaric dvc 2ohm, phoenix gold 2000 watt, lunar 100watt @ 1/4 ohm,3 farad cap kicker 250watt,2800watt ,TRU-SINE inverter, dual HID bulb+HID fogs w/ mod, Roof rack,Westin Bull Bar, Manik Side Bars, Sirius/XM (HACKED) Undercover Bed Cover, bosch Wipers, Iridium Plugs, Undercover Bed Cover
    is it only when you run it hard that you here that? and is it only when the truck is running or even when it is turned off?
    cheers,
    disco
  9. Apr 21, 2014 at 9:27 PM
    MARSHBUSTER
    Jim
    Alamogordo NM
    I hear it when I turn the truck off.
  10. Apr 22, 2014 at 9:10 AM
    aficianado
    back to bone stock.
    Is the temp gauge spiking?
  11. Apr 22, 2014 at 9:23 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    If the radiator cap didn't fix it, you still have a leak. Flourescent dye, and a black light will help find the small leaks. You'll need a dark garage to find the source.
    Have you looked at the water pump's shaft, and found any coolane crust? How is your engine temp looking, while this is going on?
  12. Apr 22, 2014 at 4:51 PM
    MARSHBUSTER
    Jim
    Alamogordo NM
    Temp Gauge is Hanging right in the middle and Has Never Spiked.
  13. Sep 2, 2020 at 4:48 PM
    Viking303
    Viking303 Active Member
    Lord Donkey Puncher
    Mile High City
    DCLB
    Jet packs and bazooka blasters all around, Amsoil everything, ARB/ALL-PRO carcass shredderz, A.R.E. Zombie proof topper, Glen Danzig Leather Pant taint stain on the rear seat, no joke and %100 truth!!!! Camburg and long travel in the future. Stoked:)
    MARSHBUSTER, what ended up being the resolve??
  14. Apr 17, 2025 at 4:42 PM
    Lord Kanti
    Lord Kanti BlackJack Taco
    SoCal
    2002 Double Cab 4x4 SR5 TRD Blackout
    Deck plate gray wire Blackout De-badge Lift Tires
    I too would like to know. I noticed my truck bleeding today and when I popped the hood it was pink all over. top of the radiator has a little pink liquid all around, dripping under the length of the radiator underneath but primarily the passenger side and the plastic res on the driver side seems low. Temp gauge never spiked while driving. no noises as far as I could tell. I figure I can try a new cap but am curious to know what else I should check. Thanks!
  15. Apr 17, 2025 at 4:49 PM
    #35
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Sounds like you may need a new radiator, I'd bet OP needs a head gasket replacement.
  16. Apr 17, 2025 at 4:55 PM
    #36
    Red Archer
    Red Archer Well-Known Member
    Marty
    O-hi-O
    01 White Tacoma
    Original with factory replacement parts.
    I did not read through all the replies, so sorry if this is a repeat.
    To see if head gasket is blown, pull each spark plug. Coolant does a great job in cleaning spark plugs.
    If 1 plug is clean, there's the problem. If all plugs are the same, then it's probably something else.
  17. Apr 17, 2025 at 9:23 PM
    #37
    DailyTacoMD
    DailyTacoMD Well-Known Member
    Jeremiah
    2006 2.7L AC 4x4 5spd
    OP has likely buried the truck due to frame rust sometime over the ELEVEN YEARS since he noticed the coolant leak… :evil:
    TireFire likes this.
