coolant fluid
Discussion in '2nd Gen. Tacomas (2005-2015)' started by brandonlamb25, Jul 23, 2013.
  1. Jul 23, 2013 at 6:54 AM
    brandonlamb25
    brandonlamb25 [OP] Well-Known Member
    Georgia
    08 Crewcab Prerunner V6
    K&N Intake, Wet Okole Seat Covers, Ipod to Factory radio hookup kit, Black Low Pro Toolbox, Toytec Coilovers and 285/75r16 BFG MT's
    I've searched and read and know everyone recommends Toyota pink long life coolant but is there a difference in quality between that and Prestone. Prestone is $10 gal vs. $30 gal for Toyota. Thanks
  2. Jul 23, 2013 at 7:07 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2015 TSS sport DC 4x4
    $30 a gallon seems high, i get the toyota red long life at my dealership for that. The pink comes pre mixed 50/50 also so no need to get distilled water. It runs about $15 a gallon. I personally wouldnt use anything else unless stated for Japanese vehicle and was pink. Zerex makes one but hard to come by in my area.
  3. Jul 23, 2013 at 7:12 AM
    brandonlamb25
    Georgia
    Thanks. Keeps the opinions coming.
  4. Jul 23, 2013 at 7:21 AM
    jmg256
    jmg256 Calmer than you are
    Al Tonter
    TRD Offroad
    Bilstein 5100 front/rear (front at .85), Hayden 678 Trans Cooler, 20% tint, Curt Hitch/Wiring Harness, Weathertech Digital Fit Floor Mats (Black), Wet Okole Seat Covers (Black), Cooper Discoverer ATP 265/75/16, LED Map/Dome lights, ImMrYo bracket, Debadged, Extang Tuff Tonno.
    I serviced my cooling system (drain/fill) at the 100k mike mark (as recommended) at the beginning of this summer. I paid ~$25 a gallon for three gallons of the premixed.
    Spendy for coolant? Sure...
    I would stick with the OEM fluid on this truck though...$75 every 100k isn't bad at all.
    Do a bit of research on mixing coolant types, and I think you'll come to the same conclusion.
  5. Jul 23, 2013 at 7:29 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    A couple years ago I paid $24 for a gallon of the red Toyota coolant. Whenever my coolant gets a little low in the plastic tank I mix some 50/50 with distilled water and fill it to the full mark. I've always used Toyota coolant and have never had a radiator problem in any of the Toyota's that I have owned. Is it better than Prestone?? Who knows!
  6. Jul 23, 2013 at 7:32 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    I flushed the OEM coolant at the 3 year mark, and replaced it with Prestone. I wouldn't mix the two though unless you absolutely have to, "should" be fine, but why risk it.
  7. Jul 23, 2013 at 7:56 AM
    brandonlamb25
    Georgia
    Thanks. I guess ill use the Toyota and take back the prestone.
  8. Jul 23, 2013 at 8:08 AM
    Collins
    Collins Well-Known Member
    North Carolina
    09' Tacoma, 2.7L, 5spd, 4x4
    I'm using the Zerex 50/50 stuff with no issues so far.
    I do have to add a bit to the reservoir from time to time,
    so it's a thing i keep an eye on when under the hood,
    not sure why it's using fluid...no leaks i can see...
    nothing weird in the oil either?
    tis normal?
    PC
  9. Jul 23, 2013 at 8:19 AM
    DirtEater
    DirtEater Well-Known Member
    Surprise, AZ
  10. Jul 23, 2013 at 8:34 AM
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    It's not a matter of whether the Toyota or Zerex extended life is better or worse than Prestone, bottom line is is the anti freeze formulated for the metals in your radiator. I'd stay away from Prestone as the additives in it corrode the inside of the Tacoma Radiator. Either spend the money for anti-freeze or replace your radiator and water pump....you do the math.
    You should be fine with the Zerex Asian formula. If there's an Oreilly's near you, they have it for $14.99 a gallon.
  11. Jul 23, 2013 at 8:47 AM
    j0sh
    j0sh Well-Known Member
    Oklahoma
    '10 TRD Sport 4x4
    AFE Filter, TRD Catback
    Everything that I gathered was that the Zerex asian stuff and the toyota are made by the same place. I did lots of reading before adding some to mine.
  12. Jul 23, 2013 at 10:04 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    What data led you to this statement? Not challenging, curious, as I did not find that same info.
  13. Jul 23, 2013 at 10:51 AM
    blm
    blm Well-Known Member
    Anytime I see something like this I ask myself the following question. Does Toyota manufacture its own coolant? The answer to that as far as I know is "NO". So that means that someone else is manufacturing the Toyota brand coolant and just putting a Toyota label on the jug. It could even be Prestone for all we know. The Toyota coolant is no better or worse than any other coolant. Just costs 3 times as much.
  14. Nov 2, 2013 at 5:43 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Here is tech bulletin http://www.valvoline.com/pdf/zerex_asian_vehicle.pdf
    And it says it's available at Napa and Oreilly http://www.valvoline.com//products/brands/zerex/antifreeze/105
    Anyone have the Toyota coolant info?
