Coolant level gen 3
Discussion in '3rd Gen. Tacomas (2016-2023)' started by WiscTaco01, Nov 6, 2019.
  1. Nov 6, 2019 at 3:09 PM
    WiscTaco01
    WiscTaco01 [OP] Member
    2018 black trd off road 4x4
    American Roll Cover Blackvue 2 ch dash cam
    Sorry if this has already been discussed, but have not found it yet. I have 2018 Tacoma 3.5L with 37,000 miles. And noticed that my coolant reservoir tank is just about empty. Am getting coolant soon to add and monitor. Engine oil samples test great.
    Long short... Has anyone else had issues like this? It just worries me because this leads me to think head gasket
  2. Nov 6, 2019 at 3:37 PM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    First off calm down because you don't know whats wrong yet.
    1. Do you park in the same spot either at home or work? If so, have you noticed any fluids where you park?
    2. How many times have you looked at the level since you had the truck?
    3. Who has serviced the truck?
    For now, you need to do like you said, fill her up and monitor. It could be a simple hose leak. Dont worry just yet.
    Chew and GreyBaldTaco like this.
  3. Nov 6, 2019 at 3:41 PM
    MaynardVanZant
    MaynardVanZant No.
    Alaska
    2017 DCSB TRD OR MT
    MBRP Catback 2” Bilstein 5100 lift
    Coolant has water in it. It goes through a bajillion heat cycles. Water evaporates. I would expect to have to top off the cooling system at 37,000 miles and wouldn’t think twice about it.
  4. Nov 6, 2019 at 3:41 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    There's a plastic crossover tube behind the engine by the firewall that has been known to leak.
    wahoobie and Ronzio like this.
  5. Nov 6, 2019 at 4:16 PM
    WiscTaco01
    I service it. Park in same spot. I've been watching it since new. Every 500 miles or less pop hood and check it all out. Just noticed it starting to go down in coolant maybe 2,000 miles ago. I'll look at the tube skydvrr mentioned. Thank you everyone.
  6. Nov 6, 2019 at 4:18 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Fwiw mine varies a lot. Sometimes when I shut it off, it's low. Sometimes it's normal :notsure:
  7. Nov 6, 2019 at 4:23 PM
    WiscTaco01
    Yeah I agree, same here. There is the paint mark, where they marked it at the factory or dealer for level on tank. But now she is just about empty. Thought I'd ask the wise people on this forum if they had any tips. Or at the very least. Remind people to check things out and things of that nature
  8. Nov 6, 2019 at 4:29 PM
    Hank Heel
    Hank Heel Well-Known Member
    WA
    Noticed the same this on my 17, oddly enough with similar miles too.
    Checked that prone-failure-plastic-tube near firewall and it was all good. Everything else is dry everywhere. Oil is clean too.
    To be fair, mine was at minimum mark when i noticed. Ended up adding some coolant and calling it a day.
    Chalking it up to evaporation as I saw some white chalky residue in the overflow area.
  9. Nov 6, 2019 at 4:40 PM
    trd09
    trd09 Well-Known Member
    Chuck
    NW Ark
    17 TRD Pro 6AT
    Had this issue with my 2017
    Skydvrr[QUOTED] likes this.
  10. Nov 6, 2019 at 4:50 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Bummer. I've been lucky so far
  11. Nov 6, 2019 at 5:33 PM
    ancient11
    ancient11 Well-Known Member
    robert
    tallahassee
    2019 4 cyl srsx ac
    Had the same issue with my previous '17 with similar miles but was only down maybe 2"
  12. Nov 8, 2019 at 10:50 AM
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    Is this plastic tube/fitting visible without removing any covers, etc....? Can anyone steer me towards identifying this part? I have been monitoring and refilling for some time but have not seen anywhere that it might be leaking.
  13. Nov 8, 2019 at 11:08 AM
    AKGSD
    AKGSD Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
    I had some boil over driving through death valley. Evident by dried coolant on the tank though
  14. Nov 8, 2019 at 11:59 AM
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    It's on the back of the engine against the firewall.
    https://www.tacomaworld.com/threads/2017-tacoma-coolant-leak.492860/page-3#post-16222247
    https://www.tacomaworld.com/threads/2017-tacoma-coolant-leak.492860/page-4#post-16233680
    https://www.tacomaworld.com/threads/2017-tacoma-coolant-leak.492860/page-2#post-15235121
  15. Nov 8, 2019 at 6:17 PM
    swimmer
    Tucson
    2016 TRDORAC4WD
