Coolant
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jerry07$, Nov 29, 2024.
  1. Nov 29, 2024 at 10:52 AM
    Jerry07$
    Jerry07$ [OP] Active Member
    2019 Tacoma SR5. I have 78,000 miles on the truck and did a drain fill on the coolant today, (radiator and block). I used Peak red/pink for Asian vehicles. Burped the system drove it around a few miles no issues. My question is, is that coolant OK to use in this truck?
  2. Nov 29, 2024 at 10:56 AM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
    Yes.
    SH10151 likes this.
  3. Nov 29, 2024 at 10:58 AM
    Jerry07$
    I thought it was. All this maintenance besides oil changes is new to me, just want to use the right parts and do a good of a job as I can so the truck will last. Thanks!
  4. Nov 29, 2024 at 11:01 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Good thing to verify, but most get this type of assurance prior to doing the work, not after! :)
    86_MR2, davidstacoma, 69 Jim and 5 others like this.
  5. Nov 29, 2024 at 12:19 PM
    Kabogski
    Kabogski Sport Rally Five
    Bote
    Los Angeles
    17' MGM - Anim na Piston.. Sport Rally Five
    Hi tuck Exhaust FalkenWildPeaks Blackout Badge
    If it Burps, it means he likes it.. :rofl:
    musicisevil likes this.
  6. Nov 29, 2024 at 12:52 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    still check it after a few days may still have a couple of burps left. fill right the the line and it should never drop below'
    mine started to drop below just slightly from time to time then i discovered i had the famous cross over pipe leak.
    had that fixed and stays right at the fill mark now.
  7. Nov 29, 2024 at 3:54 PM
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    What's the price diff of Toyota vs Peak? Sometimes OEM is nearly the same price as Peak or Prestone so you don't get the mixing hinkies.
    69 Jim likes this.
  8. Nov 29, 2024 at 3:57 PM
    69 Jim
    69 Jim 4-word Jimmy
    PNW
    2013 Standard Cab 4x4
    Good question, oem is very reasonable, and is the best IMHO.:thumbsup:
    SH10151 likes this.
  9. Nov 29, 2024 at 5:51 PM
    Jerry07$
    Thanks for the input and advice. I used peak because it was available and I have limited free time so I wanted to get it done. Thanks.
  10. Nov 29, 2024 at 5:54 PM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    Assuming it’s the red pink stuff, it’s fine.
  11. Nov 30, 2024 at 10:31 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    The name “Peak red/pink for Asian vehicles” makes me think of a porn site more than antifreeze.
    What exactly is special about this antifreeze that makes it specific to Asian automobile brands?
    My guess is that there is nothing special about the cooling systems in Asian branded automobiles, but there is a difference in what the various brands recommend for coolant.
    Some limited reading suggests that some modern coolants are not compatible with each other (e.g, OAT vs HOAT), so it seems important to not mix them. If you completely drain the current coolant, mixing of non-compatible coolants is not an issue.
    https://www.google.com/search?q=poat+oat+hoat+coolant&ie=UTF-8&oe=UTF-8&hl=en-us&client=safari
  12. Feb 3, 2025 at 7:51 AM
    s.e.charles
    s.e.charles Well-Known Member
    i just called a local dealer - toyota coolant x gallon is $27.77 + tax
    sound right?
  13. Feb 3, 2025 at 9:05 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
  14. Feb 3, 2025 at 9:08 AM
    Barsoom
    Barsoom Well-Known Member
    NW GA OTP
    Thread resurrection.
    Asian coolants do not have silicates (hard on the seals and water pumps), or 2-EHA, like Dexcool (aka Deathcool). They use Phosphate, instead of silicates and use a different organic acid for protection. Some organic acid are plasticizers (2-EHA is one of the more infamous one). They will soften up and melt plastics.
    PS Never mix All Makes/All Models coolant. It has 2-EHA and silicates and it WILL gel up in your coolant system.
    More than you ever wanted to know about coolants:
    https://bobistheoilguy.com/forums/forums/cooling-system-fluids-additives.35/
    gudujarlson[QUOTED] and t0p_d0g like this.
