Cooling fan is loud
Discussion in '1st Gen. Tacomas (1995-2004)' started by NickJ*97756, Jan 2, 2011.
  1. Jan 2, 2011 at 1:03 PM
    NickJ*97756
    NickJ*97756 [OP] Well-Known Member
    Nick
    La Grande OR
    95 Red Ext. Cab
    Black Ultra Type 175 Rogue wheels, 33x12.50's, exhaust, sony deck,JL tweeters, hella 500ff's, painted rear bumper, brush guard, tail lights, kc's, custom tube bumper,5100's w/trd springs, toytec aal, custom tire carrier
    After i filled up with gas yesterday i started up my truck and the fan from the engine bay was extremely loud. it has not gone away and sounds like a dam airplane. anybody know why it sounds like this? my belts started squeeling at areound 3k rpm too. any help appreciated
  2. Jan 2, 2011 at 1:34 PM
    NickJ*97756
    Nick
    La Grande OR
    95 Red Ext. Cab
    bump
    anybody?
  3. Jan 2, 2011 at 1:34 PM
    Fati Tacoma
    Fati Tacoma Well-Known Member
    my fan is loud when it kicks in but I'm pretty sure thats how it's suppose to be. There would be an issue if the fan never kicks off tho, not sure its a clutch system on the fan (just got my truck and its in the shop now so I cant check it). Just remember man, it's a truck, not an infinity Q45...
  4. Jan 2, 2011 at 3:18 PM
    TacomaJPP
    TacomaJPP To secure peace, is to prepare for war
    East TN
    03 4WD TRD XTD Cab
    Snugtop Camper Brushguard
    4cyl or V6
    By loud, do you mean squeaky, what type of loud?
    Have you done anything to that part of the truck lately, ie, replace accessory belts, water pump, etc?
  5. Jan 2, 2011 at 6:25 PM
    NickJ*97756
    Nick
    La Grande OR
    95 Red Ext. Cab
    The fan is loud. not squeeky just loud. I haven't done anything to it lately. I think the clutch fan is bad because the fan is just on constantly and the more gas you give it the louder the fan gets.
  6. Jan 2, 2011 at 6:26 PM
    NickJ*97756
    Nick
    La Grande OR
    95 Red Ext. Cab
    Oh and it is the 2.7 4cly
  7. Jan 2, 2011 at 6:50 PM
    TacomaJPP
    East TN
    03 4WD TRD XTD Cab
    My fan is on constantly too, but it's not loud like you describe. Maybe the clutch fan is bad.
  8. Jan 2, 2011 at 7:01 PM
    NickJ*97756
    Nick
    La Grande OR
    95 Red Ext. Cab
    ya thats what i was thinking. Thanks for the help
  9. Jan 2, 2011 at 8:07 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Sounds like the fan clutch is shot. They're heat activated... to test it, try spinning the fan with your hand when the engine is cold (and NOT running... hopefully I don't have to tell you that) It should be easy to spin as the cooling fan isn't needed when the engine is already cool. Now, when the engine is hot (and again NOT running) try spinning it again. It shouldn't spin because the clutch is engaged.
    You may have an entirely different problem... i've noticed what you're talking about how when you start it up and the fan really roars for a few seconds, but mine always stops. I have no idea what could be wrong if yours doesn't stop
  10. Jan 3, 2011 at 9:42 AM
    vantaco
    vantaco Well-Known Member
    02 Taco Xtracab TRD Step Side
    upgrade to electric fans....that's my plan for the summer
  11. Jan 3, 2011 at 11:02 AM
    PnoyBOS5
    PnoyBOS5 Well-Known Member
    kevin
    CA
    2013 PRERUNNER
    Maxtrac 4'' Spindes -Bilsteins 5100 @ 1.75" - All Pro Expo Leaf Pack - Extended Rear Shocks - PC 5001 wheels - 285/70/17 Goodyear Duratracs - Debadged -Red emblem - AFE Pro Dry-S Filter
    mine does that for only a few seconds on start up.. i like it hheheeh. it sounds like VROOOM.....
  12. Jan 3, 2011 at 11:20 AM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    ur belts are slipping if they are squeeling... check them to make sure they don't need replacement or are not loose...
    cruxofthebisquit likes this.
  13. Jan 3, 2011 at 11:38 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    x2, belts may be glazed too, my truck always engages the fan clutch for a few secs. when started cold ( I thought they did only when hot) so guessing its normal for these trucks
    if the "loud fan" is constant, clutch is failing, with engine off , pop the hood & grasp the fan blade & spin by hand, there should be slight resistance, if you can't easily move it at all or if it won't budge then it's fan clutch time...
  14. Jan 3, 2011 at 6:47 PM
    NickJ*97756
    Nick
    La Grande OR
    95 Red Ext. Cab
    So do you guys think i should replace the fan clutch and all the belts?
    I was going to do that this morning
  15. Jan 8, 2011 at 10:25 PM
    NickJ*97756
    Nick
    La Grande OR
    95 Red Ext. Cab
    I just replaced all the belts and the fan cluch and the fan is still loud. Do i have to wait for the new clutch to break in? is there anything else that could be causing a loud fan?
  16. Jan 9, 2011 at 5:15 PM
    NickJ*97756
    Nick
    La Grande OR
    95 Red Ext. Cab
    bump
    Anybody?
    After i replaced the fan clutch the fan spins easy now with my hand but the fan is still on constantly and is really loud. Could the new cluch be bad?
  17. Apr 21, 2019 at 11:49 AM
    aaronhogiemon
    aaronhogiemon New Member
    Hi Nick,
    I am having the same thing going on. Did you ever find out what was going on?
    Thanks, Aaron
  18. Apr 21, 2019 at 12:01 PM
    Clearwater Bill
    Billy
    Largo Florida
    That was a thread from 8 yrs ago and Nick hasn't been around since 2015.
    Just so you're not disappointed if you get no reply. ;)
  19. Apr 21, 2019 at 3:31 PM
    tony2018
    tony2018 Well-Known Member
    Usually is loud at startup, or cold startup. If the fan is loud when your at a gas station filling up then the truck should already be warmed up and the clutch might be going out or needs the fluid changed out. There's a link or a thread where someone shows you how its done. Was it @mechanicjon who talked about it?
