Cooling issues? Not anymore
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Deo taco, Aug 25, 2020.
  1. Oct 12, 2020 at 8:27 AM
    #361
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Thanks brother. :thumbsup:
  2. Oct 12, 2020 at 8:36 AM
    #362
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    Sub’d will read through later. Hopefully Power draw and air movement spec’s are in here someplace. Very interested in this.
  3. Oct 12, 2020 at 8:39 AM
    #363
    Deo taco
    Deo taco [OP] Well-Known Member
    2017 trd pro in cement grey.
    Lots to come
    the air move specs are under lock and key with the OEM. but since i already have released for gm the 600w version to fix corvette track overheating issues this 834w fan is going to be overkill. power draw at max should be about 70amp
  4. Oct 12, 2020 at 8:41 AM
    #364
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Which will mean AC performance at idle will be through the roof and super ice cold on really hot days. ;)
    Torspd and MattCowsmasher like this.
  5. Oct 12, 2020 at 8:50 AM
    #365
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    @Deo taco if this will add a max 70amp current draw to the truck, what will the avg current draw be approx ? 70amps is like adding a second massive stereo system to your truck so I am wondering about the weak OE alternator output. IE: If I already have a ton of accessories and a high end audio system is my oe alternator going to be able to keep up with this ?
  6. Oct 12, 2020 at 8:57 AM
    #366
    Deo taco
    Lots to come
    remember that is only at MAX fan speed. i highly doubt any truck will command more then 60 to 70%
    12TRDTacoma and MattCowsmasher like this.
  7. Oct 12, 2020 at 9:02 AM
    #367
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Less than 20 amps most likely
    Some of the PWM set ups have an ac override where the fan is on max speed when the ac is on. Not sure if OP added this feature.
    12TRDTacoma likes this.
  8. Oct 12, 2020 at 9:04 AM
    #368
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    We're gonna race when I get my 2mph back !
  9. Oct 12, 2020 at 9:11 AM
    #369
    anthony250f
    Anthony
    San Diego, CA
    Haha! I’m likely going to do this same set up. Been chasing running hot issues for years in my truck.
    MattCowsmasher likes this.
  10. Oct 12, 2020 at 9:39 AM
    #370
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    If I missed it, what's pricing going to be like?
    Dirk Diggler likes this.
  11. Oct 12, 2020 at 10:25 AM
    #371
    Deo taco
    Lots to come
    i am working as hard as i can on pricing and getting bulk buy deals on the sourced parts.
    aboftofbeam and 12TRDTacoma like this.
  12. Oct 12, 2020 at 11:03 AM
    #372
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    Good job OP. It' still kinda mind boggling that Toyota left a pretty significate MPG improvement on the table for what is a relatively common and easy update.
    Ol'gray mare and RedWings44 like this.
  13. Oct 13, 2020 at 3:00 PM
    #373
    12TRDTacoma
    Rob
    Concordia
    Boosted
    70% duty would imply a 49 amp draw. A 60% duty at max effort would imply a 42 amp draw. Looks like I may need to replace my alternator when I get this setup because mine does not like heavy amperage draw that my sub gives it when it is pounding around.
    MountainManGuy likes this.
  14. Oct 13, 2020 at 7:11 PM
    #374
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    Sub'd This would greatly increase the air movement and decrease the trans temps while towing slow on dirt roads. Maybe I will get around to installing my CSF radiator if I get this also.
    aboftofbeam likes this.
  15. Oct 13, 2020 at 7:18 PM
    #375
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
  16. Oct 14, 2020 at 1:59 PM
    #376
    Markc1024
    Markc1024 Well-Known Member
    The challenge with trans temps is the 195 degree thermostat at the tranny. I've got an aftermarket trans cooler, which helps keep it below 200 most of the time, but it still warms up to 195.
  17. Oct 14, 2020 at 2:04 PM
    #377
    12TRDTacoma
    Rob
    Concordia
    Boosted
    What does the t stat look like? Or is it internal to the tranny? I would be curious as to whether or not the thing can be replaced, or even eliminated from the equation.
  18. Oct 14, 2020 at 2:12 PM
    #378
    Skydvrr
    Nick
    YMH
    Black '17 OR
    It can be pinned so it's always open. There's pics of it in the trans fluid check thread
    12TRDTacoma[QUOTED] likes this.
  19. Oct 14, 2020 at 2:27 PM
    #379
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I would highlight in this mod that that should be done in conjunction with the mod itself somewhere in the instructions or in the online write up as a footnote or something then.
  20. Oct 14, 2020 at 2:47 PM
    #380
    Skydvrr
    Nick
    YMH
    Black '17 OR
    I never pin mine. There's a couple of schools of thought associated with that mod.
