Cooling issues? Not anymore
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Deo taco, Aug 25, 2020.
  1. Nov 3, 2020 at 7:03 AM
    #421
    Deo taco
    Deo taco [OP] Well-Known Member
    2017 trd pro in cement grey.
    Lots to come
    hey guys sorry for the delay but me and the fam all got covid. we are thru it now and back on the project. i will be opening up a group buy thread today for the kit. it will be 15 spots for the first run.
  2. Nov 3, 2020 at 7:07 AM
    #422
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    Uh oh
    Skydvrr likes this.
  3. Nov 3, 2020 at 7:07 AM
    #423
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    depending on price i'd be down for two kits
    MattCowsmasher likes this.
  4. Nov 3, 2020 at 7:13 AM
    #424
    12TRDTacoma
    Rob
    Concordia
    Boosted
    More info. We want more info!!!!!
  5. Nov 3, 2020 at 7:20 AM
    #425
    Deo taco
    Lots to come
    MountainManGuy likes this.
  6. Nov 3, 2020 at 7:21 AM
    #426
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    Can't find it in here but will this kit fit the second gens as well?
  7. Nov 3, 2020 at 7:21 AM
    #427
    Deo taco
    Lots to come
    i have not had a second gen to fit it to. but a tacoma world guy measured his shroud and it seems to be the same opening.
  8. Nov 3, 2020 at 8:39 AM
    #428
    Deo taco
    Lots to come
    4 spots down already 11 left
  9. Nov 4, 2020 at 8:33 PM
    #429
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Update with my fan:
    Got the AEM temp sensor installed with the moshimoto sensor housing into the upper Radiator hose. Lingenfelter module all done and programmed. I hooked the power up to an ignition in cab which comes one with the key(nothing in the engine bay is a true switched power)
    Took the truck out and beat on it.
    It tripped my 60A circuit breaker(I need to up it to 80A) and The whole Time I didn’t realize it wasn’t running(truck was loud enough)...temps ran away from me. So quick that it reached max and truck shut off due to high coolant temp:facepalm:
    After getting power back on the module wouldn’t power the fan since it was higher than the max programmed temp. Had to unplug it, dial it up to 300 and plug it back in. Lesson learned I’m DEFIANTLY wiring in an over ride switch.
    most of it was my fault, but I’m getting it dialed in. Once it’s running this fan is a BEAST. At 100% it sounds like a jet engine about to take off. I was praying my mounts were in there solid because if that thing let’s go, all hell will break loose(no pun).
    Overall I’m impressed, just need to figure out the programming a little more on the module. Thanks OP for leading the way on this mod:cheers:
  10. Nov 4, 2020 at 8:51 PM
    #430
    Deo taco
    Lots to come
    When the controller is setup right it never really hits anywhere near 100% and yes st 100% it sounds like the truck could fly
  11. Nov 5, 2020 at 7:44 AM
    #431
    brentano
    brentano Well-Known Member
    2017 TRD OR AC SSM
    Shit Hit the Fan Operation
    Your fail mode interests me because I worry about the reliability of this system when I am boondocking.
    Without a aftermarket guage, the only problem indication you had was the idiot console temperature guage and ultimately the "High Engine Coolant Temperature" display on the Taco multi-function display? I don't (yet) have a twin turbo with a resonant side exhaust, so the absence of the air boat decibel level I guess would also be an indicator. :)
    Did the Tacoma ECT shut off your engine? So after resetting the circuit breaker, you had to engage the fan and cool it down with IGN on but strictly off the battery because your alternator was not running? That high amp draw (<60A) must have strained even your small (34?) Northstar battery a bit depending on the cooling time.
    The Lingenfelter manual states on page 8, paragraph 2 that the fan should operate at maximum speed when the input temperature is greater than the Max Output Temp setting. This is contrary to your experience where you had to dial it up to 300 to make it work.
    So you defiantly (?definitely?) would install an override for the failure condition you experienced. Are there other circumstances where you might make use of the override switch?
    My first take away to accompany this customization is to consider a battery with more reserve and to configure the Ligenfelter override polarity for +12 activation (page 5) and dedicate a button on my SwitchPro to the override.
    And when the Lingenfelter bellies up, are we all SOL, even with an override?
    BigWhiteTRD likes this.
  12. Nov 5, 2020 at 10:19 AM
    #432
    Deo taco
    Lots to come
    there is alot going on here. the failure mode of the lingenfelter kit is to go to 100% command if the CONTROLLER dies. where as his failure mode was the too small of a fuse issue. for that its simple. amps=watts/volts. so if we have a 843w fan operating on a 12v system it requires a minimum 69.5 amps to run at 100% thats why a 80-100 amp fuse is used.
  13. Nov 5, 2020 at 10:43 AM
    #433
    brentano
    2017 TRD OR AC SSM
    Yes, the reason for @MESO failure is simple. My interest is in the after effects of a Ligenfelter failure (for unknown reasons) and ways to work around the failure when in the wild.
  14. Nov 5, 2020 at 10:48 AM
    #434
    Deo taco
    Lots to come
    well there are 2 ways to deal with a failure out in the wild. run at 100% command and know you system is cool. 2 remove the fan housing and electric fan and install the mechanical you packed with you. there is no issue reverting back at all.
  15. Nov 5, 2020 at 10:58 AM
    #435
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    So can the DIP switches be Configured to switch to 12V+ override? That would be super handy with the switch pro. Or taking into the AC compressor compressor :anonymous:
  16. Nov 5, 2020 at 11:04 AM
    #436
    Deo taco
    Lots to come
    the system you got is already programed for 12v activation and the white wire on the controller can plug into a switch pro or any switch on 12 volt and will be user command on.
  17. Nov 5, 2020 at 11:05 AM
    #437
    Deo taco
    Lots to come
    ill make a video and post it later today of a walk thru of the setup
  18. Nov 5, 2020 at 11:14 AM
    #438
    Skydvrr
    Nick
    YMH
    Black '17 OR
    I only briefly looked at it and I assumed it was ground switched.
  19. Nov 5, 2020 at 11:28 AM
    #439
    brentano
    2017 TRD OR AC SSM
    So, in an emergency, 100% command could be achieved by completely eliminating a failed Ligenfelter module from the kit and grounding the PWM input signal on the fan?
  20. Nov 5, 2020 at 11:52 AM
    #440
    Deo taco
    Lots to come
    yes the default is to open circuit and let the fan run
