Cooling issues? Not anymore
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Deo taco, Aug 25, 2020.
  1. Nov 5, 2020 at 11:52 AM
    #441
    Deo taco
    Deo taco [OP] Well-Known Member
    2017 trd pro in cement grey.
    Lots to come
  2. Nov 8, 2020 at 1:29 PM
    #442
    brentano
    brentano Well-Known Member
    2017 TRD OR AC SSM
    Anyone planning on using the blue (0 - 5V) output signal of the controller module for in-cab monitoring of fan speed or coolant temperature?
    Seems like a handy “idiot light” for the efan system.
  3. Nov 8, 2020 at 4:22 PM
    #443
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I have an old phone that'll always be on with OBD fusion. Although your method sounds sweet
    PapaRee likes this.
  4. Nov 8, 2020 at 4:58 PM
    #444
    Skydvrr
    Nick
    YMH
    Black '17 OR
  5. Nov 8, 2020 at 5:07 PM
    #445
    Tacospike
    Two Trucks
    Skydvrr[QUOTED] likes this.
  6. Nov 8, 2020 at 5:37 PM
    #446
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Thanks buddy!
    Tacospike[QUOTED] likes this.
  7. Nov 8, 2020 at 7:07 PM
    #447
    brentano
    2017 TRD OR AC SSM
    Was the circuit breaker part of the kit or your addition? Amperage?
    The breaker and Ligenfelter are just VBM’d to the top of the fuse box?
  8. Nov 8, 2020 at 7:16 PM
    #448
    Skydvrr
    Nick
    YMH
    Black '17 OR
    My 80a circuit breaker was an add on. @Deo taco crunched the numbers and sent an 80A fuse plus @MESO had issues with his self assembled kit with a 60A breaker so I opted for an 80.
    I cut out some aluminum sheet and added rivenuts to attach it to the underside of the switch panel. God I love rivenuts.
    nudavinci64 likes this.
  9. Nov 8, 2020 at 7:28 PM
    #449
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Looks awesome. Still considering doing this. Now that it’s near winter it hasnt been as much of an issue
  10. Nov 10, 2020 at 3:53 PM
    #450
    point45
    point45 Well-Known Member
    SoCal, OC
    05 DCSB TRD offroad
    Getting this to take care of the weak AC at idle, just need to see if my current fuse subpanel will be able to handle the extra load.
    I see where an 80amp fuse was used but with a 60% load that shouldnt really need more than 50 or 60amps right?
    My current panel has a 100amp breaker with it feeding aux lights and locker, largest load using a 25amp fuse.
  11. Nov 11, 2020 at 6:17 AM
    #451
    Deo taco
    Lots to come
    i would suggest running this as we wire it for you. we have a dedicated inline fuse for the fan only.
    Skydvrr, 3JOH22A and mightytacoman like this.
  12. Nov 17, 2020 at 7:01 AM
    #452
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
  13. Nov 17, 2020 at 7:55 AM
    #453
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Skydvrr likes this.
  14. Nov 17, 2020 at 8:01 AM
    #454
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    There is a controller in the kit. It's adjustable and all. I'm just looking around for a cheaper option than what's here. $350 is a lot less than $1k (JEGS has it for $341). There are definite differences between the two kits, but I wonder if it's that huge when all is said and done.
  15. Nov 19, 2020 at 10:36 AM
    #455
    racebug68
    racebug68 Well-Known Member
    Travis
    Chandler, AZ
    05 DCLB 4x4 TRD SPORT SILVER
    I can't leave anything well enough alone
    I would like some sort of opinion statement for this efan setup, or reasoning behind the idea of putting the temp probe in the top radiator hose (hot side) as opposed to the bottom (cold side). I completely understand why the OEM coolant temp is in the manifold, it is the running temperature of the engine and needs to be measured where it is the hottest. However, in my mind, the radiator with no fan running could be doing an adequate job of cooling the fluid due to the velocity pressure of air flowing through it at speed. You don't need to ramp up a fan to make the radiator more efficient, until the outlet temp of the cooler isn't sufficiently cooled. That is when you need to make the radiator do better, which could be due to slow speed and heavy load, or heat soak, or whatever. But I would think that you would want to let the radiator do it's thing without the fan running, then ramp up the fan when the radiator outlet temperature with natural airflow is not sufficient for the incoming coolant to the engine. Manual override when you want air conditioning prior to the truck being up to full temp or something.
    I don't feel like we should always want the fan to be running. would be good if it turned itself off, even at full running speed if the radiator alone was doing the job? I mean, I doubt the fan needs to run at all when doing flat ground at 65-70 in 50degree or colder weather, regardless of engine temp, since the outgoing coolant temp is below the thermostat temp, which should be causing the thermostat to modulate, or at least restrict some flow due to the outlet temp most likely being way below 180 degrees?
    Please convince me. Maybe I understand something incorrectly. I come from a world of air-cooled VW, this new fangled liquid cooling system may have me confused... and perhaps I don't have the right thought process on how cool the cold side of the radiator is in relation to thermostat opening temp, or the factory coolant temp sensor reading.
    Pinchaser and Kev250R like this.
  16. Nov 19, 2020 at 12:16 PM
    #456
    Deo taco
    Lots to come
    well there are a couple of things here to address.
    you want the fan somewhat running to help clear the air passing thru the rad. creating a negative pressure zone behind the rad is always better then just trying to force air thru a radiator. also have the fan already spinning allow for proper and responsive changes in speed. these fans are set to soft start so they can take about 5 to 10 seconds to spin up.
  17. Nov 19, 2020 at 12:22 PM
    #457
    Deo taco
    Lots to come
    also in every scenario the times an engine burns down is like 99% at idle or 0 vehicle speed (unless on a race track at WOT all the time). the radiator cant get the air thru it and the engine continues to heat up. so having a good close to thermostat breach temp stabilization is key to ensure the engine is running at optimal temperature. alot of people believe lower thermostats help. they do but a lot don't take into account that it can also change the oil viscosity requirements for that engine. you now operate at a low temperature but don't correct your oil and that can lead to the pump over working. this is all a balance and for every truck and owner its different. almost every modern car will have the fan on at a low command like under 30% at almost every driving situation just to ensure airflow optimization.
  18. Nov 19, 2020 at 2:39 PM
    #458
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Hot side probe is responding to engine temp, cold side is controlling the engine temp. My efan set up has the temp probe on the cold side (by bottom driver tire). I have my fans set up to kick on and start ramping up at/after 185°F. I find in the colder winter months- the fan hardly has to run at all as the oversized csf radiator is doing a good enough job.
  19. Nov 19, 2020 at 3:07 PM
    #459
    racebug68
    Travis
    Chandler, AZ
    This is my point. Just because the engine is up to temp, doesn't mean that the coolant entering the engine needs to be even cooler. If the radiator is cooling the fluid that is entering the engine, so that the coolant exiting the engine is the right temp to keep the thermostat flowing somewhat, then you are good without needing to spin the fan at all.
    I'm not saying there isn't merit to running the fan somewhat all the time, but when the radiator alone cannot keep the fluid entering the engine in check is when the fan should run harder.
    This doesn't speak to the need to have airflow through the AC condenser prior to truck warming up.
    Moving or not, negative pressure behind radiator or not, it either can remove the BTUs of energy from the airflow that exists or it can't. if the cold side coolant is too hot, then the fan needs to ramp up to control it. Or am I missing something fundamental on Engine theory here?
    Maybe it doesn't really matter where you put the probe, but the controller just needs to be adjusted to suit. But I can think of times when the hot side temp will be spiking due to huge engine loads, but due to outside air temp and airflow through radiator at speed, the cold side temp is still well within check.... and there is no need for the fan to be doing anything extra...
    This is how the stock mechanical fan works right? if the air coming off the radiator is still cool enough, the clutch will unlock somewhat even if you are at speed. but when it gets hot due to air off the radiator as a proxy for hot side coolant temp, the fan clutch locks up and works harder to move more air.
    I am seriously waffling on getting this kit, but so far even in phoenix az area I haven't had a problem with the cooling system... or AC temps... but I have yet to install the blower that is sitting in the garage and hard to evaluate how that will change things.
    Pinchaser likes this.
  20. Nov 19, 2020 at 3:51 PM
    #460
    Big geek
    Big geek Well-Known Member
    This. Predictive > Reactive.
