Cooling issues? Not anymore
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Deo taco, Aug 25, 2020.
  1. May 27, 2021 at 9:09 AM
    #581
    Deo taco
    Deo taco [OP] Well-Known Member
    2017 trd pro in cement grey.
    Lots to come
    the part of this i find interesting is that if its a fan issue or failure then you should be having issues at idle. fans are basically not even need (maybe a tiny bit) above 45mph. you having the issue at highway speeds leads me to think there is a coolant flow issue or a air blockage in the rad.
    Skydvrr likes this.
  2. May 27, 2021 at 11:30 AM
    #582
    Deo taco
    Lots to come
    to all watching the thread we are working thru the situation. we are not seeing any amount of coolant flow and are working to figure out what is wrong.
    JDKred, Torspd, Skydvrr and 1 other person like this.
  3. May 27, 2021 at 11:36 AM
    #583
    TWTaco
    TWTaco Well-Known Member
    Dave
    Thanks John.
    Still letting it cool down to start checking for blockage.
    Skydvrr likes this.
  4. Jun 8, 2021 at 11:27 AM
    #584
    brentano
    brentano Well-Known Member
    2017 TRD OR AC SSM
    In a future emergency, unplug the temperature sensor wiring to achieve a “poor man’s” override: A functional Lingenfelter will recognize the fault and run the fan at 100% command.
    Skydvrr and TWTaco[QUOTED] like this.
  5. Jun 8, 2021 at 11:36 AM
    #585
    Xplosiv
    Xplosiv Well-Known Member
    Jeff
    Lewisville, TX
    2021 OR DCSB Black 99 Corvette FRC
    265/75/16 AT's, Cali Raised Sliders, BAMF RTT Rack
    Looks like a nice piece. I havent had any cooling issues with my current 21 or my 16 but that doesnt mean I wont. Ill def look into this after warranty is up. Anything to keep things cool in North Texas Heat.
    And your Camaro sounds like it's amazing.
  6. Jun 8, 2021 at 11:36 AM
    #586
    TWTaco
    Dave
    Good to know. Most likely going back to stock fan. Cant find out the issue I am having fan wont run when it should be. Runs fine until truck is fully warmed up then the fan cycles on and off. Not supposed to do that. Called Lingenfelter they said controller looks to be working fine so is the sensor they think the fans bad. No way to fix it without completely changing everything. I am not buying it a second time. Just going back to stock. John has been excellent helping trouble shoot and finding part numbers. Hell I even replaced my thermostat. I have the 1 in a million that has a gremlin in it.
    loginfailed likes this.
  7. Jun 8, 2021 at 11:41 AM
    #587
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Damn man! Bummer
    TWTaco[QUOTED] likes this.
  8. Jun 8, 2021 at 12:19 PM
    #588
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Interesting. I only made it through the first 10 or 11 pages, but where is that temp read from? Like is it a new probe, or does it use OBDII to read the actual water temp?
  9. Jun 8, 2021 at 12:34 PM
    #589
    point45
    point45 Well-Known Member
    SoCal, OC
    05 DCSB TRD offroad
    New probe spliced into the upper hose
    SR-71A[QUOTED] likes this.
  10. Jun 17, 2021 at 2:04 PM
    #590
    TWTaco
    Dave
    Anyone know the torque setting for the nuts that hold the stock fan clutch?
  11. Jun 17, 2021 at 6:40 PM
    #591
    Ol'gray mare
    Ol'gray mare Well-Known Member
    West, Tx
    2017 MGM DCLB TRD OR Geared, locked and tuned, rear disc brakes. 2018 TRD PRO White boss' bone stock
    Build thread coming soon.
    Do y'all know of any one running this set up with a boosted (supercharged) rig?
  12. Jun 17, 2021 at 6:54 PM
    #592
    Skydvrr
    Nick
    YMH
    Black '17 OR
    @MESO :anonymous:
  13. Jun 17, 2021 at 8:41 PM
    #593
    SK808
    SK808 Well-Known Member
    Ewa Beach, Hawaii
    2017 Tacoma TRD OR DCSB 4X4
    Magnuson Supercharger, Kings w/Resi front and rear, ICON UCA, Allpro STD leaf pack, C4 Fab Hybrid Front Bumper, RCI Rear Bumper, X20 winch, All Pro U-bolt Flip Kit w/ wheelers bump stop, Method 701, 17X8.5 w/0 offset, BFG KM3 285/70/17, All Pro Sliders, TRD CAI, Spec-U exhaust, Total Chaos bed stiffener, RCI Skid Plates (all skids), Wet Okole seat covers, Diamondback tonneau cover, Grillcraft MX Grille, Husky front floor mats, Weather Tech rear floor mats, bed mat, various Baja Design lights, mobtown tailgate reinforcement plate, and a bunch of other stuff.
    I’m running this kit with the magnuson charger.
  14. Jun 18, 2021 at 2:00 PM
    #594
    Ol'gray mare
    West, Tx
    How is it working for you? I'm about to do the Magnuson.
  15. Jun 19, 2021 at 4:45 AM
    #595
    SK808
    Ewa Beach, Hawaii
    It’s working well. Feels like throttle response improved a bit and my AC feels colder.
    Ol'gray mare[QUOTED] likes this.
  16. Jan 4, 2022 at 4:06 PM
    #596
    Kane50
    Kane50 Well-Known Member
    2016 TRD Sport
    OP or anyone else know of a way to wire the fan so it’s not on when engine is off and ignition is on, like to listen to the radio sometimes when parked without having to hear the fan whine and soaking up battery voltage.
  17. Jan 4, 2022 at 5:23 PM
    #597
    Skydvrr
    Nick
    YMH
    Black '17 OR
    I usually trip my circuit breaker, but I rarely run into those situations.
  18. Jun 2, 2022 at 6:39 AM
    #598
    Pinchaser
    Pinchaser Flipper Crazy
    Alan
    2020 Tacoma ECU 04B82 AT
    Regarding sensor location: I am in full support of installing the sensor near the radiator outlet, and here is my reasoning: The need for the fan is contingent on current conditions, and if the radiator alone is providing adequate cooling, or not. If the ambient is below zero, but your sensor is on top, then you are running the fan without any need (in all likelihood). Consider the following:
    There is plenty of comment that you do not want to be constantly cycling the T-stat or it will prematurely fail: I personally don't see this as an issue. The T-stat regulates the amount of heat kept in the engine. So as the Engine Entering Water Temperature (EEWT) drops, flow thru the engine is reduced, maintaining target internal engine temperature. If it is below zero out, then the EEWT is typically extremely LOW, but no problem, the T-stat maintains (reasonably close) target engine temperatures. If T-stats fail due to excessively cold EEWT, then T-stats must fail OFTEN in Canada? I agree this has some merit; but clearly indicates that wearing out the T-stat is not a factor for outdoor temperatures during the other 3 seasons.
    I think the T-stat is more than an on-off switch, as it is Bi-Metal controlled, so how open or closed it is is likely dependent on the temp. of fluid passing thru it. The T-stat likely, has a temperature where it begins to open, and requires a higher temperature for it to fully open; thus reducing cycling to smaller movements. Of course it remains fully open at temps. above full open.
    With concern for Oil temperatures, oil temperatures take longer in winter weather, but again, despite extreme Low EEWT, the T-stat maintains engine operating temperature, and the oil does (eventually) come up to proper temperature, so EEWT is a not really an issue for Oil Temperature; at least not for the other 3 seasons.
    If you really believe that you can wear out the T-stat if your fan settings are too low (equating to low EEWT); then how do you compensate for changes to Outdoor Temperature when it is below zero? By only monitoring temperatures leaving the engine, your settings MUST cater to preventing overheating on the Hottest day, for your most extreme situations. So therefore, Aren't you running the fan and driving EEWT needlessly lower under all other conditions? Under normal driving situations, is this not creating the T-stat cycling that you want to avoid? And this same logic also applies to concerns for oil temperatures. Best to not run the fan, unless conditions warrant it.
    So as I see it, the advantages of having the sensor monitor EEWT (instead of Engine Leaving Water Temperature, ELWT) are:
    - Stabilizes EEWT to a considerable extent (Does not leave EEWT up to chance and changing environmental conditions)
    - Is pro-active by regulating EEWT (instead of reacting to elevated temperatures Leaving the Engine)
    - Takes full advantage of natural cooling (ambient air temperature, radiator size and air flow without fan)
    - Reduces electric load
    - Minimizes lower than necessary EEWT
    - Possibly extends life of T-Stat
    - (somewhat) reduces length of time for oil to reach operating temperature
    - reduces noise (fan)
    - Possibly extends the operating life of the electric fan (will run less often/lesser fan speed)
    Possible disadvantages:
    - slight lag in responding to surge of higher ELWT (sudden heat generating load, like passing a car) Not yet shown to be problematic.
    - Reduces the improvement to AC cooling operations (unless alternate controls are added, specific to AC demand)
    - Less fan noise? (maybe you like it)
    - Possible higher under hood temperatures (but if EEWT is cool, then under hood temp. and airflow is most likely adequate already)
    I have read this entire thread, and others on this topic, to arrive at the above. Interested in what others think.
    I am working out how I to proceed with controlling the fan on my vehicle. There is still much to consider, but this post is too long already.
  19. Jun 2, 2022 at 6:57 AM
    #599
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Nice summary. I think you hit all the points, AC is a big one. It’s basically worthless without some airflow.
    SR-71A likes this.
  20. Jun 2, 2022 at 7:09 AM
    #600
    MaGuyver
    MaGuyver Well-Known Member
    Savannah, Ga.
    2020 Tacoma Sport, Cement
    Tinted glass, Bed mat, Rigid light bar, Bakflip FiberMax tonneau, Bull bar, LED cabin lights, Bed lights.
    You may have stated this (if so, which page is it on), but what is the HP and torque gain by removing the engine fan? Thanks
