Cooling issues? Not anymore
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Deo taco, Aug 25, 2020.
  1. Aug 25, 2020 at 9:09 PM
    #121
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Under this logic, then no "aftermarket" parts make any improvements in performance....
    Technically he never said that he was an engineer for Toyota. Devil's in the details. ;) Always feel free to spend your hard earned money as and where you please. The well informed will spend their money as they please.
  2. Aug 26, 2020 at 3:48 AM
    #122
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
  3. Aug 26, 2020 at 4:13 AM
    #123
    Paulndot
    Paulndot Well-Known Member
    2020 TRD Off Road
    WOW... I get the R&D costs need to be made up, but $800 (on the low end) for a plastic shroud, fan, and electric motor? I'm sure this will help the guys running out in the deserts, or up the the thinner air as you said. For the other guys, probably 80% of us I'm guessing, it's a tough sell. I think it's a niche product man. GOOD LUCK! Bringing new(ish) ideas to market is always tough - hopefully it works out for you.
    D.A.S. Taco, Mmaira2018 and mu.n8ball like this.
  4. Aug 26, 2020 at 5:03 AM
    #124
    Deo taco
    Deo taco [OP] Well-Known Member
    2017 trd pro in cement grey.
    Lots to come
    No any 12v command will work
  5. Aug 26, 2020 at 5:20 AM
    #125
    jas235
    jas235 Member
    On the hunt!
    While I will agree that the failure modes you mention are possible, most cars on the road (every transverse engine car, at least) uses an electric fan as its only cooling. It should be quite possible to make a reliable electric setup!
  6. Aug 26, 2020 at 5:24 AM
    #126
    Itchyfeet
    Itchyfeet Well-Known Member
    Warranty issues should be the reason that most people should have second thoughts about doing this. If your truck is under warranty, this could be something that would void the warranty. I'm sure someone will cite Magnuson–Moss Warranty Act they often incorrectly do
    Gunshot-6A and EatSleepTacos like this.
  7. Aug 26, 2020 at 5:24 AM
    #127
    Deo taco
    Lots to come
    Its a bit more then that. Sure you could go buy a 16in fan and small controller and prove for the rad and it would work. But its not reliable for a daily. Thats for like a classic muscle car. These parts im using have to be the best bc it has to work. Most of us don't have a tacoma as just a toy to use here and there. That's why we chose the parts we chose. To ensure that reliability and to ensure it works for all. I might work on a cheaper kit but how much cheaper it will be is unknown. Bc ill still pirate a oem validated pwm setup to ensure the fan won't quit on you
  8. Aug 26, 2020 at 5:29 AM
    #128
    dunlap837
    dunlap837 Well-Known Member
    2018QSDCLBSR5
    Enhanced Skinny Pedal
    What are you using to record these values? Looks like something I'd be interested in.
    MountainManGuy likes this.
  9. Aug 26, 2020 at 5:44 AM
    #129
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Just an obd2 plug and the obd fusion app
    tonered likes this.
  10. Aug 26, 2020 at 5:48 AM
    #130
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    I've never seen or heard of any cooling issues. My temps run 190-195 even on the hottest and most humid of days in NJ. Never even touched 200.
  11. Aug 26, 2020 at 7:01 AM
    #131
    BlacknWhite23
    BlacknWhite23 Member
    Michael
    ‘19 TRD Off Road
    Doubt I would be in on something like this, however I enjoy seeing people work out problems. This probably will never be a problem for my rig, however just hauling my arse back and forth is all she is going to do.
  12. Aug 26, 2020 at 7:21 AM
    #132
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Let's expand on that just a bit. :D
    If engineers were allowed to run free, stuff would cost two or three times as much, would take twice as long to develop and launch, and would last at least twice as long.
    Everyone from managers through bean counters, marketing, CEOs, and stockholders want zero part of that. :bananadead:
    Customers want a $15k Taco that most only keep around for 3yrs.
    Who's correct in all of this? Us, them, no one? :cheers:
  13. Aug 26, 2020 at 7:25 AM
    #133
    Kev250R
    Kev250R Well-Known Member
    Kevin
    Orange, So.Cal.
    2020 Tacoma TRD Off-Road 6MT
    Floor mats, junk in center console
    I don't disagree, many (if not most) late-model cars use this style of fan, however I've personally seen one fail (because of a chaffed wire) which caused the engine to overheat and blow a head gasket. A local shop I'm friendly with tells me it's a pretty common issue they see regularly. That's why I suggested the OP add a status light to alert the driver if the fan stops.
    My off-road car is a heavily-modified VW Thing with a swapped-in Turbo-charged Ford engine in it (picture of the car in my album). Because of the engine being in the rear (and the radiator being above the rear seat) I can only run dual electric fans on it. Thankfully it's very obvious in that car when those fans turn-on. If it wasn't I would add a light to tell me when they wern't on. It was also on that same car where I saw that upgrading from a two-row radiator with plastic tanks to an aluminum four-core radiator made a dramatic difference in how often my fans have to run. Unless I'm on the freeway or pushing it really hard in the dirt it takes a long time (~20 minutes) for the fans to kick-on. With the previous, smaller radiator that time was about half of that.
    My point is replacing the stock mechanical fan with an electric unit is a neat idea, but without Dyno numbers for *this application* it's impossible to say if it will result in higher horsepower or not. If it's only an increase of say less then 5 HP is it really worth it?
    Personally I think the proposed cost is too high. The four-core radiator and dual-fan system I'm running on my afore-mentioned VW Thing cost about half of what the OP is proposing for his system. FWIW My system uses all OEM parts from a Jeep XJ (radiator) and fans from a Chrysler Minivan.
    Add a status light so if (/when) the fan stops the driver knows it.
    My plan is to upgrade my Taco to a larger radiator (once the warranty is over) and call it a day.
  14. Aug 26, 2020 at 7:28 AM
    #134
    Deo taco
    Lots to come
    Its also a global platform. That is designed to run for ever in stock form anywhere. Toyota also does it if works dont fix it so there is a ton of old tech in these trucks.
    Here we dont keep it stock. And thats where this comes in.
    AxisCab and Rainoffire like this.
  15. Aug 26, 2020 at 7:35 AM
    #135
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    The customer is always right. :laughing:
    My take on it is that if its cheap and easy, Toyota would have already done it. When you get into more serious stuff like this you have to ask why didn't they do it? Did they feel it was too expensive for the market? An engineering compromise? Something we haven't thought of?
    I like the idea of electric fans, but a reliable implementation is going to be crucial. At the very least I would upgrade my temperature gauge so it actually reads the temperature.
  16. Aug 26, 2020 at 7:39 AM
    #136
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The customer is right when it is easy. o_O
    The current fan is defacto. It's a known and Toyota is conservative. Why put in additional testing, yadda, yadda . . .
    Electric fans are the norm these days. There's no risk on the OE side other than the cost of the change.
    On the gauge, I am surprised it is still there. Bet on the same or worse (a light only) in the future. Sorry!
  17. Aug 26, 2020 at 7:43 AM
    #137
    0xDEADBEEF
    Yep, agreed. We've already seen where they've cut costs on the tacoma compared to 4runner in other places, this might be one of those things.
    The lack of useful gauges on vehicles these days is such a shitty trend. Its worse when they replace them with gauges that are just on/off. Ugh.
    Gunshot-6A and tonered[QUOTED] like this.
  18. Aug 26, 2020 at 7:51 AM
    #138
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It will continue, esp when the masses are asking for more gizmos. Folks want more features, stuff like bed cubbies and AT coolers disappear.
    On the gauge side, at least there is OBD. All the real data is thankfully still available. Just have to seek it out.
  19. Aug 26, 2020 at 8:45 AM
    #139
    Lucario Runner
    Robert
    06 Toyota 4Runner
    True. Chained up by legal, finance, management, emissions, focus groups etc.
    Torspd and tonered[QUOTED] like this.
  20. Aug 26, 2020 at 8:49 AM
    #140
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :cheers:
    Focus groups! AKA, how can a group of customers get it so wrong? :facepalm:
