Coot83's bro inspired "Baller Maller" Build
Discussion in '2nd Gen. Builds (2005-2015)' started by Coot83, Jun 28, 2017.
  1. Feb 16, 2018 at 7:40 AM
    #841
    Coot83
    Coot83 [OP] DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    Yea def better, so was yours an addition to the “p” to make it a “b?” Def pretty slick man.
    MESO[QUOTED] likes this.
  2. Feb 16, 2018 at 7:42 AM
    #842
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    It's an addition to the P. Just a small 3d printed+painted piece at the bottom. You can see e line if you look hard. Tired to keep as OEM as possible.
    Coot83[QUOTED][OP] likes this.
  3. Feb 16, 2018 at 9:11 AM
    #843
    Coot83
    Scottsdale, Az
    2012 Baja TX
    I noticed that and I can appreciate that. Did you get the base of the emblem off eBay or from a fellow pro owner?
  4. Feb 16, 2018 at 9:46 AM
    #844
    MESO
    State of Jefferson
    A member sent me the OEM badges to transform them.
  5. Feb 20, 2018 at 5:36 AM
    #845
    Coot83
    Scottsdale, Az
    2012 Baja TX
    So another little update...well I played around with my prinsu and decided to remove the first horizontal plank closest to the front.
    Two reasons for this: the air distortion of the light bar needs a little more room to dissipate from the roof rack to mitigate further noise, the second is I have a sunroof and didn't want the hinderance of the bar being in the way when it was opened.
    An oberservation when removing the front plank without the fairing is I have taken away enough struturability of the front part of the rack where it now can be slightly floppy and not rigid up front. I am going to play around with the single plank that comes with the rack and see if I can strategically insert it where it might make sense. Worst case it just wont be rock solid up at the very front like it is from the middle and back. As the testing will continue, I hope to find a solid configuration that will work for the long run but I am happy with the lack of noise currently.
  6. Feb 20, 2018 at 3:30 PM
    #846
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Well it turns out some asshole who I took my truck to for an oil change in Dallas cross threaded my drain bolt. I’m not sure if my shit will drain or stay, but I get the feeling it’s going to have a slight leak. Go figure the one time I let someone change my oil in three years.
  7. Feb 20, 2018 at 3:39 PM
    #847
    ericd
    ericd Stuff
    Eric
    las vegas
    2013 DCSB 4x4 OR
    Chase the threads and it will probably be fine depending on how bad it was. Otherwise helicoil that thing and call it good.
    Gunshot-6A and Wild Crow like this.
  8. Feb 20, 2018 at 4:18 PM
    #848
    Coot83
    Scottsdale, Az
    2012 Baja TX
    What is helicoil? I’m still getting a small leak in it.
  9. Feb 20, 2018 at 5:53 PM
    #849
    ericd
    ericd Stuff
    Eric
    las vegas
    2013 DCSB 4x4 OR
    If you able to get it to thread well you could also use a fumoto valve, so you don't have to take it out each time you do an oil change, and use some thread sealant.
    The most common usage for helicoils is to repair cross threaded spark plug holes. We used to go through them pretty fast on VW motors. I had a boss with an f150 that used to blow the spark plugs out about once a month.
    http://www.stanleyengineeredfastening.com/brands/heli-coil
  10. Feb 21, 2018 at 6:18 AM
    #850
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Appreciate the info man...my original intention was to install my f103 fumoto valve but I didn't want to mess it up so I went with the drain bolt this time. Since the oil pan is 20 bucks I am doing a temp gasket sealer around the bolt until next oil change. After that Im going to swap out the pan.
  11. Feb 23, 2018 at 9:14 AM
    #851
    Coot83
    Scottsdale, Az
    2012 Baja TX
    I have always had an interest in setting up a front camera for better approaches on things and just to give better perspective when on trail. Im leaning towards the ebay one as for me I am pretty loaded up on buttons in the cab. The fact that this might be able to utilize the call button to cycle would be great as I never use it in my ride.
    Don't know if anyone has considered getting a set up like this, but Im very strongly thinking about pulling the trigger soon.
    tonered[QUOTED] likes this.
  12. Feb 23, 2018 at 9:29 AM
    #852
    Superman910
    Superman910 Epic Dirty
    Eric
    Northern Virginia
    2009 Tacoma TRD Sport DCLB 4x4
    Stock as Fuck or Not Fucking Stock
    I am going to do it once Pioneer and/or Kenwood releases that nice ass Android Auto 2-Din with two channel inputs for cameras, its either that or go with a 1-din and see about doing something to route via Ipad (Still using android Auto) mount via the tech deck extreme
  13. Feb 23, 2018 at 9:31 AM
    #853
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Ah nice man and that totally makes sense. Since I got the screen on my dash I am eager to see how this works. I would go your route if I had to use the tablet though.
  14. Feb 23, 2018 at 12:40 PM
    #854
    Coot83
    Scottsdale, Az
    2012 Baja TX
  15. Feb 24, 2018 at 6:53 AM
    #855
    Coot83
    Scottsdale, Az
    2012 Baja TX
    I installed these just before the weather went to shit this week.
    These things are pretty cool, adds a little cushion like a topper does to a bed.
    RyanL, misdirection1982 and 90yota like this.
  16. Feb 24, 2018 at 6:55 AM
    #856
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Getting the emblems ready for bro status...in case anyone is interested all you need is a thin exacto blade.
    Use the blade To get underneath the letters and slowly wedge them off as you pry from underneath through out the letters.
  17. Feb 25, 2018 at 6:50 AM
    #857
    Justanotherhemi
    Justanotherhemi Space Cowboy/Ninja
    Rick James
    Area 52 (because area 51 was full)
    Intelligent Life Exists
    Updated! Truck is looking sekxy AF Cootster!
    #trdBRO
    Coot83[OP] likes this.
  18. Feb 25, 2018 at 9:57 AM
    #858
    RyanL
    RyanL Well-Known Member
    Indiana
    15 TRD Pro, supercharged, BP-51s, etc
    Those look NICE, congrats on the upgrade.
    The Bro logos are gonna look so legit!
  19. Feb 25, 2018 at 8:11 PM
    #859
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Hell yea it is... just need those B’s!
    Dalandser likes this.
  20. Feb 25, 2018 at 8:12 PM
    #860
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Appreciate it man! Finally gonna live up to the name!
