Corbeau Retractable Harness
Discussion in 'Product Reviews' started by nfs257, Jun 19, 2013.
  1. Jun 19, 2013 at 7:20 PM
    nfs257
    nfs257 [OP] Well-Known Member
    DFW
    She gone
    Has any body used these to suffice until a cage was made for a normal 4 or 5 point harness? :notsure:
    http://www.corbeau.com/products/harness_belts/2-inch_retractable_harness_belts/
    Corbeau 2 Inch Retractable Harness Belts are a result of Corbeau’s dedication to innovation and style. This unique harness belt has raised the bar as it pertains to user friendliness. We know how uncomfortable and annoying it can be to use harness belts in your daily driver. Once you are strapped in a harness belt, there is little to no moving around. With that in mind we designed the Retractable Harness Belt. This harness belt features an inertia reel, which allows your harness belt to function like your stock belt. That means you can still move around but it will lock under sudden movement or jolt. It also features an on-off switch, which allows you to turn the retracting option off so your belt will function as a full time harness belt. In additions the Retractable Harness Belt has the double release feature, which allows you to disconnect the front shoulder straps from the rear tail strap. This feature allows for easy access to the rear seat as you can disconnect that rear strap without taking the belts out. They also have the rare ability to be bolted to all your factory provided mounting points. What that means is all our hardware was manufactured to bolt right up to your factory bolt holes. In most cases no drilling or modifications are necessary, they just bolt right in. Corbeau Retractable Harness belts are available in a 3 point, bolt-in style only. Each harness belt is manufactured with pressure reducing waist pads to provide extra comfort. "
