Core Support is Tearing Itself Apart
Discussion in '2nd Gen. Tacomas (2005-2015)' started by desertjunkie760, Aug 19, 2018.
  1. Aug 19, 2018 at 11:37 AM
    desertjunkie760
    desertjunkie760 [OP] @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    While doing a service on the truck today, I noticed some very concerning stress cracks on the core support. One of which has torn clean through!
    At this point, I am trying to look into my options to correct the issue. My initial thought was to stitch weld the support together. This is the easiest and likely the cheapest option, but also the most redneck way you could do it. If it was just cracks, I would probably consider it, but being the support is cracked fully through, I am leaning more towards wanting to replace the entire unit.
    After further investigation, it looks like one of the radiator support bushings is GONE! I feel like the support bushing came loose, fell out, and put additional stress on the radiator support itself. This is why the crack is so pronounced on one side, and not the other.
    Has anyone had experience with replacing a core support? It looks like there are some spot welds holding everything together but they do sell replacement support assemblies which makes me believe it can be done. Any advice is appreciated.
    Passenger side bushing is gone.
    Driver's side
    Crack through the support.
    AR15xAR10 likes this.
  2. Aug 19, 2018 at 11:46 AM
    IwasDacapsterAz
    IwasDacapsterAz Well-Known Member
    Cap
    14 4w4 Taco Access
    Bamf and Bilstien
    What's up with the zip tye?
    TomTwo likes this.
  3. Aug 19, 2018 at 11:51 AM
    desertjunkie760
    Shane
    Check My Sig.
    That's what you noticed?
    Thats where the grill and headlight meet. There are four holes. Two are for bolts and the other two look to be those plastic snaps that always break so I replaced with some zip ties.
    MalinoisDad, Biscuits, Mully and 12 others like this.
  4. Aug 19, 2018 at 11:55 AM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    Crom, Mully, lo2hi and 11 others like this.
  5. Aug 19, 2018 at 11:56 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Dude, my whole grill is held on with zip-ties... Ain't nothin wrong with zip-ties....
  6. Aug 19, 2018 at 11:57 AM
    desertjunkie760
    Shane
    Check My Sig.
    :rofl:
    So is mine. At least the none important parts.
  7. Aug 19, 2018 at 11:58 AM
    desertjunkie760
    Shane
    Check My Sig.
    I had the Energy Bushings already in there. Looks like one just came loose. Did you replace the entire radiator support for the final fix?
  8. Aug 19, 2018 at 12:04 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    Nope. Just cut the ends of the replacement off and used about a foot of each end of it so I wouldn't have to get involved with the spot welds across the top of the radiator. The hood prop hole was a bit of a pain, but other than that it lines up pretty well and nests on top of the broken one just fine.
    jeminyned, Mully, TomTwo and 2 others like this.
  9. Aug 19, 2018 at 12:08 PM
    IwasDacapsterAz
    Cap
    14 4w4 Taco Access
    Bamf and Bilstien
    My bad, thought you may have missed a bolt thus creating that mess....
  10. Aug 19, 2018 at 12:19 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    Of course, we all know that this is the correct way to fix this problem. I aspire to having this done one day:
    essjay, kidthatsirish, Crom and 13 others like this.
  11. Aug 19, 2018 at 12:21 PM
    desertjunkie760
    Shane
    Check My Sig.
    Don't give me ideas!! :rofl:
    TnShooter, TRDSport10, TomTwo and 2 others like this.
  12. Aug 19, 2018 at 2:07 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    My buddies looks worse than this.
    He just runs it as is lol
  13. Aug 20, 2018 at 6:50 AM
    desertjunkie760
    Shane
    Check My Sig.
    Yeah, I’m not planning on running it this way. Going to get a new support bushing coming today and probably order an aftermarket core support.
    TomTwo and whatstcp like this.
  14. Aug 20, 2018 at 7:06 AM
    anthony250f
    Anthony
    San Diego, CA
    Good plan. I did the support bushings too.
  15. Aug 20, 2018 at 7:28 AM
    desertjunkie760
    Shane
    Check My Sig.
    OE is $412!?! :puke:
    12TRDTacoma likes this.
  16. Aug 20, 2018 at 10:32 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Weld it up (not spot weld) and then weld on a a steel support brace.
  17. Aug 20, 2018 at 10:40 AM
    desertjunkie760
    Shane
    Check My Sig.
    The metal on our trucks is so thin that welding can be extremely difficult. You burn through way to easy. I’d have to weld to piece of filler plate. This will probably be the temporary fix until I have the time/fun’s to do it the right way.
    12TRDTacoma and EDDO like this.
  18. Aug 20, 2018 at 10:45 AM
    lynlan1819
    Tacoma
    Lifted
    Done it hundreds of times on same thickness metal using a Mig Welder, easy
    Mully, ericvega, 3 Blade Rage and 2 others like this.
  19. Aug 20, 2018 at 3:33 PM
    casey2012
    casey2012 Well-Known Member
    mark
    yota
    none
    do you all know what causes that ?
  20. Aug 20, 2018 at 3:46 PM
    lynlan1819
    Tacoma
    Lifted
    Heavy off-roading usually,speed bumps,pot holes
