Correct O2 part numbers?
Discussion in '1st Gen. Tacomas (1995-2004)' started by kuntry09, Dec 3, 2018.
  1. Dec 3, 2018 at 8:09 PM
    kuntry09
    kuntry09 [OP] Well-Known Member
    Cam
    Douglas, Georgia
    '99 extended cab Tacoma 4x4 converted Prerunner
    I purchased new Denso O2 sensors for my ‘99 prerunner extra cab. I ordered NP 234-4162 for the upstream, and NP 234-4153 for the down stream. The upstream is correct, the lead is just slightly longer on the new one. However, on the downstream the new lead is about 6” or so shorter than the old sensor. Did I order the incorrect downstream sensor? I got the PNs by cross referenced numbers on the Denso site. I can make the downstream work, but would rather return it for the correct one.
  2. Dec 3, 2018 at 8:11 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
  3. Dec 3, 2018 at 10:25 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    The wire length should be identical to the original. It’s possible you may have gotten a sensor for a Cali emissions or not cali emissions (I don’t know what it
    You have) if you have 2 cats it is cali. 1 cat is federal
  4. Dec 3, 2018 at 10:28 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    What do you mean by "cali"?
    California emissions? That can't possibly be right for 2 cats. I'm almost certain I have 2 cats and I'm no where near cali.
  5. Dec 3, 2018 at 10:30 PM
    Empty_Lord
    Dan
    I’m pretty sure 99 had the option for dual cats or single. The emission label under he hood would say.
    And I forgot but the manual sensor is different from the automatic
    Chances are if the sensor you have reached the plug in though it would likely work
    Matic[QUOTED] likes this.
  6. Dec 3, 2018 at 10:31 PM
    Empty_Lord
    Dan
    Oh you have an 02. All the trucks from 2001 I believe are 50 state spec
  7. Dec 4, 2018 at 6:54 AM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    if you have extended cab, the good downstream sensor is 234-4189, but for some weird reason, it sometimes does not show up in searches as a compatible part...
    The sensors are the same, the only difference is the wires lenght. You could cut and splice the new sensor to your old wiring and it will work no problem (that's what I did on mine)
  8. Dec 5, 2018 at 7:35 PM
    kuntry09
    Cam
    Douglas, Georgia
    Thanks for that! I’ll see if I can find that part number on rockauto. Worst comes to worst, I’ll use the sensor I purchased and extend the wires slightly.
