Correct TPMS?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jpereira2, Apr 18, 2018.
  1. Apr 18, 2018 at 6:11 PM
    jpereira2
    jpereira2 [OP] Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
  2. Apr 19, 2018 at 3:39 AM
    jpereira2
    Massachusetts
  3. Apr 19, 2018 at 3:43 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    They'll work, Toyota (Denso) only really has 2 TPMS sensors, one for alloy stock wheels and one for steel stock wheels the difference being the angle of the sensor in relation to the valve stem.
    That said if you have aftermarket wheels it's anyones guess which kind will fit.
    That said again, the installing shop can (and will generally) turn the sensor around "backwards" and they work just as well.
    jpereira2[OP] likes this.
  4. Apr 19, 2018 at 4:19 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I have always wonder how can you tell how old they are? Since your buying something with a battery in it. How do you know you aren’t buying something that sat on the shelf for 5 yrs. do they have a battery date on the side?
  5. Apr 19, 2018 at 4:39 AM
    Key-Rei
    Key
    Florida
    The do have codes stamped into the bodies, sometimes there's a QR code printed on it, I don't remember if the date is in a standard 'date' format or if it's hidden in a number someway but I know there is a way to find the age.
    That is a very real concern, knowing the date of manufacture. TPMS batteries are good for about 7 years average.
    Stryker420 and spitdog[QUOTED] like this.
  6. Apr 19, 2018 at 6:16 AM
    jpereira2
    Massachusetts
    I just contacted the seller, we will see what they say. But that is certainly a concern.
  7. Apr 19, 2018 at 6:35 AM
    RickG
    RickG It seemed like a good idea at the time...
    Southern NH
    2010 SR5 4x4 Pyrite Mica
    Color matched grille, Access tonneau, OEM Temp/compass, De-badged, OEM hitch, Custom rear storage/dog deck, LED foot well lighting, Illuminated 4x4 switch
    The aftermarket ones I bought (...ITI, I think) didn't quite make it to 5 years. The vendor even made a point of stating in the ad that they didn't "activate" them until they were ordered, which given that they're a sealed unit would pretty much have to be BS.
    When the light came on with tires properly inflated and wouldn't reset, my local tire shop replaced all 4 and re-programmed for ~$160. Easier than ordering some, then finding someone to install them, and maybe someone else to program them in.
    spitdog likes this.
  8. Apr 19, 2018 at 6:37 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    I got all 4 TPMS for my 2014 I could sell you for cheaper if you are interested.
  9. Apr 19, 2018 at 6:40 AM
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
  10. Apr 19, 2018 at 6:51 AM
    spitdog
    After doing a little searching, I saw that tech stream can verify if the batteries are in good shape, so If you have someone installed these,it may be a good idea to see if they can check them first before they mount them.
    I also saw they have a sleep mode, that is to preserve battery life while sitting on a shelf or when the vehicle is not in motion for a period of time.
  11. Apr 19, 2018 at 7:51 AM
    jpereira2
    Massachusetts
    depends on how much cheaper since they are already 4 years old
  12. Sep 24, 2018 at 7:33 AM
    knucklehed
    knucklehed Well-Known Member
    OC, CA
    08 DCSB
    I feel like the TPMS sensors on my '08 have always been hit or miss in that sometimes they work, sometimes they don't. Is there a shelf life for these ? Maybe the batteries be changed out every couple of years?
    For the life of the truck I've never had a consistent sensor
  13. Sep 24, 2018 at 7:34 AM
    knucklehed
    OC, CA
    08 DCSB
    oof. just saw this thread is half a year old.
  14. Sep 24, 2018 at 8:35 AM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    You knucklehed... sorry couldn't resist
  15. Sep 24, 2018 at 8:57 AM
    knucklehed
    OC, CA
    08 DCSB
    Living up to my name!
