Correct Under Sink Plumbing?
Discussion in 'Garage / Workshop' started by kris77, Apr 13, 2012.
  1. Apr 13, 2012 at 9:13 AM
    kris77
    kris77 [OP] Born in the Backwoods
    West Virginia
    08 DC TRD Sport Speedway Blue
    In channel Vent Visors, AVS Bug Shield, Hankook Dynapro RF10 265/70/17
    Short story, My garbage disposal is going bad, so im going to replace it. I'm having the problem now everytime i turn on the disposal, crap comes up in the other bowl of the sink.
    Whats the correct way to plumb a disposal under a sink.
    Mine looks like this now...
    Just add a disposal on the left side. I'll try and get a pic tonight.
  2. Apr 13, 2012 at 9:23 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Not sure if this is the correct way but if I were to add a disposal, I'd make the trap straight under the disposal and the other sink bowl T in below the disposal. Otherwise, The T you have in the center should have something in the middle to direct the water down to the trap so water can't easily pass through the T and come up the other bowl.
  3. Apr 13, 2012 at 9:24 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    PM Brutalguyracing - he's the resident pipe expert. :D
  4. Apr 13, 2012 at 9:25 AM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    '18 T4R & '06 F250
    6" lift 40s
    This
    EDIT I forgot how a disposal works :eek: they go out the side, not the bottom, so this no workie.
  5. Apr 13, 2012 at 9:26 AM
    JonnyBb
    JonnyBb I have to return some videotapes
    Arkansas
    2021 TRD Pro (upgrade from my 2nd gen)
    Work in progress, but mods so far; OTT 7.0 tune, 255/85/16 Falken WildPeak M/Ts
    This is what mine looks like, but drain down instead of back
  6. Apr 13, 2012 at 9:33 AM
    4x4jeep
    4x4jeep Well-Known Member
    Kyle
    Destin FL.
    Mines like this too
  7. Apr 13, 2012 at 9:45 AM
    Pugga
    Massachusetts
    Shit, forgot they come out the side :eek:
  8. Apr 14, 2012 at 5:22 AM
    JonnyBb
    Arkansas
    Hey OP, I was mistaken. The first pic I posted was similar to what I had in my first house. My current house is set up with a trap off the garbage disposal which goes to a T before the drain. The sink side then has a trap that connects to the other side of the T. It doesn't back up quite as bad.
  9. Apr 14, 2012 at 5:29 AM
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2015 DCSB OR Auto Silver Sky 4x4 / 2017 4Runner Premium
    Here it is:
  10. Apr 16, 2012 at 3:18 AM
    kris77
    West Virginia
    This makes sense having a 90 attached to the disposal then going over to the straight pipe going down to the trap. Wonder if that "T" is a straight "T" or a directional "T"?
  11. Apr 16, 2012 at 11:02 PM
    El Tano
    El Tano i am the one who knocks
    Pasadena. CA
    10 Tacoma TRD sport
    Corvette homelink FRONT: 5100 Blinstein set at 0 Procomp 3" leveling kit Allpro UCA’s. REAR: Icon Multi Rate RXT Leaf Pack 5100 Blinstein. 17x9 kMC wheels 0 BS 285/70 17 Wildpeak A/T4W C range Amp research steps. and a bunch of TSB's
    Dude, if this is your sink, you need to get the drain hose from the dishwasher higher otherwise the dirty water, food, etc from he disposal can go in the hose.
  12. May 7, 2012 at 5:30 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    Thats a 1st. I have never seen a 4'' line brought up under a sink like that b4?
  13. May 30, 2012 at 4:24 PM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    What you are looking for is a continious waste. This will connect the disposal to the p-trap for the waste to go down
  14. May 30, 2012 at 4:33 PM
    Deercantseeme
    Deercantseeme Well-Known Member
    Massachusetts
    If it is backing up its most likely due to your drain being plugged. As a plumber that would be the first thing I'd check. You'll most likely find that to be the problem.
