Correctly or Incorrectly Done TSB-susp?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GregO, Mar 27, 2008.
  1. Mar 27, 2008 at 5:20 PM
    GregO
    GregO [OP] Northern Alliance:Scout-sniper
    06 TRD/SR5-4WD Off RD pkg.
    2 JL-10's,1400watt Amp, IPOD interface, Maglite holster,
    How can you tell if the TSB for the Suspension was done Correctly or Incorrectly? What are some indicators when you go to pick up your taco at the dealer, to tell you if it was done right or wrong? And what is up with the dealer saying that they have to inspect our Truck when Toyota Corp said they checked my Vin and I qualify?
  2. Mar 27, 2008 at 5:24 PM
    Charli
    Charli Stealer of Souls
    Chuck?
    Ohio
    '06 Black Sand 4X4 SR5 TRD Sport V6 Access Ca
    Towing pkg with Mossberg hitch cover, Toyota tube steps, 3" Toytec lift and TSB, 1" diff drop, Tacoma World sticker, sockmonkey decals
    Some dealerships are a whoppin' great pain in the ass is all I can figure! The leaf springs should be a four-pack instead of a three. I think yours already came with the Bilsteins? If it did, then all that will change is the leafs and an alignment. If you didn't already have the Bilsteins, you should have them now. I don't have the link, but when I had it done, I googled the TSB and printed it out to take with me--its the surest way to check if they've done it correctly.
    Put TSB in the search feature here and you will come up with a post that tells you all you need to know--including the link to the pdf.
  3. Mar 27, 2008 at 5:25 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    ok....after the rear leaf(harsh ride) tsb is done.....there should be a total of 4 laef springs on each side.....3 leaf springs and an over load spring.....if its done incorrectly.........you will have a new set of the "old" springs with three leafs. also, an alignment should be performed, as well as new shocks all the way around if your truck is just the sr5 version and not the trd offroad or sport.
  4. Mar 28, 2008 at 1:34 PM
    GregO
    Sweet thanks all, for the info...pics to come
  5. Mar 28, 2008 at 1:36 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
  6. Mar 28, 2008 at 2:41 PM
    Basshunter
    Basshunter Idaho
    Just picked mine up from the dealer here in idaho and Yes it has Bilsteins and 4 leafs installed.They also did the brake rotor replace TSB for the squeaky brakes when backing up.
  7. Apr 24, 2008 at 6:25 AM
    kaszeta
    kaszeta Well-Known Member
    I didn't know that squeaky brakes when backing was a TSB....
    I haven't had the leaf spring TSB yet, but I have noticed that with even a little weight in the back, my rear suspension is really "creaky" and bouncy.
  8. Apr 24, 2008 at 9:05 AM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    I didn't get an Alignment when I had my TSB done. The dealer owes me one now. I figure after I get the truck lifted I'll have them align it for free.
  9. Apr 24, 2008 at 2:38 PM
    Basshunter
    Basshunter Idaho
    Yep there is a TSB for the squeeky brakes when backing up.New Rotor replacement. My Tacoma was very rough/bouncy on rough roads especially washboard gravel ones.Drives like a Champ now with the updated springs and Bilsteins...
  10. Apr 24, 2008 at 6:37 PM
    kaszeta
    Mines a TRD, so I already have the Bilsteins. I've got a service appointment for next week for them to check out the brakes and leaf spring TSB.
  11. Apr 27, 2008 at 6:58 AM
    music_man185
    music_man185 Active Member
    NC
    07 Black Double Cab, SR5, 4x4
    i have a 07 dbl cab sr5 4x4. how can i tell if i have bilsteins or the tsb? also, are tsb's done for free at the dealership? what could i benefit from it?
